编译器使用:arm-linux-gnueabihf
测试目标板:http://www.oschina.net/p/pcduino
USB-CAN适配器:www.viewtool.com
Makefile的编写:
- # Instructions to the compiler and options
- CC = arm-linux-gnueabihf-g++
- RM = rm
- CFLAGS = -Wall -march=armv7-a -mtune=cortex-a8 -fexceptions
- # Macro definition
- DEFS = -D OS_UNIX
- CFLAGS += $(DEFS)
- # The target file
- TARGET = USB_CAN_Test
- # The source file
- SRCS = USB_CAN_Test.cpp
- # The header file search path
- INC = -I./
- # Dependent libraries,Select library file According to the operating system you using
- LIBS += -L./lib/arm_linux -lGinkgo_Driver -lusb
- LIBS += -L./usr/arm-linux-gnueabihf/lib -lpthread
- # The target file
- OBJS = $(SRCS:.cpp=.o)
- # Link for the executable file
- $(TARGET):$(OBJS)
- $(CC) -o $@ $^ $(LIBS)
- clean:
- $(RM) -rf $(TARGET) $(OBJS) *~
- %.o:%.cpp
- $(CC) $(CFLAGS) $(INC) -o $@ -c $<
通过make命令编译程序,最后编译出一个USB_CAN_Test执行文件,将libGinkgo_Driver.so库和改执行文件放到Release目录下,同时在该目录建立一个runme.sh的脚本用来启动这个可执行程序(用脚本主要是为了更改LD_LIBRARY_PATH环境变量,让程序找到它所调用的库),其runme.sh内容为:
- #!/bin/sh
- echo $PWD
- export LD_LIBRARY_PATH="$PWD/lib/arm_linux:$LD_LIBRARY_PATH"
- echo $LD_LIBRARY_PATH
- ./USB_CAN_Test
最后通过执行 sudo ./runme.sh即可启动程序。
程序源码及Makefile下载:
