一样的TEA加密代码,C51和STM32结果不一样?
测试了论坛里的一个TEA加密代码,在51和STM32里编译仿真,加密解密都正常,但是加密结果不一样,郁闷,这么说51加密的STM32解不了?
代码如下:
- #include"at89x51.h"
- #define MX (z>>5^y<<2)+(y>>3^z<<4)^(sum^y)+(k[p&3^e]^z)
- #define DELTA 0x9e3779b9
- #define S_LOOPTIME 32 //5
- #define BLOCK_SIZE 64 //PAGE_SIZE,根据你所要加密的数据包长度修改此参数(单位:字节)
- *key maybe 128bit =16 Bytes.
- *buf maybe BLOCK_SIZE
- void btea_encrypt( unsigned char* buf, unsigned char* key )
- unsigned char n=BLOCK_SIZE/4;
- unsigned long *v=(unsigned long *)buf;
- unsigned long *k=(unsigned long *)key;
- unsigned long z = v[n - 1],y = v[0],sum = 0,e ;
- unsigned char p,q ;
- // Coding Part
- q = S_LOOPTIME + 52 / n ;
- while ( q-- > 0 )
- sum += DELTA ;
- e = sum >> 2 & 3 ;
- for ( p = 0 ; p < n - 1 ; p++ )
- y = v[p + 1],
- z = v[p] += MX;
- y = v[0] ;
- z = v[n - 1] += MX;
- *key maybe 128bit =16Bytes.
- inbuf == outbuf == buf
- //TEA密钥
- unsigned char TEA_key[16]=
- 0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,
- 0x09,0x0A,0x0B,0x0C,0x0D,0x0E,0x0F,0x10
- //数据缓冲区
- unsigned char xdata TX_buffer[64]={0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,60,61,62,63};
- unsigned char xdata RX_buffer[64];
- void btea_decrpyt( unsigned char* buf, unsigned char* key )
- //Decoding Part...
- sum = q * DELTA ;
- while ( sum != 0 )
- for ( p = n - 1 ; p > 0 ; p-- )
- z = v[p - 1],
- y = v[p] -= MX;
- z = v[n - 1] ;
- y = v[0] -= MX;
- sum -= DELTA ;
- void main(void)
- while(1)
- btea_encrypt(TX_buffer,TEA_key);
- btea_decrpyt(TX_buffer,TEA_key);
C51结果
STM32结果 |
