发表于 2014-5-23 17:06:09
- static const GUI_WIDGET_CREATE_INFO _aDialogCreate[] =
- { FRAMEWIN_CreateIndirect, "Edit winmode", 0, 90, 90, 140, 130, FRAMEWIN_CF_MOVEABLE},
- { EDIT_CreateIndirect, NULL, GUI_ID_EDIT0, 10, 10, 110, 20, 0, 15},
- { EDIT_CreateIndirect, NULL, GUI_ID_EDIT1, 10, 40, 110, 20, 0, 15},
- { BUTTON_CreateIndirect, "Ok", GUI_ID_OK, 10, 80, 50, 20 },
- { BUTTON_CreateIndirect, "Cancel", GUI_ID_CANCEL, 70, 80, 50, 20 },
回调函数:
- static void _cbDialog(WM_MESSAGE * pMsg)
- int i;
- int NCode;
- int Id;
- WM_HWIN hDlg;
- WM_HWIN hItem;
- hDlg = pMsg->hWin;
- switch (pMsg->MsgId)
- case WM_INIT_DIALOG:
- FRAMEWIN_SetFont(pMsg->hWin, &GUI_Font13_ASCII);
- FRAMEWIN_SetTextAlign(pMsg->hWin, GUI_TA_HCENTER);
- for (i = 0; i < 2; i++)
- hItem = WM_GetDialogItem(hDlg, GUI_ID_EDIT0 + i); // Get the handle of the edit widget
- EDIT_AddKey(hItem, GUI_KEY_ADD);
- EDIT_SetText(hItem, "Hello world!"); // Fill widget with text
- EDIT_SetSel(hItem, 0, -1); // Select the whole contents of the edit field
- break;
- case WM_KEY:
- switch (((WM_KEY_INFO*)(pMsg->Data.p))->Key)
- case GUI_KEY_ESCAPE:
- GUI_EndDialog(hDlg, 1);
- break;
- case GUI_KEY_ENTER:
- GUI_EndDialog(hDlg, 0);
- break;
- break;
- case WM_NOTIFY_PARENT:
- Id = WM_GetId(pMsg->hWinSrc); // Id of widget
- NCode = pMsg->Data.v; // Notification code
- switch (NCode)
- case WM_NOTIFICATION_RELEASED: // React only if released
- if (Id == GUI_ID_OK)
- { // OK Button
- if (Id == GUI_ID_CANCEL)
- { // Cancel Button
- break;
- break;
- default:
- WM_DefaultProc(pMsg);
任务循环代码:
按键发送:
- GUI_SendKeyMsg(GUI_KEY_ESCAPE, 1);
补充描述:
发送按键,没有触发回调函数:WM_KEY。 |
