MSP430F149驱动ST7529 160160液晶
File Name:HG16016005T.C;
Description:This Resouce Is For Dot Matrix Liquid Crystal
Modules Controlled By Sitronix'S ST7529
LCM Interface Dimenision:
1 2 3 4 5 6 7 8 9 10
VSS RS R/W E /CS /RST VDD D0 D1 D2
11 12 13 14 15 16 17 18
D3 D4 D5 D6 D7 K NC A
Author By:Dangzhen
Date:2009-05-07
#include <msp430x14x.h>
#define DataPort P1OUT //数据口 P1
#define led1_on() P4OUT|=BIT7 //P47 LED+ A VDD3.3V
#define led1_off() P4OUT^=BIT7
#define lcm_on P4OUT|=BIT5 //背光控制 P45 LED- K
#define lcm_off P4OUT^=BIT5
#define LCD_RS1 P4OUT|=BIT0 //RS 0:指令 1:数据 P40
#define LCD_RS0 P4OUT&=~BIT0
#define LCD_RST1 P4OUT|=BIT4 //RESET P44
#define LCD_RST0 P4OUT&=~BIT4
#define LCD_WR1 P4OUT|=BIT1 //WR P41
#define LCD_WR0 P4OUT&=~BIT1
#define LCD_RD1 P4OUT|=BIT2 //RD P42
#define LCD_RD0 P4OUT=~BIT2
#define LCD_CS1 P4OUT|=BIT3 //CS P43
#define LCD_CS0 P4OUT&=~BIT3
#define VOLCTRL 0x81 / *EC控制 2字节参数 D0~D5,D6~D8*/
#define VOLUP 0xD6 /* EC减一 */
#define VOLDOWN 0xD7 /* EC加一 */
#define uint unsigned int
#define TRUE 1
#define FALSE 0
#define DELAYMS 200
***************************函数定义*************************/
const uchar HTDISPLAY[];
void delay();
void delayms();
void delay10ms(int count);
void wr_cmd(uchar cmd);
void wr_dat(uchar dat);
void ST7529Ini(void);
void HDT_DisplayOff();
void HDT_DisplayOn();
void InitSys();
void disp_dots(uchar dat1,uchar dat2);
void disp_bmpp( const uchar *myziku);
void LcdSetAddr16_16(uchar x1, uchar y1, const uchar *ziku);
void dsiplay16_16(uchar x,uchar y);
const uchar MYNUMBER[];
void LcdSetAddr12_12(uchar x1, uchar y1, const uchar *NUMBER);
const uchar HTDISPLAY[]=
0x08,0x30,0x04,0x20,0x02,0x40,0x3F,0xFC,0x29,0x14,0x25,0x24,0x25,0x44,0x3F,0xFC,
0x00,0x00,0x0F,0xF0,0x08,0x10,0x0F,0xF0,0x08,0x10,0x08,0x10,0x0F,0xF0,0x08,0x10,/*"曾",0*/
0x10,0x00,0x11,0xFC,0x20,0x08,0x20,0x10,0x48,0x30,0xF0,0xC8,0x13,0x06,0x20,0x02,
0x41,0xFC,0xF8,0x20,0x00,0x20,0x00,0x20,0x18,0x20,0xE3,0xFE,0x00,0x00,0x00,0x00,/*"经",1*/
0x01,0x00,0x01,0x00,0x7F,0xFE,0x02,0x00,0x04,0x00,0x0F,0xF0,0x18,0x10,0x28,0x10,
0x4F,0xF0,0x88,0x10,0x08,0x10,0x0F,0xF0,0x08,0x10,0x08,0x90,0x08,0x70,0x08,0x20,/*"有",2*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x7F,0xFE,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*"一",3*/
0x09,0x30,0x0D,0xA0,0x09,0x20,0x12,0x10,0x12,0x08,0x24,0x0E,0x68,0x04,0xB7,0xF8,
0x20,0x88,0x20,0x88,0x20,0x88,0x21,0x08,0x21,0x08,0x22,0x38,0x2C,0x10,0x00,0x00,/*"份",4*/
0x01,0x00,0x01,0x04,0x7F,0xFE,0x02,0x00,0x0F,0xF0,0x08,0x10,0x0F,0xF0,0x08,0x10,
0x0F,0xF0,0x08,0x10,0x0F,0xF0,0x08,0x10,0xFF,0xFE,0x04,0x40,0x18,0x30,0x60,0x0C,/*"真",5*/
0x08,0x40,0x08,0x40,0x7E,0xF8,0x08,0x48,0x1E,0x48,0x68,0xCA,0x08,0xAA,0x2B,0x06,
0x1F,0xF0,0x01,0x00,0x3F,0xF8,0x01,0x00,0x7F,0xFE,0x01,0x00,0x05,0x00,0x02,0x00,/*"挚",6*/
0x10,0x80,0x10,0x80,0x20,0x80,0x7C,0xFC,0x45,0x04,0x45,0x04,0x46,0x04,0x7C,0x84,
0x44,0x44,0x44,0x64,0x44,0x24,0x44,0x04,0x7C,0x04,0x44,0x28,0x40,0x10,0x00,0x00,/*"的",7*/
0x00,0xF8,0x3F,0x90,0x12,0x10,0x09,0x20,0x3F,0xFE,0x22,0x02,0x42,0x00,0x3F,0xFC,
0x04,0x00,0x07,0xF0,0x0C,0x20,0x0B,0x40,0x10,0xC0,0x63,0x30,0x8C,0x0E,0x30,0x04,/*"爱",8*/
0x20,0x40,0x20,0x40,0x27,0xFC,0x30,0x40,0xAB,0xF8,0xA0,0x40,0xAF,0xFE,0x20,0x00,
0x23,0xF8,0x22,0x08,0x23,0xF8,0x22,0x08,0x23,0xF8,0x22,0x08,0x22,0x28,0x22,0x10,/*"情",9*/
0x10,0x40,0x08,0x60,0x08,0x40,0xFE,0xFE,0x20,0x84,0x20,0x84,0x3D,0x44,0x26,0x48,
0x24,0x28,0x24,0x30,0x24,0x10,0x24,0x30,0x44,0x48,0x44,0x8E,0x95,0x04,0x08,0x00,/*"放",10*/
0x02,0x00,0x02,0x00,0x7F,0xFE,0x04,0x00,0x04,0x00,0x08,0x40,0x18,0x40,0x17,0xFC,
0x30,0x40,0x50,0x40,0x90,0x40,0x10,0x40,0x10,0x40,0x17,0xFE,0x10,0x00,0x00,0x00,/*"在",11*/
0x06,0x40,0x38,0x50,0x08,0x48,0x08,0x48,0x08,0x40,0xFF,0xFE,0x08,0x40,0x08,0x48,
0x0E,0x28,0x38,0x30,0xC8,0x20,0x08,0x50,0x09,0x92,0x08,0x0A,0x28,0x06,0x10,0x02,/*"我",12*/
0x00,0x00,0x7F,0xFE,0x02,0x00,0x04,0x00,0x3F,0xFC,0x24,0x44,0x24,0x44,0x27,0xC4,
0x24,0x44,0x24,0x44,0x27,0xC4,0x24,0x44,0x24,0x44,0x3F,0xFC,0x20,0x04,0x00,0x00,/*"面",13*/
0x08,0x10,0x06,0x18,0x04,0x20,0xFF,0xFE,0x00,0x00,0x3E,0x08,0x22,0x48,0x3E,0x48,
0x22,0x48,0x22,0x48,0x3E,0x48,0x22,0x48,0x22,0x48,0x2A,0x08,0x24,0x28,0x00,0x10,/*"前",14*/
0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x00,0x30,0x00,0x10,0x00,0x20,0x00,0x00,0x00,/*",",15*/
0x0E,0x28,0x38,0x30,0xC8,0x20,0x08,0x50,0x09,0x92,0x08,0x0A,0x28,0x06,0x10,0x02,/*"我",16*/
0x20,0x00,0x11,0xF0,0x11,0x10,0x81,0x10,0x42,0x12,0x54,0x0E,0x10,0x00,0x17,0xF8,
0x22,0x10,0x21,0x10,0xE0,0xA0,0x20,0x40,0x20,0xA0,0x21,0x18,0x26,0x0E,0x20,0x04,/*"没",17*/
0x4F,0xF0,0x88,0x10,0x08,0x10,0x0F,0xF0,0x08,0x10,0x08,0x90,0x08,0x70,0x08,0x20,/*"有",18*/
0x10,0x00,0x11,0xFC,0x10,0x08,0x10,0x10,0xFC,0x20,0x24,0x20,0x24,0x20,0x27,0xFE,
0x44,0x20,0x64,0x20,0x18,0x20,0x08,0x20,0x14,0x20,0x26,0x20,0x44,0xA0,0x80,0x40,/*"好",19*/
0x44,0x20,0x64,0x20,0x18,0x20,0x08,0x20,0x14,0x20,0x26,0x20,0x44,0xA0,0x80,0x40,/*"好",20*/
0x00,0x40,0xF8,0x40,0x20,0xA0,0x21,0x10,0x22,0x28,0x24,0x46,0xF8,0x80,0x23,0x10,
0x20,0x24,0x20,0x44,0x39,0x88,0xC6,0x10,0x00,0x60,0x01,0x80,0x06,0x00,0x38,0x00,/*"珍",21*/
0x21,0x10,0x21,0x10,0x21,0x10,0x37,0xFC,0xA9,0x10,0xA1,0x10,0xAF,0xFE,0x20,0x00,
0x23,0xF8,0x22,0x08,0x22,0x08,0x23,0xF8,0x22,0x08,0x22,0x08,0x23,0xF8,0x00,0x00,/*"惜",22*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x00,0x10,0x00,0x10,0x00,0x10,0x00,
0x10,0x00,0x10,0x00,0x10,0x00,0x10,0x00,0x10,0x00,0x00,0x00,0x10,0x00,0x00,0x00,/*"!",23*/
0x10,0x00,0x10,0x00,0x18,0x00,0x10,0x7E,0xFE,0x42,0x22,0x42,0x22,0x42,0x22,0x42,
0x22,0x42,0x24,0x42,0x14,0x42,0x08,0x42,0x14,0x7E,0x23,0x42,0x42,0x42,0x80,0x00,/*"如",24*/
0x00,0x00,0x1F,0xF0,0x11,0x10,0x1F,0xF0,0x11,0x10,0x1F,0xF0,0x01,0x00,0x01,0x00,
0xFF,0xFE,0x03,0x80,0x05,0x40,0x09,0x30,0x31,0x0E,0xC1,0x04,0x01,0x00,0x01,0x00,/*"果",25*/
0x00,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0xF8,0x01,0x00,
0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x04,0x7F,0xFE,0x00,0x00,/*"上",26*/
0x00,0x00,0x3F,0xFC,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x7F,0xFE,0x01,0x00,
0x01,0x00,0x02,0x80,0x02,0x40,0x04,0x20,0x08,0x18,0x10,0x0E,0x20,0x04,0x40,0x00,/*"天",27*/
0x20,0x40,0x30,0x40,0x24,0x4C,0x42,0x70,0xFF,0x44,0x42,0x46,0x00,0x7C,0x7E,0x00,
0x42,0x40,0x7E,0x4C,0x42,0x70,0x7E,0x40,0x42,0x44,0x42,0x46,0x4A,0x3C,0x44,0x00,/*"能",28*/
0x7F,0xFC,0x01,0x00,0x01,0x00,0x1F,0xF0,0x11,0x10,0x11,0x10,0x1F,0xF0,0x11,0x10,
0x11,0x10,0x11,0x10,0xFF,0xFE,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x50,0x10,0x20,/*"再",29*/
0x10,0x40,0x10,0x40,0x20,0xA0,0x20,0x90,0x49,0x08,0xF2,0x0E,0x15,0xF4,0x20,0x00,
0x40,0x00,0xF9,0xF8,0x01,0x08,0x01,0x08,0x19,0x08,0xE1,0x08,0x01,0xF8,0x00,0x00,/*"给",30*/
0x0E,0x28,0x38,0x30,0xC8,0x20,0x08,0x50,0x09,0x92,0x08,0x0A,0x28,0x06,0x10,0x02,/*"我",31*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*"一",32*/
0x01,0x00,0x41,0x00,0x25,0x00,0x25,0xFE,0x2A,0x44,0x0A,0x48,0x14,0x40,0x10,0x40,
0x20,0xC0,0xE0,0xA0,0x41,0x20,0x42,0x10,0x44,0x08,0x18,0x0E,0x60,0x04,0x00,0x00,/*"次",33*/
0x10,0x00,0x10,0xF8,0x10,0x88,0xFE,0x88,0x10,0x88,0x10,0x88,0x38,0x88,0x34,0x88,
0x54,0x88,0x50,0x88,0x91,0x08,0x11,0x0A,0x12,0x0A,0x12,0x0A,0x14,0x06,0x10,0x00,/*"机",34*/
0x01,0x00,0x01,0x00,0x02,0x80,0x04,0x40,0x08,0x20,0x10,0x18,0x6F,0xEE,0x80,0x04,
0x00,0x00,0x3F,0xF8,0x02,0x00,0x04,0x20,0x08,0x10,0x11,0xF8,0x3F,0x18,0x10,0x10,/*"会",35*/
0x44,0x44,0x44,0x64,0x44,0x24,0x44,0x04,0x7C,0x04,0x44,0x28,0x40,0x10,0x00,0x00,/*"的",36*/
0x40,0x00,0x20,0x1C,0x33,0xE0,0x20,0x20,0x00,0x20,0x07,0xFE,0xF0,0x20,0x10,0x20,
0x10,0x20,0x11,0xFC,0x11,0x04,0x11,0x04,0x15,0x04,0x19,0xFC,0x11,0x04,0x00,0x00,/*"话",37*/
0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x00,0x30,0x00,0x10,0x00,0x20,0x00,0x00,0x00,/*",",38*/
0x0E,0x28,0x38,0x30,0xC8,0x20,0x08,0x50,0x09,0x92,0x08,0x0A,0x28,0x06,0x10,0x02,/*"我",39*/
0x00,0x00,0x3F,0xF8,0x02,0x00,0x04,0x20,0x08,0x10,0x11,0xF8,0x3F,0x18,0x10,0x10,/*"会",40*/
0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0xFF,0xFE,0x01,0x00,0x02,0x80,
0x02,0x80,0x02,0x40,0x04,0x40,0x04,0x20,0x08,0x10,0x10,0x18,0x20,0x0E,0x40,0x04,/*"大",41*/
0x01,0x00,0xFF,0xFE,0x01,0x00,0x01,0x00,0x7F,0xFC,0x00,0x00,0x3F,0xF8,0x21,0x08,
0x21,0x08,0x3F,0xF8,0x20,0x08,0x20,0x00,0x40,0x00,0x40,0x00,0x80,0x00,0x00,0x00,/*"声",42*/
0x00,0x10,0x00,0x10,0x7C,0x10,0x04,0x10,0x05,0xFE,0x44,0x10,0x24,0x10,0x19,0x10,
0x08,0x90,0x14,0xD0,0x24,0x90,0x22,0x10,0x42,0x10,0x80,0x10,0x00,0x50,0x00,0x20,/*"对",43*/
0x00,0x20,0x20,0xA0,0x20,0xA0,0x20,0xA4,0xFC,0xBE,0x27,0xE4,0x24,0xA4,0x44,0xA4,
0x44,0xA4,0x48,0xB4,0x28,0xA8,0x10,0xA0,0x28,0x82,0x46,0x82,0x84,0x7E,0x00,0x00,/*"她",44*/
0x42,0x08,0x21,0x88,0x31,0x10,0x23,0xF8,0x02,0x08,0xE2,0x08,0x22,0x08,0x23,0xF8,
0x22,0xA8,0x20,0xA0,0x20,0xA0,0x29,0x20,0x31,0x22,0x22,0x22,0x04,0x1E,0x08,0x00,/*"说",45*/
0x00,0x00,0x30,0x00,0x30,0x00,0x00,0x00,0x30,0x00,0x30,0x00,0x00,0x00,0x00,0x00,/*":",46*/
0x0E,0x28,0x38,0x30,0xC8,0x20,0x08,0x50,0x09,0x92,0x08,0x0A,0x28,0x06,0x10,0x02,/*"我",47*/
0x04,0x00,0x07,0xF0,0x0C,0x20,0x0B,0x40,0x10,0xC0,0x63,0x30,0x8C,0x0E,0x30,0x04,/*"爱",48*/
0x09,0x00,0x09,0x80,0x11,0x04,0x13,0xFE,0x22,0x04,0x34,0x48,0x68,0x40,0xA2,0x50,
0x23,0x48,0x22,0x48,0x24,0x44,0x24,0x46,0x28,0x44,0x21,0x40,0x20,0x80,0x00,0x00,/*"你",49*/
0x10,0x00,0x10,0x00,0x10,0x00,0x10,0x00,0x10,0x00,0x00,0x00,0x10,0x00,0x00,0x00,/*"!",50*/
0x22,0x42,0x24,0x42,0x14,0x42,0x08,0x42,0x14,0x7E,0x23,0x42,0x42,0x42,0x80,0x00,/*"如",51*/
0xFF,0xFE,0x03,0x80,0x05,0x40,0x09,0x30,0x31,0x0E,0xC1,0x04,0x01,0x00,0x01,0x00,/*"果",52*/
0x04,0x40,0x04,0x40,0x04,0x40,0x7C,0x7E,0x04,0x40,0x04,0x40,0x04,0x40,0x7C,0x7C,
0x04,0x40,0x04,0x40,0x04,0x40,0xFC,0x7E,0x04,0x40,0x04,0x40,0x04,0x40,0x04,0x40,/*"非",53*/
0x00,0x00,0xFF,0xFE,0x04,0x40,0x3F,0xF8,0x24,0x48,0x24,0x48,0x3F,0xF8,0x24,0x08,
0x04,0x00,0xFF,0xFE,0x08,0x10,0x0E,0x20,0x01,0xC0,0x06,0x30,0x18,0x0C,0x60,0x08,/*"要",54*/
0x08,0x00,0x08,0x00,0x08,0x00,0x7F,0x7C,0x09,0x44,0x09,0x44,0x09,0x44,0x09,0x44,
0x11,0x44,0x11,0x44,0x11,0x44,0x21,0x44,0x21,0x7C,0x45,0x44,0x82,0x40,0x00,0x00,/*"加",55*/
0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x04,0x7F,0xFE,0x00,0x00,/*"上",56*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*"一",57*/
0x01,0x00,0x01,0x00,0x02,0x80,0x02,0x40,0x04,0x20,0x09,0x18,0x11,0x0E,0x61,0x04,
0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x00,0x00,/*"个",58*/
0x22,0x00,0x22,0x7C,0x7F,0x44,0x22,0x44,0x3E,0x44,0x22,0x7C,0x3E,0x44,0x22,0x44,
0x22,0x44,0xFF,0x7C,0x00,0x44,0x24,0x84,0x22,0x84,0x43,0x14,0x81,0x08,0x00,0x00,/*"期",59*/
0x00,0x00,0xFB,0xF8,0x92,0x08,0x93,0xF8,0xA2,0x08,0xA2,0x08,0x93,0xF8,0x8A,0x80,
0x8A,0x48,0xAA,0x50,0x92,0x20,0x82,0x20,0x82,0x10,0x82,0x8E,0x83,0x04,0x82,0x00,/*"限",60*/
0x44,0x44,0x44,0x64,0x44,0x24,0x44,0x04,0x7C,0x04,0x44,0x28,0x40,0x10,0x00,0x00,/*"的",61*/
0x10,0x20,0x11,0xFC,0x11,0x04,0x11,0x04,0x15,0x04,0x19,0xFC,0x11,0x04,0x00,0x00,/*"话",62*/
0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x00,0x30,0x00,0x10,0x00,0x20,0x00,0x00,0x00,/*",",63*/
0x0E,0x28,0x38,0x30,0xC8,0x20,0x08,0x50,0x09,0x92,0x08,0x0A,0x28,0x06,0x10,0x02,/*"我",64*/
0x08,0x20,0x06,0x40,0x01,0x80,0x0E,0x60,0x32,0x10,0xFF,0xFE,0x04,0x80,0x08,0x80,
0x1F,0xF8,0x28,0x88,0x48,0x88,0x88,0x88,0x08,0x88,0x08,0xB8,0x00,0x90,0x00,0x80,/*"希",65*/
0x10,0x00,0x08,0xFC,0xFE,0x84,0x20,0xFC,0x20,0x84,0x24,0xFC,0x28,0x84,0x31,0x1C,
0x00,0x00,0x3F,0xFC,0x01,0x00,0x1F,0xF8,0x01,0x00,0x01,0x00,0x7F,0xFE,0x00,0x00,/*"望",66*/
0x00,0x00,0x0F,0xF0,0x08,0x10,0x0F,0xF0,0x08,0x10,0x0F,0xF0,0x00,0x00,0xFF,0xFE,
0x01,0x00,0x09,0x00,0x09,0xF8,0x09,0x00,0x15,0x00,0x23,0x00,0x40,0xFE,0x00,0x00,/*"是",67*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*"一",68*/
0x00,0x00,0x7F,0xFE,0x02,0x00,0x02,0x00,0x02,0x10,0x03,0xF8,0x02,0x10,0x04,0x10,
0x04,0x10,0x04,0x10,0x08,0x10,0x08,0x10,0x10,0x10,0x20,0xE0,0x40,0x40,0x00,0x00,/*"万",69*/
0x08,0x00,0x0F,0xFC,0x10,0x80,0x10,0x80,0x20,0x80,0x4F,0xF8,0x88,0x80,0x08,0x80,
0x08,0x80,0x08,0x80,0xFF,0xFE,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0x80,/*"年",70*/
0x10,0x00,0x10,0x00,0x10,0x00,0x10,0x00,0x10,0x00,0x00,0x00,0x10,0x00,0x00,0x00,/*"!",71*/
const uchar MYNUMBER[]=
0x00,0x00,0x70,0x88,0x88,0x88,0x88,0x88,0x88,0x70,0x00,0x00,/*"0",0*/
0x00,0x00,0x20,0x60,0x20,0x20,0x20,0x20,0x20,0x70,0x00,0x00,/*"1",1*/
0x00,0x00,0x70,0x88,0x88,0x10,0x20,0x40,0x80,0xF8,0x00,0x00,/*"2",2*/
0x00,0x00,0x70,0x88,0x08,0x30,0x08,0x08,0x88,0x70,0x00,0x00,/*"3",3*/
0x00,0x00,0x10,0x30,0x50,0x50,0x90,0x78,0x10,0x18,0x00,0x00,/*"4",4*/
0x00,0x00,0xF8,0x80,0x80,0xF0,0x08,0x08,0x88,0x70,0x00,0x00,/*"5",5*/
0x00,0x00,0x70,0x90,0x80,0xF0,0x88,0x88,0x88,0x70,0x00,0x00,/*"6",6*/
0x00,0x00,0xF8,0x90,0x10,0x20,0x20,0x20,0x20,0x20,0x00,0x00,/*"7",7*/
0x00,0x00,0x70,0x88,0x88,0x70,0x88,0x88,0x88,0x70,0x00,0x00,/*"8",8*/
0x00,0x00,0x70,0x88,0x88,0x88,0x78,0x08,0x48,0x70,0x00,0x00,/*"9",9*/
///////////////////LCD的写字测试程序///16×16//////////////////
//横向点18位,最后两位填0////液晶驱动变态///////////
uchar x,y;
uchar uc_CharCode,uc_BitCnt;
wr_cmd(0x30);//EXT=0
wr_cmd(0x75); //Line address set
wr_dat(0x00); //Start Line
wr_dat(0x0F); //End Line
wr_cmd(0x15); //Column address set
wr_dat(0x00); //Start Column
wr_dat(0x05); //End Column
wr_cmd(0X5C);//Write data to DDRAM
for(x=0;x<16;x++)
for(y=0;y<2;y++)
uc_CharCode = *myziku++;
for(uc_BitCnt=0;uc_BitCnt<8;uc_BitCnt++)
if((uc_CharCode&0x80) == 0)
wr_dat(0x00);
wr_dat(0xFF);
//仅仅点亮panel上面的一个点---需要一个byte
uc_CharCode =uc_CharCode <<1;
wr_dat(0x00);
wr_dat(0x00);
delayms(1);
* 名称: LcdSetAddr
* 功能: 设置数据地址指针(坐标值)。
* 入口参数: x1 起始横坐标的值 (0-158)
* y1 起始纵坐标的值 (0-158)
* 出口参数: 设置正确返回TRUE,参数超出范围返回FALSE
uchar x,y;
wr_cmd(0x30); //EXT=0
wr_cmd(0x75);
wr_dat(x1);
wr_dat(x1+15);
wr_cmd(0x15);
wr_dat(y1);
wr_dat(y1+5);
wr_cmd(0X5C); //Write data to DDRAM
for(x=0;x<16;x++)
for(y=0;y<2;y++)
uc_CharCode = *ziku++;
wr_dat(0x00);
wr_dat(0xFF);
wr_dat(0x00);
wr_dat(0x00);
// if(((x1+15)<160) && ((y1+5)<53)) return(TRUE);
// else return(FALSE);
void LcdSetAddr12_12(uchar x1, uchar y1, const uchar *ziku)
uchar x;
wr_cmd(0x75);
wr_dat(x1);
wr_dat(x1+11);
wr_cmd(0x15);
wr_dat(y1);
wr_dat(y1+2);
for(x=0;x<12;x++)
wr_dat(0x00);
wr_dat(0xFF);
wr_dat(0x00);
//Reset Delay
void delay()
uchar uc_dlay1,uc_dlay2;
for (uc_dlay1=0; uc_dlay1<250; uc_dlay1++);
for (uc_dlay2=0; uc_dlay2<20; uc_dlay2++);
//Delay Times(s Level)
void delayms()
uint ui_dlay1,ui_dlay2;
ui_dlay2 = DELAYMS;
while (ui_dlay2-- >0)
for (ui_dlay1=0; ui_dlay1<500; ui_dlay1++);
void delay10ms(int count) //===延迟===
unsigned int i,j,k;
for (i=0; i<count; i++);
for(j=0; j<10; j++);
for(k=0; k<120; k++);
//Write Instruction Code
LCD_RS0;
LCD_WR1;
LCD_RD1;
LCD_CS0;
DataPort = cmd;
LCD_WR0;
LCD_WR1;
LCD_CS1;
//Write Display RAM Data
LCD_RS1;
LCD_WR1;
LCD_RD1;
LCD_CS0;
DataPort = dat;
LCD_WR0;
LCD_WR1;
LCD_CS1;
void InitSys()
unsigned int iq0; //--- 使用XT2振荡器 ---
BCSCTL1&=~XT2OFF; //=== 打开XT2振荡器 ===
do
IFG1 &= ~OFIFG; //=== 清除振荡器失效标志 ===
for (iq0 = 0xFF; iq0 > 0; iq0--); //=== 延时,等待XT2起振 ===
while ((IFG1 & OFIFG) != 0); //=== 判断XT2是否起振 ===
BCSCTL2 =SELM_2+SELS; //=== 选择MCLK、SMCLK为XT2 ===
//--- 以下填充用户代码,对各种模块、中断、外围设备等进行初始化 ---
P1SEL = 0x00; // 设置P1口为IO口
P1DIR = 0xFF; // 设置P1口为output
P4DIR = 0xFF; //===Set P4.0 to output direction===
// _EINT(); //=== 打开全局中断控制,若不需要打开,可以屏蔽本句 ===
* 函数名称 : ST7529Ini(void)
* 功能描述 : 初始化控制器
* 函数说明 :
* 调用函数 : 无
* 全局变量 : 无
* 输入参数 : 无
* 返回值 : 无
* 设计者 : Joshua Chiang
* 修改者 : --
* 版本号 : 1.0
wr_cmd(0X30); //EXT=0
wr_cmd(0X94); //SLEEP OUT
wr_cmd(0XD1); //OSC ON
wr_cmd(0x20); //POWER CONTROL SET
wr_dat(0X0B); //BOOSTER ON
wr_cmd(0x81); //ELECTRONIC CONTROL
wr_dat(0X30); //DL 30
wr_dat(0X04); //DH
wr_cmd(0xCA); //DISPLAY CONTROL
wr_dat(0X04); //CLD=0,NOT DIVIDE
wr_dat(0X27); //1/160 DUTY 39
wr_dat(0X00); //FR
wr_cmd(0xA7); //Reverse display ~A6?
wr_cmd(0xBB); //COM SCAN DIRECTION
wr_dat(0X02); //C79->C0,C80->C159
wr_cmd(0xBC); //Data Scan Direction
wr_dat(0X01);
wr_dat(0X00); //CLR=0
wr_dat(0X02); //32 Gray-scale 3byte 3pixel mode
wr_dat(0x9F); //End Line
wr_dat(0x35); //End Column
wr_cmd(0x31); //ext=1
wr_cmd(0x32); //Analog circuit set
wr_dat(0X07); //FR=12.7KHZ
wr_dat(0X02); //Booster FR=6KHZ
wr_dat(0X03); //1/11bias 01 调对比度
wr_cmd(0x34); //Dithering off
wr_cmd(0xAF); //DISP ON
//Write Data To DDRAM
uchar uc_RowCnt,uc_ColCnt;
for (uc_RowCnt=0;uc_RowCnt<80;uc_RowCnt++)
for (uc_ColCnt=0;uc_ColCnt<54;uc_ColCnt++)
wr_dat(dat1);
wr_dat(dat1);
wr_dat(dat1);
wr_dat(dat2);
wr_dat(dat2);
wr_dat(dat2);
delayms();
const uchar *z;
z=HTDISPLAY;
for(;x<145;x+=16)
for(;y<50;y+=6)
LcdSetAddr16_16(x, y, z);
z+=32;
y=0;
功能:设置液晶开关
参数:无
返回:无
wr_cmd(0xaf);
//wr_cmd(0x94);
led1_on();
lcm_on;
wr_cmd(0xae);
//wr_cmd(0x95);
led1_off();
lcm_off;
void main()
WDTCTL = WDTPW + WDTHOLD; //=== Stop watchdog timer ===
InitSys(); //=== 初始化 ===
LCD_RST0;
delay();
delay();
LCD_RST1;
delay();
delay();
ST7529Ini();
disp_dots(0x00,0x00); //Clear Screen
while (1)
{ //disp_dots(0x00,0x00); //Clear Screen
// disp_dots(0xFF,0xFF); //All Dots Display
//disp_dots(0xFF,0x00); //Seperate Rows I
HDT_DisplayOff();
HDT_DisplayOn();
//disp_dots(0x00,0xFF); //Seperate Rows II
// disp_dots(0x00,0x00); //Clear Screen
dsiplay16_16(0,0);
// LcdSetAddr12_12(0, 6,HTDISPLAY);
// disp_bmpp(&HTDISPLAY[32]);
// LcdSetAddr16_16(16, 0, HTDISPLAY );
//LcdSetAddr12_12(0, 18,MYNUMBER);
