新手,闲的没事写的,所有的crc校验基本就都是一个套路,我这里写了crc-4,5,6,7,8,16,32的校验码生成函数,
64的没怎么见过,没写,不过根据前面的套路,很容易就写出来了.
其实并不是所有的情况都需要讲究速度,比如DS18B20那种器件,就8个字节的寄存器,校验起来很容易的.不需要查表,逐位运算就能满足要求.
逐位运算好处是不用写表了,弱点也很明显,速度慢.
废话不多说,贴代码
- uint8_t crc4_itu(uint8_t *data, uint_len length);
- uint8_t crc5_epc(uint8_t *data, uint_len length);
- uint8_t crc5_itu(uint8_t *data, uint_len length);
- uint8_t crc5_usb(uint8_t *data, uint_len length);
- uint8_t crc6_itu(uint8_t *data, uint_len length);
- uint8_t crc7_mmc(uint8_t *data, uint_len length);
- uint8_t crc8(uint8_t *data, uint_len length);
- uint8_t crc8_itu(uint8_t *data, uint_len length);
- uint8_t crc8_rohc(uint8_t *data, uint_len length);
- uint8_t crc8_maxim(uint8_t *data, uint_len length);
- uint16_t crc16_ibm(uint8_t *data, uint_len length);
- uint16_t crc16_maxim(uint8_t *data, uint_len length);
- uint16_t crc16_usb(uint8_t *data, uint_len length);
- uint16_t crc16_modbus(uint8_t *data, uint_len length);
- uint16_t crc16_ccitt(uint8_t *data, uint_len length);
- uint16_t crc16_ccitt_false(uint8_t *data, uint_len length);
- uint16_t crc16_x25(uint8_t *data, uint_len length);
- uint16_t crc16_xmodem(uint8_t *data, uint_len length);
- uint16_t crc16_dnp(uint8_t *data, uint_len length);
- uint32_t crc32(uint8_t *data, uint_len length);
- uint32_t crc32_mpeg_2(uint8_t *data, uint_len length);
- * Name: CRC-4/ITU x4+x+1
- * Poly: 0x03
- * Init: 0x00
- * Refin: True
- * Refout: True
- * Xorout: 0x00
- * Note:
- uint8_t i;
- uint8_t crc = 0; // Initial value
- while(length--)
- crc ^= *data++; // crc ^= *data; data++;
- for (i = 0; i < 8; ++i)
- if (crc & 1)
- crc = (crc >> 1) ^ 0x0C;// 0x0C = (reverse 0x03)>>(8-4)
- else
- crc = (crc >> 1);
- return crc;
- * Name: CRC-5/EPC x5+x3+1
- * Poly: 0x09
- * Init: 0x09
- * Refin: False
- * Refout: False
- * Xorout: 0x00
- * Note:
- uint8_t i;
- uint8_t crc = 0x48; // Initial value: 0x48 = 0x09<<(8-5)
- while(length--)
- for ( i = 0; i < 8; i++ )
- if ( crc & 0x80 )
- crc = (crc << 1) ^ 0x48; // 0x48 = 0x09<<(8-5)
- else
- crc <<= 1;
- return crc >> 3;
- * Name: CRC-5/ITU x5+x4+x2+1
- * Poly: 0x15
- * Init: 0x00
- * Refin: True
- * Refout: True
- * Xorout: 0x00
- * Note:
- uint8_t i;
- while(length--)
- if (crc & 1)
- crc = (crc >> 1) ^ 0x15;// 0x15 = (reverse 0x15)>>(8-5)
- else
- crc = (crc >> 1);
- return crc;
- * Name: CRC-5/USB x5+x2+1
- * Poly: 0x05
- * Init: 0x1F
- * Refin: True
- * Refout: True
- * Xorout: 0x1F
- * Note:
- uint8_t i;
- uint8_t crc = 0x1F; // Initial value
- while(length--)
- if (crc & 1)
- crc = (crc >> 1) ^ 0x14;// 0x14 = (reverse 0x05)>>(8-5)
- else
- crc = (crc >> 1);
- return crc ^ 0x1F;
- * Name: CRC-6/ITU x6+x+1
- * Poly: 0x03
- * Init: 0x00
- * Refin: True
- * Refout: True
- * Xorout: 0x00
- * Note:
- uint8_t i;
- while(length--)
- if (crc & 1)
- crc = (crc >> 1) ^ 0x30;// 0x30 = (reverse 0x03)>>(8-6)
- else
- crc = (crc >> 1);
- return crc;
- * Name: CRC-7/MMC x7+x3+1
- * Poly: 0x09
- * Init: 0x00
- * Refin: False
- * Refout: False
- * Xorout: 0x00
- * Use: MultiMediaCard,SD,ect.
- uint8_t i;
- while(length--)
- if ( crc & 0x80 )
- crc = (crc << 1) ^ 0x12; // 0x12 = 0x09<<(8-7)
- else
- crc <<= 1;
- return crc >> 1;
- * Name: CRC-8 x8+x2+x+1
- * Poly: 0x07
- * Init: 0x00
- * Refin: False
- * Refout: False
- * Xorout: 0x00
- * Note:
- uint8_t i;
- while(length--)
- if ( crc & 0x80 )
- crc = (crc << 1) ^ 0x07;
- else
- crc <<= 1;
- return crc;
- * Name: CRC-8/ITU x8+x2+x+1
- * Poly: 0x07
- * Init: 0x00
- * Refin: False
- * Refout: False
- * Xorout: 0x55
- * Alias: CRC-8/ATM
- uint8_t i;
- while(length--)
- if ( crc & 0x80 )
- else
- crc <<= 1;
- return crc ^ 0x55;
- * Name: CRC-8/ROHC x8+x2+x+1
- * Poly: 0x07
- * Init: 0xFF
- * Refin: True
- * Refout: True
- * Xorout: 0x00
- * Note:
- uint8_t i;
- uint8_t crc = 0xFF; // Initial value
- while(length--)
- if (crc & 1)
- crc = (crc >> 1) ^ 0xE0; // 0xE0 = reverse 0x07
- else
- crc = (crc >> 1);
- return crc;
- * Name: CRC-8/MAXIM x8+x5+x4+1
- * Poly: 0x31
- * Init: 0x00
- * Refin: True
- * Refout: True
- * Xorout: 0x00
- * Alias: DOW-CRC,CRC-8/IBUTTON
- * Use: Maxim(Dallas)'s some devices,e.g. DS18B20
- uint8_t i;
- while(length--)
- for (i = 0; i < 8; i++)
- if (crc & 1)
- crc = (crc >> 1) ^ 0x8C; // 0x8C = reverse 0x31
- else
- crc >>= 1;
- return crc;
- * Name: CRC-16/IBM x16+x15+x2+1
- * Poly: 0x8005
- * Init: 0x0000
- * Refin: True
- * Refout: True
- * Xorout: 0x0000
- * Alias: CRC-16,CRC-16/ARC,CRC-16/LHA
- uint8_t i;
- uint16_t crc = 0; // Initial value
- while(length--)
- if (crc & 1)
- crc = (crc >> 1) ^ 0xA001; // 0xA001 = reverse 0x8005
- else
- crc = (crc >> 1);
- return crc;
- * Name: CRC-16/MAXIM x16+x15+x2+1
- * Poly: 0x8005
- * Init: 0x0000
- * Refin: True
- * Refout: True
- * Xorout: 0xFFFF
- * Note:
- uint8_t i;
- while(length--)
- if (crc & 1)
- else
- crc = (crc >> 1);
- return ~crc; // crc^0xffff
- * Name: CRC-16/USB x16+x15+x2+1
- * Poly: 0x8005
- * Init: 0xFFFF
- * Refin: True
- * Refout: True
- * Xorout: 0xFFFF
- * Note:
- uint8_t i;
- uint16_t crc = 0xffff; // Initial value
- while(length--)
- if (crc & 1)
- else
- crc = (crc >> 1);
- * Name: CRC-16/MODBUS x16+x15+x2+1
- * Poly: 0x8005
- * Init: 0xFFFF
- * Refin: True
- * Refout: True
- * Xorout: 0x0000
- * Note:
- uint8_t i;
- while(length--)
- if (crc & 1)
- else
- crc = (crc >> 1);
- return crc;
- * Name: CRC-16/CCITT x16+x12+x5+1
- * Poly: 0x1021
- * Init: 0x0000
- * Refin: True
- * Refout: True
- * Xorout: 0x0000
- * Alias: CRC-CCITT,CRC-16/CCITT-TRUE,CRC-16/KERMIT
- uint8_t i;
- while(length--)
- if (crc & 1)
- crc = (crc >> 1) ^ 0x8408; // 0x8408 = reverse 0x1021
- else
- crc = (crc >> 1);
- return crc;
- * Name: CRC-16/CCITT-FALSE x16+x12+x5+1
- * Poly: 0x1021
- * Init: 0xFFFF
- * Refin: False
- * Refout: False
- * Xorout: 0x0000
- * Note:
- uint8_t i;
- uint16_t crc = 0xffff; //Initial value
- while(length--)
- crc ^= (uint16_t)(*data++) << 8; // crc ^= (uint6_t)(*data)<<8; data++;
- if ( crc & 0x8000 )
- crc = (crc << 1) ^ 0x1021;
- else
- crc <<= 1;
- return crc;
- * Name: CRC-16/X25 x16+x12+x5+1
- * Poly: 0x1021
- * Init: 0xFFFF
- * Refin: True
- * Refout: True
- * Xorout: 0XFFFF
- * Note:
- uint8_t i;
- while(length--)
- if (crc & 1)
- else
- crc = (crc >> 1);
- return ~crc; // crc^Xorout
- * Name: CRC-16/XMODEM x16+x12+x5+1
- * Poly: 0x1021
- * Init: 0x0000
- * Refin: False
- * Refout: False
- * Xorout: 0x0000
- * Alias: CRC-16/ZMODEM,CRC-16/ACORN
- uint8_t i;
- while(length--)
- crc ^= (uint16_t)(*data++) << 8; // crc ^= (uint16_t)(*data)<<8; data++;
- else
- crc <<= 1;
- return crc;
- * Name: CRC-16/DNP x16+x13+x12+x11+x10+x8+x6+x5+x2+1
- * Poly: 0x3D65
- * Init: 0x0000
- * Refin: True
- * Refout: True
- * Xorout: 0xFFFF
- * Use: M-Bus,ect.
- uint8_t i;
- while(length--)
- if (crc & 1)
- crc = (crc >> 1) ^ 0xA6BC; // 0xA6BC = reverse 0x3D65
- else
- crc = (crc >> 1);
- * Name: CRC-32 x32+x26+x23+x22+x16+x12+x11+x10+x8+x7+x5+x4+x2+x+1
- * Poly: 0x4C11DB7
- * Init: 0xFFFFFFF
- * Refin: True
- * Refout: True
- * Xorout: 0xFFFFFFF
- * Alias: CRC_32/ADCCP
- * Use: WinRAR,ect.
- uint8_t i;
- uint32_t crc = 0xffffffff; // Initial value
- while(length--)
- if (crc & 1)
- crc = (crc >> 1) ^ 0xEDB88320;// 0xEDB88320= reverse 0x04C11DB7
- else
- crc = (crc >> 1);
- return ~crc;
- * Name: CRC-32/MPEG-2 x32+x26+x23+x22+x16+x12+x11+x10+x8+x7+x5+x4+x2+x+1
- * Poly: 0x4C11DB7
- * Init: 0xFFFFFFF
- * Refin: False
- * Refout: False
- * Xorout: 0x0000000
- * Note:
- uint8_t i;
- while(length--)
- crc ^= (uint32_t)(*data++) << 24;// crc ^=(uint32_t)(*data)<<24; data++;
- if ( crc & 0x80000000 )
- crc = (crc << 1) ^ 0x04C11DB7;
- else
- crc <<= 1;
- return crc;
使用方法,首先根据数据长度,定义uint_len的类型
比如 typedef uint16_t uint_len;
然后定义一组测试数据
比如 uint8_t serno[] = { 0x91, 0xA3, 0xB5, 0xC7, 0x8D, 0xEB, 0x2D, 0X4E,};
最后输出对应的校验码
printf("0x%X\n", crc8(serno, sizeof(serno))); //CRC-8
printf("0x%X\n", crc32(serno, sizeof(serno))); //CRC-32
我是按照网上的crc小工具来的,图片里的所有校验函数都写了
参考资料是AVR-GCC的库util/crc16.h
http://www.nongnu.org/avr-libc/user-manual/group__util__crc.html |
