发表于 2014-10-9 19:36:26
* @brief Set compass sampling rate.
* The compass on the auxiliary I2C bus is read by the MPU hardware at a
* maximum of 100Hz. The actual rate can be set to a fraction of the gyro
* sampling rate.
* \n WARNING: The new rate may be different than what was requested. Call
* mpu_get_compass_sample_rate to check the actual setting.
* @param[in] rate Desired compass sampling rate (Hz).
* @return 0 if successful.
int mpu_set_compass_sample_rate(unsigned short rate)
#ifdef AK89xx_SECONDARY
unsigned char div;
if (!rate || rate > st.chip_cfg.sample_rate || rate > MAX_COMPASS_SAMPLE_RATE)
return -1;
div = st.chip_cfg.sample_rate / rate - 1;
if (i2c_write(st.hw->addr, st.reg->s4_ctrl, 1, &div))
return -1;
st.chip_cfg.compass_sample_rate = st.chip_cfg.sample_rate / (div + 1);
return 0;
#else
return -1;
我看invensense 提供的eMPL里面,用上面的代码配置了AK8975的采样频率,实际上是控制mpu6050辅助I2C总线对AK8975的读写周期。依旧没有搞明白到底是怎样配置AK8975的采样频率的。 |
