发表于 2015-3-10 11:00:28
有些交叉编译器在制作时限制了使用的最低内核版本,不要比这个版本低就可以了。
root@ubuntu:~/Downloads/linux-2.6.30.4# file /opt/FriendlyARM/4.4.3/arm-none-linux-gnueabi/lib/libc-2.9.so
/opt/FriendlyARM/4.4.3/arm-none-linux-gnueabi/lib/libc-2.9.so: ELF 32-bit LSB shared object, ARM, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.32, not stripped
file /opt/EmbedSky/4.3.3/arm-none-linux-gnueabi/libc/armv4t/usr/lib/libc-2.8.so
/opt/EmbedSky/4.3.3/arm-none-linux-gnueabi/libc/armv4t/usr/lib/libc-2.8.so: ELF 32-bit LSB shared object, ARM, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.14, not stripped
