在MINI2440开发板上移植Linux,搞了一个多星期了,一直未成功!
最后使用Linux 2.6.32.63里自带的支持MINI2440的配置来编译,结果
还是出现下面的错误,板的中没有ROOT文件系统,似乎启动过程都没有完成!
这种问题真是无从下手啊!有经验的DD们给点建议吧!
U-Boot 2014.01 (Aug 06 2014 - 10:48:00)
CPUID: 32440001
FCLK: 400 MHz
HCLK: 100 MHz
PCLK: 50 MHz
DRAM: 64 MiB
WARNING: Caches not enabled
Flash: 2 MiB
NAND: 256 MiB
In: serial
Out: serial
Err: serial
Net: dm9000
DREAM2440 # tftpboot 30008000 zImage.img
dm9000 i/o: 0x20000000, id: 0x90000a46
DM9000: running in 16 bit mode
MAC: 00:00:00:00:00:00
Bad MAC address (uninitialized EEPROM?), randomizing
MAC: 3a:03:63:5b:74:86
operating at unknown: 0 mode
Using dm9000 device
TFTP from server 192.168.1.10; our IP address is 192.168.1.11
Filename 'zImage.img'.
Load address: 0x30008000
Loading: T T #############################T T ####################################
77.1 KiB/s
done
Bytes transferred = 2037740 (1f17ec hex)
DREAM2440 # bootm 30008000
## Booting kernel from Legacy Image at 30008000 ...
Image Name: chong
Created: 2014-08-10 2:25:28 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2037676 Bytes = 1.9 MiB
Load Address: 30008000
Entry Point: 30008040
Verifying Checksum ... OK
XIP Kernel Image ... OK
Starting kernel ...
Uncompressing Linux............................................................................................................................... done, booting the kernel.
Linux version 2.6.32.63 (chong@debian) (gcc version 4.8.3 20140320 (prerelease) (Sourcery CodeBench Lite 2014.05-29) ) #2 Sun Aug 10 10:01:14 CST 2014
CPU: ARM920T [41129200] revision 0 (ARMv4T), cr=c0007177
CPU: VIVT data cache, VIVT instruction cache
Machine: MINI2440
Memory policy: ECC disabled, Data cache writeback
CPU S3C2440A (id 0x32440001)
S3C24XX Clocks, (c) 2004 Simtec Electronics
S3C244X: core 400.000 MHz, memory 100.000 MHz, peripheral 50.000 MHz
CLOCK: Slow mode (1.500 MHz), fast, MPLL on, UPLL on
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
Kernel command line: noinitrd console=ttySAC0 initcall_debug=1
PID hash table entries: 256 (order: -2, 1024 bytes)
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 64MB = 64MB total
Memory: 60676KB available (3548K code, 417K data, 128K init, 0K highmem)
SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Hierarchical RCU implementation.
NR_IRQS:85
irq: clearing subpending status 00000003
irq: clearing subpending status 00000002
Console: colour dummy device 80x30
console [ttySAC0] enabled
Calibrating delay loop... 199.47 BogoMIPS (lpj=498688)
CPU: Testing write buffer coherency: ok
calling spawn_ksoftirqd+0x0/0x50 @ 1
initcall spawn_ksoftirqd+0x0/0x50 returned 0 after 499 usecs
calling spawn_softlockup_task+0x0/0x70 @ 1
initcall spawn_softlockup_task+0x0/0x70 returned 0 after 476 usecs
calling relay_init+0x0/0x8 @ 1
initcall relay_init+0x0/0x8 returned 0 after 8 usecs
calling init_mmap_min_addr+0x0/0x20 @ 1
initcall init_mmap_min_addr+0x0/0x20 returned 0 after 12 usecs
calling net_ns_init+0x0/0x118 @ 1
initcall net_ns_init+0x0/0x118 returned 0 after 22 usecs
calling ptrace_break_init+0x0/0x24 @ 1
initcall ptrace_break_init+0x0/0x24 returned 0 after 12 usecs
calling consistent_init+0x0/0xb8 @ 1
initcall consistent_init+0x0/0xb8 returned 0 after 81 usecs
calling s3c24xx_gpiolib_init+0x0/0x30 @ 1
initcall s3c24xx_gpiolib_init+0x0/0x30 returned 0 after 73 usecs
calling s3c2442_core_init+0x0/0xc @ 1
initcall s3c2442_core_init+0x0/0xc returned 0 after 1183 usecs
calling s3c2440_core_init+0x0/0xc @ 1
initcall s3c2440_core_init+0x0/0xc returned 0 after 1214 usecs
calling s3c24xx_dma_sysclass_init+0x0/0x28 @ 1
initcall s3c24xx_dma_sysclass_init+0x0/0x28 returned 0 after 1209 usecs
calling sysctl_init+0x0/0x3c @ 1
initcall sysctl_init+0x0/0x3c returned 0 after 977 usecs
calling ksysfs_init+0x0/0xa0 @ 1
initcall ksysfs_init+0x0/0xa0 returned 0 after 186 usecs
calling async_init+0x0/0x60 @ 1
initcall async_init+0x0/0x60 returned 0 after 516 usecs
calling init_jiffies_clocksource+0x0/0xc @ 1
initcall init_jiffies_clocksource+0x0/0xc returned 0 after 19 usecs
calling pm_init+0x0/0x3c @ 1
initcall pm_init+0x0/0x3c returned 0 after 151 usecs
calling init_zero_pfn+0x0/0x30 @ 1
initcall init_zero_pfn+0x0/0x30 returned 0 after 11 usecs
calling filelock_init+0x0/0x40 @ 1
initcall filelock_init+0x0/0x40 returned 0 after 60 usecs
calling init_script_binfmt+0x0/0x10 @ 1
initcall init_script_binfmt+0x0/0x10 returned 0 after 13 usecs
calling init_elf_binfmt+0x0/0x10 @ 1
initcall init_elf_binfmt+0x0/0x10 returned 0 after 10 usecs
calling debugfs_init+0x0/0x60 @ 1
initcall debugfs_init+0x0/0x60 returned 0 after 129 usecs
calling random32_init+0x0/0x78 @ 1
initcall random32_init+0x0/0x78 returned 0 after 15 usecs
calling cpuidle_init+0x0/0x24 @ 1
initcall cpuidle_init+0x0/0x24 returned 0 after 107 usecs
calling sock_init+0x0/0x70 @ 1
initcall sock_init+0x0/0x70 returned 0 after 699 usecs
calling netlink_proto_init+0x0/0x1ec @ 1
initcall netlink_proto_init+0x0/0x1ec returned 0 after 3234 usecs
calling bdi_class_init+0x0/0x4c @ 1
initcall bdi_class_init+0x0/0x4c returned 0 after 1515 usecs
calling kobject_uevent_init+0x0/0x68 @ 1
initcall kobject_uevent_init+0x0/0x68 returned 0 after 106 usecs
calling gpiolib_sysfs_init+0x0/0x88 @ 1
initcall gpiolib_sysfs_init+0x0/0x88 returned 0 after 13899 usecs
calling lcd_class_init+0x0/0x58 @ 1
initcall lcd_class_init+0x0/0x58 returned 0 after 1241 usecs
calling backlight_class_init+0x0/0x70 @ 1
initcall backlight_class_init+0x0/0x70 returned 0 after 1276 usecs
calling video_output_class_init+0x0/0x14 @ 1
initcall video_output_class_init+0x0/0x14 returned 0 after 1266 usecs
calling tty_class_init+0x0/0x3c @ 1
initcall tty_class_init+0x0/0x3c returned 0 after 1267 usecs
calling vtconsole_class_init+0x0/0xd8 @ 1
initcall vtconsole_class_init+0x0/0xd8 returned 0 after 2739 usecs
calling spi_init+0x0/0x8c @ 1
initcall spi_init+0x0/0x8c returned 0 after 2619 usecs
calling i2c_init+0x0/0x70 @ 1
initcall i2c_init+0x0/0x70 returned 0 after 2964 usecs
calling customize_machine+0x0/0x24 @ 1
MINI2440: Option string mini2440=0tb
MINI2440: 't' ignored, touchscreen not compiled in
MINI2440: LCD [0:240x320] 1:800x480 2:1024x768
initcall customize_machine+0x0/0x24 returned 0 after 38046 usecs
calling init_atags_procfs+0x0/0xf8 @ 1
initcall init_atags_procfs+0x0/0xf8 returned 0 after 107 usecs
calling s3c2440_pm_drvinit+0x0/0x14 @ 1
initcall s3c2440_pm_drvinit+0x0/0x14 returned 0 after 22 usecs
calling s3c2440_irq_init+0x0/0x14 @ 1
initcall s3c2440_irq_init+0x0/0x14 returned 0 after 13 usecs
calling s3c24xx_clk_driver+0x0/0x14 @ 1
initcall s3c24xx_clk_driver+0x0/0x14 returned 0 after 14 usecs
calling s3c2440_dma_init+0x0/0x14 @ 1
initcall s3c2440_dma_init+0x0/0x14 returned 0 after 13 usecs
calling s3c2442_irq_init+0x0/0x14 @ 1
initcall s3c2442_irq_init+0x0/0x14 returned 0 after 16 usecs
calling s3c2442_clk_init+0x0/0x14 @ 1
initcall s3c2442_clk_init+0x0/0x14 returned 0 after 14 usecs
calling s3c2440_clk_init+0x0/0x14 @ 1
initcall s3c2440_clk_init+0x0/0x14 returned 0 after 12 usecs
calling adc_init+0x0/0x30 @ 1
initcall adc_init+0x0/0x30 returned 0 after 1588 usecs
calling s3c_arch_init+0x0/0x4c @ 1
S3C2440: Initialising architecture
S3C2440: IRQ Support
S3C24XX DMA Driver, (c) 2003-2004,2006 Simtec Electronics
DMA channel 0 at c4808000, irq 33
DMA channel 1 at c4808040, irq 34
DMA channel 2 at c4808080, irq 35
DMA channel 3 at c48080c0, irq 36
S3C244X: Clock Support, DVS off
initcall s3c_arch_init+0x0/0x4c returned 0 after 30498 usecs
calling pwm_init+0x0/0x8c @ 1
initcall pwm_init+0x0/0x8c returned 0 after 1425 usecs
calling topology_init+0x0/0x24 @ 1
initcall topology_init+0x0/0x24 returned 0 after 1607 usecs
calling param_sysfs_init+0x0/0x208 @ 1
initcall param_sysfs_init+0x0/0x208 returned 0 after 101797 usecs
calling default_bdi_init+0x0/0xb4 @ 1
initcall default_bdi_init+0x0/0xb4 returned 0 after 2719 usecs
calling init_bio+0x0/0xf4 @ 1
bio: create slab <bio-0> at 0
initcall init_bio+0x0/0xf4 returned 0 after 2723 usecs
calling fsnotify_init+0x0/0xc @ 1
initcall fsnotify_init+0x0/0xc returned 0 after 19 usecs
calling fsnotify_notification_init+0x0/0xa4 @ 1
initcall fsnotify_notification_init+0x0/0xa4 returned 0 after 98 usecs
calling cryptomgr_init+0x0/0xc @ 1
initcall cryptomgr_init+0x0/0xc returned 0 after 16 usecs
calling blk_settings_init+0x0/0x38 @ 1
initcall blk_settings_init+0x0/0x38 returned 0 after 9 usecs
calling blk_ioc_init+0x0/0x3c @ 1
initcall blk_ioc_init+0x0/0x3c returned 0 after 43 usecs
calling blk_softirq_init+0x0/0x2c @ 1
initcall blk_softirq_init+0x0/0x2c returned 0 after 12 usecs
calling blk_iopoll_setup+0x0/0x2c @ 1
initcall blk_iopoll_setup+0x0/0x2c returned 0 after 9 usecs
calling genhd_device_init+0x0/0x80 @ 1
initcall genhd_device_init+0x0/0x80 returned 0 after 2124 usecs
calling blk_dev_integrity_init+0x0/0x3c @ 1
initcall blk_dev_integrity_init+0x0/0x3c returned 0 after 60 usecs
calling gpiolib_debugfs_init+0x0/0x38 @ 1
initcall gpiolib_debugfs_init+0x0/0x38 returned 0 after 115 usecs
calling fbmem_init+0x0/0xa8 @ 1
initcall fbmem_init+0x0/0xa8 returned 0 after 1566 usecs
calling misc_init+0x0/0xbc @ 1
initcall misc_init+0x0/0xbc returned 0 after 1418 usecs
calling usb_init+0x0/0x1ac @ 1
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
initcall usb_init+0x0/0x1ac returned 0 after 11480 usecs
calling serio_init+0x0/0x88 @ 1
initcall serio_init+0x0/0x88 returned 0 after 1894 usecs
calling input_init+0x0/0x150 @ 1
initcall input_init+0x0/0x150 returned 0 after 1646 usecs
calling rtc_init+0x0/0x74 @ 1
initcall rtc_init+0x0/0x74 returned 0 after 1351 usecs
calling i2c_adap_s3c_init+0x0/0xc @ 1
s3c-i2c s3c2440-i2c: slave address 0x10
s3c-i2c s3c2440-i2c: bus frequency set to 97 KHz
s3c-i2c s3c2440-i2c: i2c-0: S3C I2C adapter
initcall i2c_adap_s3c_init+0x0/0xc returned 0 after 12797 usecs
calling hwmon_init+0x0/0x48 @ 1
initcall hwmon_init+0x0/0x48 returned 0 after 1413 usecs
calling mmc_init+0x0/0x88 @ 1
initcall mmc_init+0x0/0x88 returned 0 after 4942 usecs
calling leds_init+0x0/0x48 @ 1
initcall leds_init+0x0/0x48 returned 0 after 1338 usecs
calling proto_init+0x0/0xc @ 1
initcall proto_init+0x0/0xc returned 0 after 97 usecs
calling net_dev_init+0x0/0x134 @ 1
initcall net_dev_init+0x0/0x134 returned 0 after 3501 usecs
calling neigh_init+0x0/0x84 @ 1
initcall neigh_init+0x0/0x84 returned 0 after 20 usecs
calling fib_rules_init+0x0/0xb0 @ 1
initcall fib_rules_init+0x0/0xb0 returned 0 after 33 usecs
calling genl_init+0x0/0x98 @ 1
initcall genl_init+0x0/0x98 returned 0 after 235 usecs
calling wireless_nlevent_init+0x0/0xc @ 1
initcall wireless_nlevent_init+0x0/0xc returned 0 after 15 usecs
calling sysctl_init+0x0/0x4c @ 1
initcall sysctl_init+0x0/0x4c returned 0 after 18 usecs
calling alignment_init+0x0/0xdc @ 1
initcall alignment_init+0x0/0xdc returned 0 after 118 usecs
calling clocksource_done_booting+0x0/0x4c @ 1
initcall clocksource_done_booting+0x0/0x4c returned 0 after 12 usecs
calling init_pipe_fs+0x0/0x48 @ 1
initcall init_pipe_fs+0x0/0x48 returned 0 after 176 usecs
calling eventpoll_init+0x0/0xb0 @ 1
initcall eventpoll_init+0x0/0xb0 returned 0 after 150 usecs
calling anon_inode_init+0x0/0x110 @ 1
initcall anon_inode_init+0x0/0x110 returned 0 after 172 usecs
calling blk_scsi_ioctl_init+0x0/0xdc @ 1
initcall blk_scsi_ioctl_init+0x0/0xdc returned 0 after 13 usecs
calling chr_dev_init+0x0/0xc0 @ 1
initcall chr_dev_init+0x0/0xc0 returned 0 after 14177 usecs
calling firmware_class_init+0x0/0x6c @ 1
initcall firmware_class_init+0x0/0x6c returned 0 after 1416 usecs
calling sysctl_core_init+0x0/0x38 @ 1
initcall sysctl_core_init+0x0/0x38 returned 0 after 241 usecs
calling inet_init+0x0/0x1e8 @ 1
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
initcall inet_init+0x0/0x1e8 returned 0 after 26296 usecs
calling af_unix_init+0x0/0x54 @ 1
initcall af_unix_init+0x0/0x54 returned 0 after 3287 usecs
calling init_sunrpc+0x0/0x58 @ 1
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
initcall init_sunrpc+0x0/0x58 returned 0 after 11690 usecs
calling populate_rootfs+0x0/0x224 @ 1
initcall populate_rootfs+0x0/0x224 returned 0 after 821 usecs
calling timer_init_sysfs+0x0/0x34 @ 1
initcall timer_init_sysfs+0x0/0x34 returned 0 after 2723 usecs
calling proc_execdomains_init+0x0/0x34 @ 1
initcall proc_execdomains_init+0x0/0x34 returned 0 after 102 usecs
calling ioresources_init+0x0/0x54 @ 1
initcall ioresources_init+0x0/0x54 returned 0 after 81 usecs
calling uid_cache_init+0x0/0xa4 @ 1
initcall uid_cache_init+0x0/0xa4 returned 0 after 110 usecs
calling init_posix_timers+0x0/0x16c @ 1
initcall init_posix_timers+0x0/0x16c returned 0 after 96 usecs
calling init_posix_cpu_timers+0x0/0xfc @ 1
initcall init_posix_cpu_timers+0x0/0xfc returned 0 after 20 usecs
calling nsproxy_cache_init+0x0/0x3c @ 1
initcall nsproxy_cache_init+0x0/0x3c returned 0 after 89 usecs
calling timekeeping_init_device+0x0/0x28 @ 1
initcall timekeeping_init_device+0x0/0x28 returned 0 after 2724 usecs
calling init_clocksource_sysfs+0x0/0x50 @ 1
initcall init_clocksource_sysfs+0x0/0x50 returned 0 after 2876 usecs
calling init_timer_list_procfs+0x0/0x38 @ 1
initcall init_timer_list_procfs+0x0/0x38 returned 0 after 206 usecs
calling futex_init+0x0/0x6c @ 1
initcall futex_init+0x0/0x6c returned 0 after 57 usecs
calling proc_modules_init+0x0/0x34 @ 1
initcall proc_modules_init+0x0/0x34 returned 0 after 73 usecs
calling kallsyms_init+0x0/0x34 @ 1
initcall kallsyms_init+0x0/0x34 returned 0 after 73 usecs
calling crash_save_vmcoreinfo_init+0x0/0x3b4 @ 1
initcall crash_save_vmcoreinfo_init+0x0/0x3b4 returned 0 after 235 usecs
calling crash_notes_memory_init+0x0/0x50 @ 1
initcall crash_notes_memory_init+0x0/0x50 returned 0 after 15 usecs
calling hung_task_init+0x0/0x50 @ 1
initcall hung_task_init+0x0/0x50 returned 0 after 595 usecs
calling utsname_sysctl_init+0x0/0x18 @ 1
initcall utsname_sysctl_init+0x0/0x18 returned 0 after 249 usecs
calling init_per_zone_wmark_min+0x0/0x68 @ 1
initcall init_per_zone_wmark_min+0x0/0x68 returned 0 after 606 usecs
calling kswapd_init+0x0/0x18 @ 1
initcall kswapd_init+0x0/0x18 returned 0 after 595 usecs
calling setup_vmstat+0x0/0x8c @ 1
initcall setup_vmstat+0x0/0x8c returned 0 after 148 usecs
calling mm_sysfs_init+0x0/0x38 @ 1
initcall mm_sysfs_init+0x0/0x38 returned 0 after 128 usecs
calling proc_vmalloc_init+0x0/0x34 @ 1
initcall proc_vmalloc_init+0x0/0x34 returned 0 after 71 usecs
calling procswaps_init+0x0/0x34 @ 1
initcall procswaps_init+0x0/0x34 returned 0 after 72 usecs
calling slab_proc_init+0x0/0x34 @ 1
initcall slab_proc_init+0x0/0x34 returned 0 after 72 usecs
calling slab_sysfs_init+0x0/0xec @ 1
initcall slab_sysfs_init+0x0/0xec returned 0 after 91457 usecs
calling fasync_init+0x0/0x3c @ 1
initcall fasync_init+0x0/0x3c returned 0 after 358 usecs
calling proc_filesystems_init+0x0/0x34 @ 1
initcall proc_filesystems_init+0x0/0x34 returned 0 after 118 usecs
calling dnotify_init+0x0/0x84 @ 1
initcall dnotify_init+0x0/0x84 returned 0 after 385 usecs
calling inotify_setup+0x0/0x14 @ 1
initcall inotify_setup+0x0/0x14 returned 0 after 9 usecs
calling inotify_user_setup+0x0/0xb8 @ 1
initcall inotify_user_setup+0x0/0xb8 returned 0 after 511 usecs
calling aio_setup+0x0/0x80 @ 1
initcall aio_setup+0x0/0x80 returned 0 after 916 usecs
calling proc_locks_init+0x0/0x34 @ 1
initcall proc_locks_init+0x0/0x34 returned 0 after 128 usecs
calling init_mbcache+0x0/0x18 @ 1
initcall init_mbcache+0x0/0x18 returned 0 after 18 usecs
calling proc_cmdline_init+0x0/0x34 @ 1
initcall proc_cmdline_init+0x0/0x34 returned 0 after 71 usecs
calling proc_cpuinfo_init+0x0/0x34 @ 1
initcall proc_cpuinfo_init+0x0/0x34 returned 0 after 71 usecs
calling proc_devices_init+0x0/0x34 @ 1
initcall proc_devices_init+0x0/0x34 returned 0 after 73 usecs
calling proc_interrupts_init+0x0/0x34 @ 1
initcall proc_interrupts_init+0x0/0x34 returned 0 after 70 usecs
calling proc_loadavg_init+0x0/0x34 @ 1
initcall proc_loadavg_init+0x0/0x34 returned 0 after 71 usecs
calling proc_meminfo_init+0x0/0x34 @ 1
initcall proc_meminfo_init+0x0/0x34 returned 0 after 72 usecs
calling proc_stat_init+0x0/0x34 @ 1
initcall proc_stat_init+0x0/0x34 returned 0 after 70 usecs
calling proc_uptime_init+0x0/0x34 @ 1
initcall proc_uptime_init+0x0/0x34 returned 0 after 81 usecs
calling proc_version_init+0x0/0x34 @ 1
initcall proc_version_init+0x0/0x34 returned 0 after 73 usecs
calling proc_softirqs_init+0x0/0x34 @ 1
initcall proc_softirqs_init+0x0/0x34 returned 0 after 81 usecs
calling proc_kmsg_init+0x0/0x34 @ 1
initcall proc_kmsg_init+0x0/0x34 returned 0 after 80 usecs
calling proc_page_init+0x0/0x54 @ 1
initcall proc_page_init+0x0/0x54 returned 0 after 91 usecs
calling init_devpts_fs+0x0/0x48 @ 1
initcall init_devpts_fs+0x0/0x48 returned 0 after 193 usecs
calling init_ext3_fs+0x0/0x80 @ 1
initcall init_ext3_fs+0x0/0x80 returned 0 after 4105 usecs
calling journal_init+0x0/0xbc @ 1
initcall journal_init+0x0/0xbc returned 0 after 6853 usecs
calling init_cramfs_fs+0x0/0x2c @ 1
initcall init_cramfs_fs+0x0/0x2c returned 0 after 223 usecs
calling init_ramfs_fs+0x0/0xc @ 1
initcall init_ramfs_fs+0x0/0xc returned 0 after 14 usecs
calling init_fat_fs+0x0/0x60 @ 1
initcall init_fat_fs+0x0/0x60 returned 0 after 4065 usecs
calling init_vfat_fs+0x0/0xc @ 1
initcall init_vfat_fs+0x0/0xc returned 0 after 39 usecs
calling init_msdos_fs+0x0/0xc @ 1
initcall init_msdos_fs+0x0/0xc returned 0 after 13 usecs
calling init_nfs_fs+0x0/0x134 @ 1
initcall init_nfs_fs+0x0/0x134 returned 0 after 9180 usecs
calling init_nlm+0x0/0x2c @ 1
initcall init_nlm+0x0/0x2c returned 0 after 251 usecs
calling init_jffs2_fs+0x0/0xd4 @ 1
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
initcall init_jffs2_fs+0x0/0xd4 returned 0 after 10710 usecs
calling init_romfs_fs+0x0/0x90 @ 1
ROMFS MTD (C) 2007 Red Hat, Inc.
initcall init_romfs_fs+0x0/0x90 returned 0 after 4558 usecs
calling init_autofs_fs+0x0/0xc @ 1
initcall init_autofs_fs+0x0/0xc returned 0 after 26 usecs
calling init_autofs4_fs+0x0/0x20 @ 1
initcall init_autofs4_fs+0x0/0x20 returned -16 after 18 usecs
initcall init_autofs4_fs+0x0/0x20 returned with error code -16
calling ipc_init+0x0/0x24 @ 1
msgmni has been set to 118
initcall ipc_init+0x0/0x24 returned 0 after 2369 usecs
calling ipc_sysctl_init+0x0/0x18 @ 1
initcall ipc_sysctl_init+0x0/0x18 returned 0 after 362 usecs
calling init_mqueue_fs+0x0/0xb0 @ 1
initcall init_mqueue_fs+0x0/0xb0 returned 0 after 2430 usecs
calling key_proc_init+0x0/0x44 @ 1
initcall key_proc_init+0x0/0x44 returned 0 after 140 usecs
calling crypto_wq_init+0x0/0x44 @ 1
initcall crypto_wq_init+0x0/0x44 returned 0 after 558 usecs
calling crypto_algapi_init+0x0/0x10 @ 1
initcall crypto_algapi_init+0x0/0x10 returned 0 after 302 usecs
calling skcipher_module_init+0x0/0x1c @ 1
initcall skcipher_module_init+0x0/0x1c returned 0 after 10 usecs
calling chainiv_module_init+0x0/0xc @ 1
initcall chainiv_module_init+0x0/0xc returned 0 after 27 usecs
calling eseqiv_module_init+0x0/0xc @ 1
initcall eseqiv_module_init+0x0/0xc returned 0 after 23 usecs
calling hmac_module_init+0x0/0xc @ 1
initcall hmac_module_init+0x0/0xc returned 0 after 27 usecs
calling md5_mod_init+0x0/0xc @ 1
initcall md5_mod_init+0x0/0xc returned 0 after 1272 usecs
calling crypto_ecb_module_init+0x0/0xc @ 1
initcall crypto_ecb_module_init+0x0/0xc returned 0 after 31 usecs
calling crypto_cbc_module_init+0x0/0xc @ 1
initcall crypto_cbc_module_init+0x0/0xc returned 0 after 20 usecs
calling des_generic_mod_init+0x0/0x38 @ 1
initcall des_generic_mod_init+0x0/0x38 returned 0 after 2999 usecs
calling aes_init+0x0/0xc @ 1
initcall aes_init+0x0/0xc returned 0 after 1662 usecs
calling arc4_init+0x0/0xc @ 1
initcall arc4_init+0x0/0xc returned 0 after 1341 usecs
calling michael_mic_init+0x0/0xc @ 1
initcall michael_mic_init+0x0/0xc returned 0 after 1142 usecs
calling krng_mod_init+0x0/0xc @ 1
alg: No test for stdrng (krng)
initcall krng_mod_init+0x0/0xc returned 0 after 3132 usecs
calling proc_genhd_init+0x0/0x54 @ 1
initcall proc_genhd_init+0x0/0x54 returned 0 after 166 usecs
calling noop_init+0x0/0x18 @ 1
io scheduler noop registered
initcall noop_init+0x0/0x18 returned 0 after 2482 usecs
calling as_init+0x0/0x18 @ 1
io scheduler anticipatory registered (default)
initcall as_init+0x0/0x18 returned 0 after 4026 usecs
calling deadline_init+0x0/0x18 @ 1
io scheduler deadline registered
initcall deadline_init+0x0/0x18 returned 0 after 2894 usecs
calling cfq_init+0x0/0xac @ 1
io scheduler cfq registered
initcall cfq_init+0x0/0xac returned 0 after 2681 usecs
calling fb_console_init+0x0/0x154 @ 1
initcall fb_console_init+0x0/0x154 returned 0 after 1583 usecs
calling platform_lcd_init+0x0/0xc @ 1
initcall platform_lcd_init+0x0/0xc returned 0 after 1566 usecs
calling pwm_backlight_init+0x0/0xc @ 1
initcall pwm_backlight_init+0x0/0xc returned 0 after 1696 usecs
calling display_class_init+0x0/0x88 @ 1
initcall display_class_init+0x0/0x88 returned 0 after 1339 usecs
calling rand_initialize+0x0/0x2c @ 1
initcall rand_initialize+0x0/0x2c returned 0 after 204 usecs
calling tty_init+0x0/0x104 @ 1
Unable to handle kernel paging request at virtual address 30c39280
pgd = c0004000
[30c39280] *pgd=00000000
Internal error: Oops: 5 [#1]
last sysfs file:
Modules linked in:
CPU: 0 Not tainted (2.6.32.63 #2)
PC is at kmem_cache_alloc+0x30/0x88
LR is at con_insert_unipair+0x34/0xdc
pc : [<c008715c>] lr : [<c019bd4c>] psr: 20000093
sp : c3823f00 ip : 0000005f fp : 00000003
r10: c0417c34 r9 : c03d3644 r8 : 00000001
r7 : 000000d0 r6 : 00000080 r5 : a0000013 r4 : 30c39280
r3 : 00000000 r2 : a0000093 r1 : 000000d0 r0 : c03bc40c
Flags: nzCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment kernel
Control: c000717f Table: 30004000 DAC: 00000017
Process swapper (pid: 1, stack limit = 0xc3822270)
Stack: (0xc3823f00 to 0xc3824000)
3f00: c03bc40c 000000d0 0000005f 0000f804 c3929600 0000005f 0000001f c019bd4c
3f20: c03d364a c3801000 c3929600 0000005f 00000000 c019c940 0000005f c03d364a
3f40: 00000014 00000000 00000014 c0418010 c00187b4 00000000 c3822030 00000000
3f60: 00000000 c0018f48 00000000 00000000 c0417d34 c00193b8 c036a2b4 c016b278
3f80: 20000013 c04178a0 00000000 c03e34c0 c00187b4 c0018884 c03477cf 00000002
3fa0: 00a10e78 00a10e78 00000002 c002837c 000000cc 00000000 00a10e78 00000002
3fc0: 00000054 c00219dc c0021b9c 00000000 00000000 00000000 00000000 c00089b0
3fe0: 00000000 00000000 c000890c 00000000 00000000 c00296f4 ffffffff ffffffff
[<c008715c>] (kmem_cache_alloc+0x30/0x88) from [<c019bd4c>] (con_insert_unipair+0x34/0xdc)
[<c019bd4c>] (con_insert_unipair+0x34/0xdc) from [<c019c940>] (con_set_default_unimap+0xc4/0x14c)
[<c019c940>] (con_set_default_unimap+0xc4/0x14c) from [<c0018f48>] (console_map_init+0x38/0x4c)
[<c0018f48>] (console_map_init+0x38/0x4c) from [<c00193b8>] (vty_init+0x120/0x15c)
[<c00193b8>] (vty_init+0x120/0x15c) from [<c0018884>] (tty_init+0xd0/0x104)
[<c0018884>] (tty_init+0xd0/0x104) from [<c002837c>] (do_one_initcall+0x5c/0x190)
[<c002837c>] (do_one_initcall+0x5c/0x190) from [<c00089b0>] (kernel_init+0xa4/0x110)
[<c00089b0>] (kernel_init+0xa4/0x110) from [<c00296f4>] (kernel_thread_exit+0x0/0x8)
Code: e5904080 e5906090 e3540000 1590308c (17943103)
---[ end trace e06eb57aa385dd0b ]---
Kernel panic - not syncing: Attempted to kill init!
[<c002d598>] (unwind_backtrace+0x0/0xcc) from [<c02c2f48>] (panic+0x3c/0x110)
[<c02c2f48>] (panic+0x3c/0x110) from [<c003d534>] (do_exit+0x60/0x5b8)
[<c003d534>] (do_exit+0x60/0x5b8) from [<c002c39c>] (die+0x150/0x174)
[<c002c39c>] (die+0x150/0x174) from [<c02c2e5c>] (__do_kernel_fault.part.3+0x54/0x64)
[<c02c2e5c>] (__do_kernel_fault.part.3+0x54/0x64) from [<c002e558>] (do_page_fault+0x1c4/0x1dc)
[<c002e558>] (do_page_fault+0x1c4/0x1dc) from [<c0028220>] (do_DataAbort+0x34/0x98)
[<c0028220>] (do_DataAbort+0x34/0x98) from [<c00288e0>] (__dabt_svc+0x40/0x60)
Exception stack(0xc3823eb8 to 0xc3823f00)
3ea0: c03bc40c 000000d0
3ec0: a0000093 00000000 30c39280 a0000013 00000080 000000d0 00000001 c03d3644
3ee0: c0417c34 00000003 0000005f c3823f00 c019bd4c c008715c 20000093 ffffffff
[<c00288e0>] (__dabt_svc+0x40/0x60) from [<c008715c>] (kmem_cache_alloc+0x30/0x88)
