目标:循环播放 XX s后休眠XXX,再唤醒再次循环
实际运行始终处于播放状态。。。
#include <mega88.h>
#include <sleep.h>
#define wav_size 5080
flash unsigned char wav[wav_size] = {
0x80,0x80,0x80,0x80,0x81,0x80,0x81,0x81,0x80,080,0x80,0x80,0x80,0x80,0x80,0x80,
0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x7f,
0x7f,0x80,0x80,0x80,0x80,0x80,0x80,0x80
}; //采样频率8K,分辨率8 位的 Wav 数据
#define true 1
#define false !true
volatile unsigned char State =0; //播放间隔
volatile unsigned char sleep = false;
volatile unsigned int wav_index=0;
volatile unsigned char wdt_counter=0; //看门狗延时
const unsigned char delay_sleep = 4; // 休眠期8s*4=32s
const unsigned char delay_play = 6; // 播放期8s*6=48s
//期望 32s 休眠后唤醒 48s,
void Ports_Init(void)
void Timers_Peripherals_Init(void)
TCCR0A=0x83;
TCCR0B=0x01;
TCNT0=0x00;
OCR0A=0x00;
OCR0B=0x00;
ASSR=0x00;
TCCR2A=0x02;
TCCR2B=0x02;
TCNT2=0x00;
OCR2A=0x7C;
OCR2B=0x00;
TIMSK2=0x02;
PRR=(1<<PRTWI)|(0<<PRTIM2)|(0<<PRTIM0)|(1<<PRTIM1)|(1<<PRSPI)|(1<<PRUSART0)|(1<<PRADC);
PRR1=(0<<PRWDT)|(0<<PREFL)|(1<<PRPCI);
interrupt [TIM2_COMPA] void timer2_compa_isr(void)
#asm("cli");
if (State == 0) OCR0A = wav[wav_index];
else OCR0A = 0x7f;
if (++wav_index > wav_size)
wav_index = 0;
State ^= 0x01;
#asm("sei");
interrupt [WDT] void wdt_timeout_isr(void) //看门狗中断只负责按时序确定状态
#asm("cli");
MCUSR = ~(1<<WDRF);
switch (sleep)
case false:
if (++wdt_counter > delay_play)
sleep = true;
wdt_counter = 0;
case true:
if (++wdt_counter > delay_sleep)
sleep = false;
wdt_counter = 0;
#asm("sei");
CLKPR=0x80;
CLKPR=0x02;
MCUSR = (0<<WDRF);
#asm("wdr");
WDTCSR = (1<<WDCE)|(1<<WDE);
WDTCSR = (1<<WDIE)|(1<<WDP3)|(0<<WDCE)|(0<<WDE)|(0<<WDP2)|(0<<WDP1)|(1<<WDP0); //8s 中断模式
Ports_Init();
Timers_Peripherals_Init();
#asm("cli");
wdt_counter = 0;
sleep = false;
#asm("wdr");
#asm("sei");
while (1)
switch (sleep)
case false:
case true:
// #asm("cli");
powerdown();
