想用一片STM32F030来模拟AT24C02
支持I2C Host读取256个字节
可以不用支持I2C host的写操作
使用中断来实现
主机一次读取16个字节,循环读取16次
现在的问题是主机读取第一个16字节没问题
读取第二个16字节就开始有问题了.
请高手帮忙支招,万分感谢
"stm32f0xx_it.c
- * @brief This function handles I2C1 global interrupt.
- void I2C1_IRQHandler(void)
- /* USER CODE BEGIN I2C1_IRQn 0 */
- /* USER CODE END I2C1_IRQn 0 */
- if (hi2c1.Instance->ISR & (I2C_FLAG_BERR | I2C_FLAG_ARLO | I2C_FLAG_OVR))
- HAL_I2C_ER_IRQHandler(&hi2c1);
- else
- HAL_I2C_EV_IRQHandler(&hi2c1);
- /* USER CODE BEGIN I2C1_IRQn 1 */
- /* USER CODE END I2C1_IRQn 1 */
- * @file stm32f0xx_hal_i2c.c
- * @author MCD Application Team
- * @version V1.3.1
- * @date 29-January-2016
- * @brief I2C HAL module driver.
- * This file provides firmware functions to manage the following
- * functionalities of the Inter Integrated Circuit (I2C) peripheral:
- * + Initialization and de-initialization functions
- * + IO operation functions
- * + Peripheral State and Errors functions
- @verbatim
- ##### How to use this driver #####
- The I2C HAL driver can be used as follows:
- (#) Declare a I2C_HandleTypeDef handle structure, for example:
- I2C_HandleTypeDef hi2c;
- (#)Initialize the I2C low level resources by implementing the HAL_I2C_MspInit() API:
- (##) Enable the I2Cx interface clock
- (##) I2C pins configuration
- (+++) Enable the clock for the I2C GPIOs
- (+++) Configure I2C pins as alternate function open-drain
- (##) NVIC configuration if you need to use interrupt process
- (+++) Configure the I2Cx interrupt priority
- (+++) Enable the NVIC I2C IRQ Channel
- (##) DMA Configuration if you need to use DMA process
- (+++) Declare a DMA_HandleTypeDef handle structure for the transmit or receive channel
- (+++) Enable the DMAx interface clock using
- (+++) Configure the DMA handle parameters
- (+++) Configure the DMA Tx or Rx channel
- (+++) Associate the initialized DMA handle to the hi2c DMA Tx or Rx handle
- (+++) Configure the priority and enable the NVIC for the transfer complete interrupt on
- the DMA Tx or Rx channel
- (#) Configure the Communication Clock Timing, Own Address1, Master Addressing mode, Dual Addressing mode,
- Own Address2, Own Address2 Mask, General call and Nostretch mode in the hi2c Init structure.
- (#) Initialize the I2C registers by calling the HAL_I2C_Init(), configures also the low level Hardware
- (GPIO, CLOCK, NVIC...etc) by calling the customized HAL_I2C_MspInit(&hi2c) API.
- (#) To check if target device is ready for communication, use the function HAL_I2C_IsDeviceReady()
- (#) For I2C IO and IO MEM operations, three operation modes are available within this driver :
- *** Polling mode IO operation ***
- (+) Transmit in master mode an amount of data in blocking mode using HAL_I2C_Master_Transmit()
- (+) Receive in master mode an amount of data in blocking mode using HAL_I2C_Master_Receive()
- (+) Transmit in slave mode an amount of data in blocking mode using HAL_I2C_Slave_Transmit()
- (+) Receive in slave mode an amount of data in blocking mode using HAL_I2C_Slave_Receive()
- *** Polling mode IO MEM operation ***
- (+) Write an amount of data in blocking mode to a specific memory address using HAL_I2C_Mem_Write()
- (+) Read an amount of data in blocking mode from a specific memory address using HAL_I2C_Mem_Read()
- *** Interrupt mode IO operation ***
- (+) Transmit in master mode an amount of data in non-blocking mode using HAL_I2C_Master_Transmit_IT()
- (+) At transmission end of transfer, HAL_I2C_MasterTxCpltCallback() is executed and user can
- add his own code by customization of function pointer HAL_I2C_MasterTxCpltCallback()
- (+) Receive in master mode an amount of data in non-blocking mode using HAL_I2C_Master_Receive_IT()
- (+) At reception end of transfer, HAL_I2C_MasterRxCpltCallback() is executed and user can
- add his own code by customization of function pointer HAL_I2C_MasterRxCpltCallback()
- (+) Transmit in slave mode an amount of data in non-blocking mode using HAL_I2C_Slave_Transmit_IT()
- (+) At transmission end of transfer, HAL_I2C_SlaveTxCpltCallback() is executed and user can
- add his own code by customization of function pointer HAL_I2C_SlaveTxCpltCallback()
- (+) Receive in slave mode an amount of data in non-blocking mode using HAL_I2C_Slave_Receive_IT()
- (+) At reception end of transfer, HAL_I2C_SlaveRxCpltCallback() is executed and user can
- add his own code by customization of function pointer HAL_I2C_SlaveRxCpltCallback()
- (+) In case of transfer Error, HAL_I2C_ErrorCallback() function is executed and user can
- add his own code by customization of function pointer HAL_I2C_ErrorCallback()
- *** Interrupt mode IO MEM operation ***
- (+) Write an amount of data in non-blocking mode with Interrupt to a specific memory address using
- HAL_I2C_Mem_Write_IT()
- (+) At Memory end of write transfer, HAL_I2C_MemTxCpltCallback() is executed and user can
- add his own code by customization of function pointer HAL_I2C_MemTxCpltCallback()
- (+) Read an amount of data in non-blocking mode with Interrupt from a specific memory address using
- HAL_I2C_Mem_Read_IT()
- (+) At Memory end of read transfer, HAL_I2C_MemRxCpltCallback() is executed and user can
- add his own code by customization of function pointer HAL_I2C_MemRxCpltCallback()
- *** DMA mode IO operation ***
- (+) Transmit in master mode an amount of data in non-blocking mode (DMA) using
- HAL_I2C_Master_Transmit_DMA()
- (+) Receive in master mode an amount of data in non-blocking mode (DMA) using
- HAL_I2C_Master_Receive_DMA()
- (+) Transmit in slave mode an amount of data in non-blocking mode (DMA) using
- HAL_I2C_Slave_Transmit_DMA()
- (+) Receive in slave mode an amount of data in non-blocking mode (DMA) using
- HAL_I2C_Slave_Receive_DMA()
- *** DMA mode IO MEM operation ***
- (+) Write an amount of data in non-blocking mode with DMA to a specific memory address using
- HAL_I2C_Mem_Write_DMA()
- (+) Read an amount of data in non-blocking mode with DMA from a specific memory address using
- HAL_I2C_Mem_Read_DMA()
- *** I2C HAL driver macros list ***
- Below the list of most used macros in I2C HAL driver.
- (+) __HAL_I2C_ENABLE: Enable the I2C peripheral
- (+) __HAL_I2C_DISABLE: Disable the I2C peripheral
- (+) __HAL_I2C_GET_FLAG: Check whether the specified I2C flag is set or not
- (+) __HAL_I2C_CLEAR_FLAG: Clear the specified I2C pending flag
- (+) __HAL_I2C_ENABLE_IT: Enable the specified I2C interrupt
- (+) __HAL_I2C_DISABLE_IT: Disable the specified I2C interrupt
- (@) You can refer to the I2C HAL driver header file for more useful macros
- @endverbatim
- * @attention
- * <h2><center>© COPYRIGHT(c) 2016 STMicroelectronics</center></h2>
- * Redistribution and use in source and binary forms, with or without modification,
- * are permitted provided that the following conditions are met:
- * 1. Redistributions of source code must retain the above copyright notice,
- * this list of conditions and the following disclaimer.
- * 2. Redistributions in binary form must reproduce the above copyright notice,
- * this list of conditions and the following disclaimer in the documentation
- * and/or other materials provided with the distribution.
- * 3. Neither the name of STMicroelectronics nor the names of its contributors
- * may be used to endorse or promote products derived from this software
- * without specific prior written permission.
- * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
- * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
- * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
- * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
- * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
- * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
- * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
- * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
- * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
- * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
- /* Includes ------------------------------------------------------------------*/
- #include "stm32f0xx_hal.h"
- /** @addtogroup STM32F0xx_HAL_Driver
- /** @defgroup I2C I2C
- #ifdef HAL_I2C_MODULE_ENABLED
- /* Private typedef -----------------------------------------------------------*/
- /* Private define ------------------------------------------------------------*/
- /** @defgroup I2C_Private_Define I2C Private Define
- #define TIMING_CLEAR_MASK ((uint32_t)0xF0FFFFFFU) /*!< I2C TIMING clear register Mask */
- #define I2C_TIMEOUT_ADDR ((uint32_t)10000) /*!< 10 s */
- #define I2C_TIMEOUT_BUSY ((uint32_t)25) /*!< 25 ms */
- #define I2C_TIMEOUT_DIR ((uint32_t)25) /*!< 25 ms */
- #define I2C_TIMEOUT_RXNE ((uint32_t)25) /*!< 25 ms */
- #define I2C_TIMEOUT_STOPF ((uint32_t)25) /*!< 25 ms */
- #define I2C_TIMEOUT_TC ((uint32_t)25) /*!< 25 ms */
- #define I2C_TIMEOUT_TCR ((uint32_t)25) /*!< 25 ms */
- #define I2C_TIMEOUT_TXIS ((uint32_t)25) /*!< 25 ms */
- #define I2C_TIMEOUT_FLAG ((uint32_t)25) /*!< 25 ms */
- #define MAX_NBYTE_SIZE 255
- /* Private macro -------------------------------------------------------------*/
- /* Private variables ---------------------------------------------------------*/
- /* Private function prototypes -----------------------------------------------*/
- /** @defgroup I2C_Private_Functions I2C Private Functions
- static void I2C_DMAMasterTransmitCplt(DMA_HandleTypeDef *hdma);
- static void I2C_DMAMasterReceiveCplt(DMA_HandleTypeDef *hdma);
- static void I2C_DMASlaveTransmitCplt(DMA_HandleTypeDef *hdma);
- static void I2C_DMASlaveReceiveCplt(DMA_HandleTypeDef *hdma);
- static void I2C_DMAMemTransmitCplt(DMA_HandleTypeDef *hdma);
- static void I2C_DMAMemReceiveCplt(DMA_HandleTypeDef *hdma);
- static void I2C_DMAError(DMA_HandleTypeDef *hdma);
- static HAL_StatusTypeDef I2C_RequestMemoryWrite(I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint16_t MemAddress, uint16_t MemAddSize, uint32_t Timeout);
- static HAL_StatusTypeDef I2C_RequestMemoryRead(I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint16_t MemAddress, uint16_t MemAddSize, uint32_t Timeout);
- static HAL_StatusTypeDef I2C_WaitOnFlagUntilTimeout(I2C_HandleTypeDef *hi2c, uint32_t Flag, FlagStatus Status, uint32_t Timeout);
- static HAL_StatusTypeDef I2C_WaitOnTXISFlagUntilTimeout(I2C_HandleTypeDef *hi2c, uint32_t Timeout);
- static HAL_StatusTypeDef I2C_WaitOnRXNEFlagUntilTimeout(I2C_HandleTypeDef *hi2c, uint32_t Timeout);
- static HAL_StatusTypeDef I2C_WaitOnSTOPFlagUntilTimeout(I2C_HandleTypeDef *hi2c, uint32_t Timeout);
- static HAL_StatusTypeDef I2C_IsAcknowledgeFailed(I2C_HandleTypeDef *hi2c, uint32_t Timeout);
- static HAL_StatusTypeDef I2C_MasterTransmit_ISR(I2C_HandleTypeDef *hi2c);
- static HAL_StatusTypeDef I2C_MasterReceive_ISR(I2C_HandleTypeDef *hi2c);
- static HAL_StatusTypeDef I2C_SlaveTransmit_ISR(I2C_HandleTypeDef *hi2c);
- static HAL_StatusTypeDef I2C_SlaveReceive_ISR(I2C_HandleTypeDef *hi2c);
- static void I2C_TransferConfig(I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint8_t Size, uint32_t Mode, uint32_t Request);
- /* Exported functions --------------------------------------------------------*/
- /** @defgroup I2C_Exported_Functions I2C Exported Functions
- /** @defgroup I2C_Exported_Functions_Group1 Initialization and de-initialization functions
- * @brief Initialization and Configuration functions
- @verbatim
- ##### Initialization and de-initialization functions #####
- [..] This subsection provides a set of functions allowing to initialize and
- deinitialize the I2Cx peripheral:
- (+) User must Implement HAL_I2C_MspInit() function in which he configures
- all related peripherals resources (CLOCK, GPIO, DMA, IT and NVIC ).
- (+) Call the function HAL_I2C_Init() to configure the selected device with
- the selected configuration:
- (++) Clock Timing
- (++) Own Address 1
- (++) Addressing mode (Master, Slave)
- (++) Dual Addressing mode
- (++) Own Address 2
- (++) Own Address 2 Mask
- (++) General call mode
- (++) Nostretch mode
- (+) Call the function HAL_I2C_DeInit() to restore the default configuration
- of the selected I2Cx peripheral.
- @endverbatim
- * @brief Initializes the I2C according to the specified parameters
- * in the I2C_InitTypeDef and initialize the associated handle.
- * @param hi2c Pointer to a I2C_HandleTypeDef structure that contains
- * the configuration information for the specified I2C.
- * @retval HAL status
- HAL_StatusTypeDef HAL_I2C_Init(I2C_HandleTypeDef *hi2c)
- /* Check the I2C handle allocation */
- if(hi2c == NULL)
- return HAL_ERROR;
- /* Check the parameters */
- assert_param(IS_I2C_ALL_INSTANCE(hi2c->Instance));
- assert_param(IS_I2C_OWN_ADDRESS1(hi2c->Init.OwnAddress1));
- assert_param(IS_I2C_ADDRESSING_MODE(hi2c->Init.AddressingMode));
- assert_param(IS_I2C_DUAL_ADDRESS(hi2c->Init.DualAddressMode));
- assert_param(IS_I2C_OWN_ADDRESS2(hi2c->Init.OwnAddress2));
- assert_param(IS_I2C_OWN_ADDRESS2_MASK(hi2c->Init.OwnAddress2Masks));
- assert_param(IS_I2C_GENERAL_CALL(hi2c->Init.GeneralCallMode));
- assert_param(IS_I2C_NO_STRETCH(hi2c->Init.NoStretchMode));
- if(hi2c->State == HAL_I2C_STATE_RESET)
- /* Allocate lock resource and initialize it */
- hi2c->Lock = HAL_UNLOCKED;
- /* Init the low level hardware : GPIO, CLOCK, CORTEX...etc */
- HAL_I2C_MspInit(hi2c);
- hi2c->State = HAL_I2C_STATE_BUSY;
- /* Disable the selected I2C peripheral */
- __HAL_I2C_DISABLE(hi2c);
- /*---------------------------- I2Cx TIMINGR Configuration ------------------*/
- /* Configure I2Cx: Frequency range */
- hi2c->Instance->TIMINGR = hi2c->Init.Timing & TIMING_CLEAR_MASK;
- /*---------------------------- I2Cx OAR1 Configuration ---------------------*/
- /* Configure I2Cx: Own Address1 and ack own address1 mode */
- hi2c->Instance->OAR1 &= ~I2C_OAR1_OA1EN;
- if(hi2c->Init.OwnAddress1 != 0)
- if(hi2c->Init.AddressingMode == I2C_ADDRESSINGMODE_7BIT)
- hi2c->Instance->OAR1 = (I2C_OAR1_OA1EN | hi2c->Init.OwnAddress1);
- else /* I2C_ADDRESSINGMODE_10BIT */
- hi2c->Instance->OAR1 = (I2C_OAR1_OA1EN | I2C_OAR1_OA1MODE | hi2c->Init.OwnAddress1);
- /*---------------------------- I2Cx CR2 Configuration ----------------------*/
- /* Configure I2Cx: Addressing Master mode */
- if(hi2c->Init.AddressingMode == I2C_ADDRESSINGMODE_10BIT)
- hi2c->Instance->CR2 = (I2C_CR2_ADD10);
- /* Enable the AUTOEND by default, and enable NACK (should be disable only during Slave process */
- hi2c->Instance->CR2 |= (I2C_CR2_AUTOEND | I2C_CR2_NACK);
- /*---------------------------- I2Cx OAR2 Configuration ---------------------*/
- /* Configure I2Cx: Dual mode and Own Address2 */
- hi2c->Instance->OAR2 = (hi2c->Init.DualAddressMode | hi2c->Init.OwnAddress2 | (hi2c->Init.OwnAddress2Masks << 8));
- /*---------------------------- I2Cx CR1 Configuration ----------------------*/
- /* Configure I2Cx: Generalcall and NoStretch mode */
- hi2c->Instance->CR1 = (hi2c->Init.GeneralCallMode | hi2c->Init.NoStretchMode);
- /* Enable the selected I2C peripheral */
- __HAL_I2C_ENABLE(hi2c);
- hi2c->ErrorCode = HAL_I2C_ERROR_NONE;
- hi2c->State = HAL_I2C_STATE_READY;
- hi2c->Mode = HAL_I2C_MODE_NONE;
- return HAL_OK;
- * @brief DeInitialize the I2C peripheral.
- HAL_StatusTypeDef HAL_I2C_DeInit(I2C_HandleTypeDef *hi2c)
- if(hi2c == NULL)
- return HAL_ERROR;
- /* Disable the I2C Peripheral Clock */
- /* DeInit the low level hardware: GPIO, CLOCK, NVIC */
- HAL_I2C_MspDeInit(hi2c);
- hi2c->State = HAL_I2C_STATE_RESET;
- /* Release Lock */
- __HAL_UNLOCK(hi2c);
- return HAL_OK;
- * @brief Initialize the I2C MSP.
- * @retval None
- __weak void HAL_I2C_MspInit(I2C_HandleTypeDef *hi2c)
- /* Prevent unused argument(s) compilation warning */
- UNUSED(hi2c);
- /* NOTE : This function should not be modified, when the callback is needed,
- the HAL_I2C_MspInit could be implemented in the user file
- * @brief DeInitialize the I2C MSP.
- * @retval None
- __weak void HAL_I2C_MspDeInit(I2C_HandleTypeDef *hi2c)
- UNUSED(hi2c);
- the HAL_I2C_MspDeInit could be implemented in the user file
- /** @defgroup I2C_Exported_Functions_Group2 Input and Output operation functions
- * @brief Data transfers functions
- @verbatim
- ##### IO operation functions #####
- This subsection provides a set of functions allowing to manage the I2C data
- transfers.
- (#) There are two modes of transfer:
- (++) Blocking mode : The communication is performed in the polling mode.
- The status of all data processing is returned by the same function
- after finishing transfer.
- (++) No-Blocking mode : The communication is performed using Interrupts
- or DMA. These functions return the status of the transfer startup.
- The end of the data processing will be indicated through the
- dedicated I2C IRQ when using Interrupt mode or the DMA IRQ when
- using DMA mode.
- (#) Blocking mode functions are :
- (++) HAL_I2C_Master_Transmit()
- (++) HAL_I2C_Master_Receive()
- (++) HAL_I2C_Slave_Transmit()
- (++) HAL_I2C_Slave_Receive()
- (++) HAL_I2C_Mem_Write()
- (++) HAL_I2C_Mem_Read()
- (++) HAL_I2C_IsDeviceReady()
- (#) No-Blocking mode functions with Interrupt are :
- (++) HAL_I2C_Master_Transmit_IT()
- (++) HAL_I2C_Master_Receive_IT()
- (++) HAL_I2C_Slave_Transmit_IT()
- (++) HAL_I2C_Slave_Receive_IT()
- (++) HAL_I2C_Mem_Write_IT()
- (++) HAL_I2C_Mem_Read_IT()
- (#) No-Blocking mode functions with DMA are :
- (++) HAL_I2C_Master_Transmit_DMA()
- (++) HAL_I2C_Master_Receive_DMA()
- (++) HAL_I2C_Slave_Transmit_DMA()
- (++) HAL_I2C_Slave_Receive_DMA()
- (++) HAL_I2C_Mem_Write_DMA()
- (++) HAL_I2C_Mem_Read_DMA()
- (#) A set of Transfer Complete Callbacks are provided in non Blocking mode:
- (++) HAL_I2C_MemTxCpltCallback()
- (++) HAL_I2C_MemRxCpltCallback()
- (++) HAL_I2C_MasterTxCpltCallback()
- (++) HAL_I2C_MasterRxCpltCallback()
- (++) HAL_I2C_SlaveTxCpltCallback()
- (++) HAL_I2C_SlaveRxCpltCallback()
- (++) HAL_I2C_ErrorCallback()
- @endverbatim
- * @brief Transmits in master mode an amount of data in blocking mode.
- * @param DevAddress Target device address
- * @param pData Pointer to data buffer
- * @param Size Amount of data to be sent
- * @param Timeout Timeout duration
- HAL_StatusTypeDef HAL_I2C_Master_Transmit(I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint8_t *pData, uint16_t Size, uint32_t Timeout)
- uint32_t sizetmp = 0;
- if(hi2c->State == HAL_I2C_STATE_READY)
- if(__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_BUSY) == SET)
- return HAL_BUSY;
- /* Process Locked */
- __HAL_LOCK(hi2c);
- hi2c->State = HAL_I2C_STATE_BUSY_TX;
- hi2c->Mode = HAL_I2C_MODE_MASTER;
- /* Send Slave Address */
- /* Set NBYTES to write and reload if size > MAX_NBYTE_SIZE and generate RESTART */
- /* Size > MAX_NBYTE_SIZE, need to set RELOAD bit */
- if(Size > MAX_NBYTE_SIZE)
- I2C_TransferConfig(hi2c, DevAddress, MAX_NBYTE_SIZE, I2C_RELOAD_MODE, I2C_GENERATE_START_WRITE);
- sizetmp = MAX_NBYTE_SIZE;
- else
- I2C_TransferConfig(hi2c, DevAddress, Size, I2C_AUTOEND_MODE, I2C_GENERATE_START_WRITE);
- sizetmp = Size;
- while(Size > 0)
- /* Wait until TXIS flag is set */
- if(I2C_WaitOnTXISFlagUntilTimeout(hi2c, Timeout) != HAL_OK)
- if(hi2c->ErrorCode == HAL_I2C_ERROR_AF)
- return HAL_ERROR;
- else
- return HAL_TIMEOUT;
- /* Write data to TXDR */
- hi2c->Instance->TXDR = (*pData++);
- sizetmp--;
- Size--;
- if((sizetmp == 0)&&(Size!=0))
- /* Wait until TCR flag is set */
- if(I2C_WaitOnFlagUntilTimeout(hi2c, I2C_FLAG_TCR, RESET, Timeout) != HAL_OK)
- I2C_TransferConfig(hi2c,DevAddress,MAX_NBYTE_SIZE, I2C_RELOAD_MODE, I2C_NO_STARTSTOP);
- else
- I2C_TransferConfig(hi2c,DevAddress,Size, I2C_AUTOEND_MODE, I2C_NO_STARTSTOP);
- sizetmp = Size;
- /* No need to Check TC flag, with AUTOEND mode the stop is automatically generated */
- /* Wait until STOPF flag is set */
- if(I2C_WaitOnSTOPFlagUntilTimeout(hi2c, Timeout) != HAL_OK)
- return HAL_ERROR;
- else
- /* Clear STOP Flag */
- __HAL_I2C_CLEAR_FLAG(hi2c, I2C_FLAG_STOPF);
- /* Clear Configuration Register 2 */
- I2C_RESET_CR2(hi2c);
- /* Process Unlocked */
- return HAL_OK;
- else
- return HAL_BUSY;
- * @brief Receives in master mode an amount of data in blocking mode.
- HAL_StatusTypeDef HAL_I2C_Master_Receive(I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint8_t *pData, uint16_t Size, uint32_t Timeout)
- return HAL_BUSY;
- __HAL_LOCK(hi2c);
- hi2c->State = HAL_I2C_STATE_BUSY_RX;
- I2C_TransferConfig(hi2c, DevAddress, MAX_NBYTE_SIZE, I2C_RELOAD_MODE, I2C_GENERATE_START_READ);
- else if(Size > 0)
- I2C_TransferConfig(hi2c, DevAddress, Size, I2C_AUTOEND_MODE, I2C_GENERATE_START_READ);
- sizetmp = Size;
- else
- I2C_TransferConfig(hi2c, DevAddress, Size, I2C_SOFTEND_MODE, I2C_GENERATE_START_READ);
- sizetmp = Size;
- /* Wait until TC flag is set */
- if(I2C_WaitOnFlagUntilTimeout(hi2c, I2C_FLAG_TC, RESET, Timeout) != HAL_OK)
- else
- /* Generate a Stop command */
- hi2c->Instance->CR2 |= I2C_CR2_STOP;
- while(Size > 0)
- /* Wait until RXNE flag is set */
- if(I2C_WaitOnRXNEFlagUntilTimeout(hi2c, I2C_FLAG_RXNE) != HAL_OK)
- return HAL_ERROR;
- else
- /* Write data to RXDR */
- (*pData++) =hi2c->Instance->RXDR;
- sizetmp--;
- Size--;
- I2C_TransferConfig(hi2c, DevAddress, MAX_NBYTE_SIZE, I2C_RELOAD_MODE, I2C_NO_STARTSTOP);
- else
- I2C_TransferConfig(hi2c, DevAddress, Size, I2C_AUTOEND_MODE, I2C_NO_STARTSTOP);
- sizetmp = Size;
- if(I2C_WaitOnSTOPFlagUntilTimeout(hi2c, I2C_TIMEOUT_STOPF) != HAL_OK)
- return HAL_ERROR;
- else
- return HAL_OK;
- else
- return HAL_BUSY;
- * @brief Transmits in slave mode an amount of data in blocking mode.
- HAL_StatusTypeDef HAL_I2C_Slave_Transmit(I2C_HandleTypeDef *hi2c, uint8_t *pData, uint16_t Size, uint32_t Timeout)
- if((pData == NULL) || (Size == 0))
- return HAL_ERROR;
- __HAL_LOCK(hi2c);
- hi2c->Mode = HAL_I2C_MODE_SLAVE;
- /* Enable Address Acknowledge */
- hi2c->Instance->CR2 &= ~I2C_CR2_NACK;
- /* Wait until ADDR flag is set */
- if(I2C_WaitOnFlagUntilTimeout(hi2c, I2C_FLAG_ADDR, RESET, Timeout) != HAL_OK)
- /* Disable Address Acknowledge */
- hi2c->Instance->CR2 |= I2C_CR2_NACK;
- /* Clear ADDR flag */
- __HAL_I2C_CLEAR_FLAG(hi2c,I2C_FLAG_ADDR);
- /* If 10bit addressing mode is selected */
- /* Wait until DIR flag is set Transmitter mode */
- if(I2C_WaitOnFlagUntilTimeout(hi2c, I2C_FLAG_DIR, RESET, Timeout) != HAL_OK)
- while(Size > 0)
- return HAL_ERROR;
- else
- /* Read data from TXDR */
- Size--;
- /* Wait until STOP flag is set */
- /* Normal use case for Transmitter mode */
- /* A NACK is generated to confirm the end of transfer */
- else
- /* Clear STOP flag */
- __HAL_I2C_CLEAR_FLAG(hi2c,I2C_FLAG_STOPF);
- /* Wait until BUSY flag is reset */
- if(I2C_WaitOnFlagUntilTimeout(hi2c, I2C_FLAG_BUSY, SET, Timeout) != HAL_OK)
- return HAL_OK;
- else
- return HAL_BUSY;
- * @brief Receive in slave mode an amount of data in blocking mode
- HAL_StatusTypeDef HAL_I2C_Slave_Receive(I2C_HandleTypeDef *hi2c, uint8_t *pData, uint16_t Size, uint32_t Timeout)
- return HAL_ERROR;
- __HAL_LOCK(hi2c);
- /* Wait until DIR flag is reset Receiver mode */
- if(I2C_WaitOnFlagUntilTimeout(hi2c, I2C_FLAG_DIR, SET, Timeout) != HAL_OK)
- while(Size > 0)
- if(I2C_WaitOnRXNEFlagUntilTimeout(hi2c, Timeout) != HAL_OK)
- /* Store Last receive data if any */
- if(__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_RXNE) == SET)
- /* Read data from RXDR */
- (*pData++) = hi2c->Instance->RXDR;
- if(hi2c->ErrorCode == HAL_I2C_ERROR_TIMEOUT)
- else
- return HAL_ERROR;
- Size--;
- return HAL_ERROR;
- else
- return HAL_OK;
- else
- return HAL_BUSY;
- * @brief Transmit in master mode an amount of data in non-blocking mode with Interrupt
- HAL_StatusTypeDef HAL_I2C_Master_Transmit_IT(I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint8_t *pData, uint16_t Size)
- return HAL_BUSY;
- __HAL_LOCK(hi2c);
- hi2c->pBuffPtr = pData;
- hi2c->XferCount = Size;
- hi2c->XferSize = MAX_NBYTE_SIZE;
- else
- hi2c->XferSize = Size;
- if( (hi2c->XferSize == MAX_NBYTE_SIZE) && (hi2c->XferSize < hi2c->XferCount) )
- I2C_TransferConfig(hi2c, DevAddress, hi2c->XferSize, I2C_RELOAD_MODE, I2C_GENERATE_START_WRITE);
- else
- I2C_TransferConfig(hi2c, DevAddress, hi2c->XferSize, I2C_AUTOEND_MODE, I2C_GENERATE_START_WRITE);
- /* Note : The I2C interrupts must be enabled after unlocking current process
- to avoid the risk of I2C interrupt handle execution before current
- process unlock */
- /* Enable ERR, TC, STOP, NACK, TXI interrupt */
- /* possible to enable all of these */
- /* I2C_IT_ERRI | I2C_IT_TCI| I2C_IT_STOPI| I2C_IT_NACKI | I2C_IT_ADDRI | I2C_IT_RXI | I2C_IT_TXI */
- __HAL_I2C_ENABLE_IT(hi2c,I2C_IT_ERRI | I2C_IT_TCI| I2C_IT_STOPI| I2C_IT_NACKI | I2C_IT_TXI );
- return HAL_OK;
- else
- return HAL_BUSY;
- * @brief Receive in master mode an amount of data in non-blocking mode with Interrupt
- HAL_StatusTypeDef HAL_I2C_Master_Receive_IT(I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint8_t *pData, uint16_t Size)
- return HAL_BUSY;
- __HAL_LOCK(hi2c);
- else
- I2C_TransferConfig(hi2c, DevAddress, hi2c->XferSize, I2C_RELOAD_MODE, I2C_GENERATE_START_READ);
- else
- I2C_TransferConfig(hi2c, DevAddress, hi2c->XferSize, I2C_AUTOEND_MODE, I2C_GENERATE_START_READ);
- process unlock */
- /* Enable ERR, TC, STOP, NACK, RXI interrupt */
- __HAL_I2C_ENABLE_IT(hi2c,I2C_IT_ERRI | I2C_IT_TCI | I2C_IT_STOPI | I2C_IT_NACKI | I2C_IT_RXI );
- return HAL_OK;
- else
- return HAL_BUSY;
- * @brief Transmit in slave mode an amount of data in non-blocking mode with Interrupt
- HAL_StatusTypeDef HAL_I2C_Slave_Transmit_IT(I2C_HandleTypeDef *hi2c, uint8_t *pData, uint16_t Size)
- return HAL_ERROR;
- __HAL_LOCK(hi2c);
- process unlock */
- __HAL_I2C_ENABLE_IT(hi2c,I2C_IT_ERRI | I2C_IT_TCI| I2C_IT_STOPI | I2C_IT_NACKI | I2C_IT_ADDRI | I2C_IT_TXI );
- return HAL_OK;
- else
- return HAL_BUSY;
- * @brief Receive in slave mode an amount of data in non-blocking mode with Interrupt
- HAL_StatusTypeDef HAL_I2C_Slave_Receive_IT(I2C_HandleTypeDef *hi2c, uint8_t *pData, uint16_t Size)
- return HAL_ERROR;
- __HAL_LOCK(hi2c);
- process unlock */
- __HAL_I2C_ENABLE_IT(hi2c,I2C_IT_ERRI | I2C_IT_TCI | I2C_IT_STOPI | I2C_IT_NACKI | I2C_IT_ADDRI | I2C_IT_RXI);
- return HAL_OK;
- else
- return HAL_BUSY;
- * @brief Transmit in master mode an amount of data in non-blocking mode with DMA
- HAL_StatusTypeDef HAL_I2C_Master_Transmit_DMA(I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint8_t *pData, uint16_t Size)
- return HAL_BUSY;
- __HAL_LOCK(hi2c);
- else
- if(hi2c->XferSize > 0)
- /* Set the I2C DMA transfer complete callback */
- hi2c->hdmatx->XferCpltCallback = I2C_DMAMasterTransmitCplt;
- /* Set the DMA error callback */
- hi2c->hdmatx->XferErrorCallback = I2C_DMAError;
- /* Enable the DMA channel */
- HAL_DMA_Start_IT(hi2c->hdmatx, (uint32_t)pData, (uint32_t)&hi2c->Instance->TXDR, hi2c->XferSize);
- else
- if(I2C_WaitOnTXISFlagUntilTimeout(hi2c, I2C_TIMEOUT_TXIS) != HAL_OK)
- /* Abort DMA */
- HAL_DMA_Abort(hi2c->hdmatx);
- return HAL_ERROR;
- else
- /* Enable DMA Request */
- hi2c->Instance->CR1 |= I2C_CR1_TXDMAEN;
- else
- return HAL_ERROR;
- else
- return HAL_OK;
- else
- return HAL_BUSY;
- * @brief Receive in master mode an amount of data in non-blocking mode with DMA
- HAL_StatusTypeDef HAL_I2C_Master_Receive_DMA(I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint8_t *pData, uint16_t Size)
- return HAL_BUSY;
- __HAL_LOCK(hi2c);
- else
- hi2c->hdmarx->XferCpltCallback = I2C_DMAMasterReceiveCplt;
- hi2c->hdmarx->XferErrorCallback = I2C_DMAError;
- HAL_DMA_Start_IT(hi2c->hdmarx, (uint32_t)&hi2c->Instance->RXDR, (uint32_t)pData, hi2c->XferSize);
- else
- /* Abort DMA */
- HAL_DMA_Abort(hi2c->hdmarx);
- return HAL_ERROR;
- else
- hi2c->Instance->CR1 |= I2C_CR1_RXDMAEN;
- else
- if(I2C_WaitOnFlagUntilTimeout(hi2c, I2C_FLAG_TC, RESET, I2C_TIMEOUT_TC) != HAL_OK)
- else
- return HAL_OK;
- else
- return HAL_BUSY;
- * @brief Transmit in slave mode an amount of data in non-blocking mode with DMA
- HAL_StatusTypeDef HAL_I2C_Slave_Transmit_DMA(I2C_HandleTypeDef *hi2c, uint8_t *pData, uint16_t Size)
- return HAL_ERROR;
- __HAL_LOCK(hi2c);
- hi2c->hdmatx->XferCpltCallback = I2C_DMASlaveTransmitCplt;
- if(I2C_WaitOnFlagUntilTimeout(hi2c, I2C_FLAG_ADDR, RESET, I2C_TIMEOUT_ADDR) != HAL_OK)
- /* If 10bits addressing mode is selected */
- if(I2C_WaitOnFlagUntilTimeout(hi2c, I2C_FLAG_DIR, RESET, I2C_TIMEOUT_BUSY) != HAL_OK)
- return HAL_OK;
- else
- return HAL_BUSY;
- * @brief Receive in slave mode an amount of data in non-blocking mode with DMA
- HAL_StatusTypeDef HAL_I2C_Slave_Receive_DMA(I2C_HandleTypeDef *hi2c, uint8_t *pData, uint16_t Size)
- return HAL_ERROR;
- __HAL_LOCK(hi2c);
- hi2c->hdmarx->XferCpltCallback = I2C_DMASlaveReceiveCplt;
- HAL_DMA_Start_IT(hi2c->hdmarx, (uint32_t)&hi2c->Instance->RXDR, (uint32_t)pData, Size);
- /* Wait until DIR flag is set Receiver mode */
- if(I2C_WaitOnFlagUntilTimeout(hi2c, I2C_FLAG_DIR, SET, I2C_TIMEOUT_DIR) != HAL_OK)
- return HAL_OK;
- else
- return HAL_BUSY;
- * @brief Write an amount of data in blocking mode to a specific memory address
- * @param MemAddress Internal memory address
- * @param MemAddSize Size of internal memory address
- HAL_StatusTypeDef HAL_I2C_Mem_Write(I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint16_t MemAddress, uint16_t MemAddSize, uint8_t *pData, uint16_t Size, uint32_t Timeout)
- uint32_t Sizetmp = 0;
- assert_param(IS_I2C_MEMADD_SIZE(MemAddSize));
- return HAL_ERROR;
- return HAL_BUSY;
- __HAL_LOCK(hi2c);
- hi2c->Mode = HAL_I2C_MODE_MEM;
- /* Send Slave Address and Memory Address */
- if(I2C_RequestMemoryWrite(hi2c, DevAddress, MemAddress, MemAddSize, Timeout) != HAL_OK)
- return HAL_ERROR;
- else
- /* Set NBYTES to write and reload if size > MAX_NBYTE_SIZE */
- Sizetmp = MAX_NBYTE_SIZE;
- else
- Sizetmp = Size;
- do
- return HAL_ERROR;
- else
- /* Write data to DR */
- Sizetmp--;
- Size--;
- if((Sizetmp == 0)&&(Size!=0))
- else
- Sizetmp = Size;
- }while(Size > 0);
- /* Wait until STOPF flag is reset */
- return HAL_ERROR;
- else
- return HAL_OK;
- else
- return HAL_BUSY;
- * @brief Read an amount of data in blocking mode from a specific memory address
- HAL_StatusTypeDef HAL_I2C_Mem_Read(I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint16_t MemAddress, uint16_t MemAddSize, uint8_t *pData, uint16_t Size, uint32_t Timeout)
- return HAL_ERROR;
- return HAL_BUSY;
- __HAL_LOCK(hi2c);
- if(I2C_RequestMemoryRead(hi2c, DevAddress, MemAddress, MemAddSize, Timeout) != HAL_OK)
- return HAL_ERROR;
- else
- else
- Sizetmp = Size;
- do
- if(I2C_WaitOnFlagUntilTimeout(hi2c, I2C_FLAG_RXNE, RESET, Timeout) != HAL_OK)
- /* Decrement the Size counter */
- Sizetmp--;
- Size--;
- else
- Sizetmp = Size;
- }while(Size > 0);
- return HAL_ERROR;
- else
- return HAL_OK;
- else
- return HAL_BUSY;
- * @brief Write an amount of data in non-blocking mode with Interrupt to a specific memory address
- HAL_StatusTypeDef HAL_I2C_Mem_Write_IT(I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint16_t MemAddress, uint16_t MemAddSize, uint8_t *pData, uint16_t Size)
- return HAL_ERROR;
- return HAL_BUSY;
- __HAL_LOCK(hi2c);
- else
- if(I2C_RequestMemoryWrite(hi2c, DevAddress, MemAddress, MemAddSize, I2C_TIMEOUT_FLAG) != HAL_OK)
- return HAL_ERROR;
- else
- I2C_TransferConfig(hi2c, DevAddress, hi2c->XferSize, I2C_RELOAD_MODE, I2C_NO_STARTSTOP);
- else
- I2C_TransferConfig(hi2c, DevAddress, hi2c->XferSize, I2C_AUTOEND_MODE, I2C_NO_STARTSTOP);
- process unlock */
- return HAL_OK;
- else
- return HAL_BUSY;
- * @brief Read an amount of data in non-blocking mode with Interrupt from a specific memory address
- HAL_StatusTypeDef HAL_I2C_Mem_Read_IT(I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint16_t MemAddress, uint16_t MemAddSize, uint8_t *pData, uint16_t Size)
- return HAL_ERROR;
- return HAL_BUSY;
- __HAL_LOCK(hi2c);
- else
- if(I2C_RequestMemoryRead(hi2c, DevAddress, MemAddress, MemAddSize, I2C_TIMEOUT_FLAG) != HAL_OK)
- return HAL_ERROR;
- else
- else
- process unlock */
- __HAL_I2C_ENABLE_IT(hi2c, I2C_IT_ERRI | I2C_IT_TCI| I2C_IT_STOPI| I2C_IT_NACKI | I2C_IT_RXI );
- return HAL_OK;
- else
- return HAL_BUSY;
- * @brief Write an amount of data in non-blocking mode with DMA to a specific memory address
- HAL_StatusTypeDef HAL_I2C_Mem_Write_DMA(I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint16_t MemAddress, uint16_t MemAddSize, uint8_t *pData, uint16_t Size)
- return HAL_ERROR;
- return HAL_BUSY;
- __HAL_LOCK(hi2c);
- else
- hi2c->hdmatx->XferCpltCallback = I2C_DMAMemTransmitCplt;
- return HAL_ERROR;
- else
- else
- return HAL_ERROR;
- else
- return HAL_OK;
- else
- return HAL_BUSY;
- * @brief Reads an amount of data in non-blocking mode with DMA from a specific memory address.
- * @param Size Amount of data to be read
- HAL_StatusTypeDef HAL_I2C_Mem_Read_DMA(I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint16_t MemAddress, uint16_t MemAddSize, uint8_t *pData, uint16_t Size)
- return HAL_ERROR;
- return HAL_BUSY;
- __HAL_LOCK(hi2c);
- else
- hi2c->hdmarx->XferCpltCallback = I2C_DMAMemReceiveCplt;
- return HAL_ERROR;
- else
- else
- if(I2C_WaitOnFlagUntilTimeout(hi2c, I2C_FLAG_RXNE, RESET, I2C_TIMEOUT_RXNE) != HAL_OK)
- return HAL_OK;
- else
- return HAL_BUSY;
- * @brief Checks if target device is ready for communication.
- * @note This function is used with Memory devices
- * @param Trials Number of trials
- HAL_StatusTypeDef HAL_I2C_IsDeviceReady(I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint32_t Trials, uint32_t Timeout)
- uint32_t tickstart = 0;
- __IO uint32_t I2C_Trials = 0;
- return HAL_BUSY;
- __HAL_LOCK(hi2c);
- do
- /* Generate Start */
- hi2c->Instance->CR2 = I2C_GENERATE_START(hi2c->Init.AddressingMode,DevAddress);
- /* Wait until STOPF flag is set or a NACK flag is set*/
- tickstart = HAL_GetTick();
- while((__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_STOPF) == RESET) && (__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_AF) == RESET) && (hi2c->State != HAL_I2C_STATE_TIMEOUT))
- if(Timeout != HAL_MAX_DELAY)
- if((Timeout == 0) || ((HAL_GetTick() - tickstart) > Timeout))
- /* Device is ready */
- /* Check if the NACKF flag has not been set */
- if (__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_AF) == RESET)
- if(I2C_WaitOnFlagUntilTimeout(hi2c, I2C_FLAG_STOPF, RESET, Timeout) != HAL_OK)
- return HAL_OK;
- else
- /* Clear NACK Flag */
- __HAL_I2C_CLEAR_FLAG(hi2c, I2C_FLAG_AF);
- /* Clear STOP Flag, auto generated with autoend*/
- /* Check if the maximum allowed number of trials has been reached */
- if (I2C_Trials++ == Trials)
- /* Generate Stop */
- }while(I2C_Trials < Trials);
- else
- return HAL_BUSY;
- /** @defgroup I2C_IRQ_Handler_and_Callbacks IRQ Handler and Callbacks
- * @brief This function handles I2C event interrupt request.
- * @retval None
- void HAL_I2C_EV_IRQHandler(I2C_HandleTypeDef *hi2c)
- /* I2C in mode Transmitter ---------------------------------------------------*/
- if (((__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_TXIS) == SET) || (__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_TCR) == SET) || (__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_TC) == SET) || (__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_STOPF) == SET) || (__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_AF) == SET) || (__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_ADDR) == SET)) && (__HAL_I2C_GET_IT_SOURCE(hi2c, (I2C_IT_TCI | I2C_IT_STOPI | I2C_IT_NACKI | I2C_IT_TXI | I2C_IT_ADDRI)) == SET))
- /* Slave mode selected */
- if (hi2c->Mode == HAL_I2C_MODE_SLAVE)
- I2C_SlaveTransmit_ISR(hi2c);
- if (((__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_TXIS) == SET) || (__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_TCR) == SET) || (__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_TC) == SET) || (__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_STOPF) == SET) || (__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_AF) == SET)) && (__HAL_I2C_GET_IT_SOURCE(hi2c, (I2C_IT_TCI | I2C_IT_STOPI | I2C_IT_NACKI | I2C_IT_TXI)) == SET))
- /* Master or Memory mode selected */
- if ((hi2c->Mode == HAL_I2C_MODE_MASTER) || (hi2c->Mode == HAL_I2C_MODE_MEM))
- I2C_MasterTransmit_ISR(hi2c);
- /* I2C in mode Receiver ----------------------------------------------------*/
- if (((__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_RXNE) == SET) || (__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_TCR) == SET) || (__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_TC) == SET) || (__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_STOPF) == SET) || (__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_AF) == SET) || (__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_ADDR) == SET)) && (__HAL_I2C_GET_IT_SOURCE(hi2c, (I2C_IT_TCI| I2C_IT_STOPI| I2C_IT_NACKI | I2C_IT_RXI | I2C_IT_ADDRI)) == SET))
- I2C_SlaveReceive_ISR(hi2c);
- if (((__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_RXNE) == SET) || (__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_TCR) == SET) || (__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_TC) == SET) || (__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_STOPF) == SET) || (__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_AF) == SET)) && (__HAL_I2C_GET_IT_SOURCE(hi2c, (I2C_IT_TCI| I2C_IT_STOPI| I2C_IT_NACKI | I2C_IT_RXI)) == SET))
- I2C_MasterReceive_ISR(hi2c);
- * @brief This function handles I2C error interrupt request.
- * @retval None
- void HAL_I2C_ER_IRQHandler(I2C_HandleTypeDef *hi2c)
- /* I2C Bus error interrupt occurred ------------------------------------*/
- if((__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_BERR) == SET) && (__HAL_I2C_GET_IT_SOURCE(hi2c, I2C_IT_ERRI) == SET))
- hi2c->ErrorCode |= HAL_I2C_ERROR_BERR;
- /* Clear BERR flag */
- __HAL_I2C_CLEAR_FLAG(hi2c, I2C_FLAG_BERR);
- /* I2C Over-Run/Under-Run interrupt occurred ----------------------------------------*/
- if((__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_OVR) == SET) && (__HAL_I2C_GET_IT_SOURCE(hi2c, I2C_IT_ERRI) == SET))
- hi2c->ErrorCode |= HAL_I2C_ERROR_OVR;
- /* Clear OVR flag */
- __HAL_I2C_CLEAR_FLAG(hi2c, I2C_FLAG_OVR);
- /* I2C Arbitration Loss error interrupt occurred -------------------------------------*/
- if((__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_ARLO) == SET) && (__HAL_I2C_GET_IT_SOURCE(hi2c, I2C_IT_ERRI) == SET))
- hi2c->ErrorCode |= HAL_I2C_ERROR_ARLO;
- /* Clear ARLO flag */
- __HAL_I2C_CLEAR_FLAG(hi2c, I2C_FLAG_ARLO);
- /* Call the Error Callback in case of Error detected */
- if((hi2c->ErrorCode & (HAL_I2C_ERROR_BERR | HAL_I2C_ERROR_OVR | HAL_I2C_ERROR_ARLO)) != HAL_I2C_ERROR_NONE)
- HAL_I2C_ErrorCallback(hi2c);
- * @brief Master Tx Transfer completed callback.
- * @retval None
- __weak void HAL_I2C_MasterTxCpltCallback(I2C_HandleTypeDef *hi2c)
- UNUSED(hi2c);
- the HAL_I2C_TxCpltCallback could be implemented in the user file
- * @brief Master Rx Transfer completed callback.
- * @retval None
- __weak void HAL_I2C_MasterRxCpltCallback(I2C_HandleTypeDef *hi2c)
- UNUSED(hi2c);
- /** @brief Slave Tx Transfer completed callback.
- * @retval None
- __weak void HAL_I2C_SlaveTxCpltCallback(I2C_HandleTypeDef *hi2c)
- UNUSED(hi2c);
- * @brief Slave Rx Transfer completed callback.
- * @retval None
- __weak void HAL_I2C_SlaveRxCpltCallback(I2C_HandleTypeDef *hi2c)
- UNUSED(hi2c);
- * @brief Memory Tx Transfer completed callback.
- * @retval None
- __weak void HAL_I2C_MemTxCpltCallback(I2C_HandleTypeDef *hi2c)
- UNUSED(hi2c);
- * @brief Memory Rx Transfer completed callback.
- * @retval None
- __weak void HAL_I2C_MemRxCpltCallback(I2C_HandleTypeDef *hi2c)
- UNUSED(hi2c);
- * @brief I2C error callback.
- * @retval None
- __weak void HAL_I2C_ErrorCallback(I2C_HandleTypeDef *hi2c)
- UNUSED(hi2c);
- the HAL_I2C_ErrorCallback could be implemented in the user file
- /** @defgroup I2C_Exported_Functions_Group3 Peripheral State, Mode and Error functions
- * @brief Peripheral State, Mode and Error functions
- @verbatim
- ##### Peripheral State, Mode and Error functions #####
- This subsection permit to get in run-time the status of the peripheral
- and the data flow.
- @endverbatim
- * @brief Return the I2C handle state.
- * @retval HAL state
- HAL_I2C_StateTypeDef HAL_I2C_GetState(I2C_HandleTypeDef *hi2c)
- /* Return I2C handle state */
- return hi2c->State;
- * @brief Returns the I2C Master, Slave, Memory or no mode.
- * the configuration information for I2C module
- * @retval HAL mode
- HAL_I2C_ModeTypeDef HAL_I2C_GetMode(I2C_HandleTypeDef *hi2c)
- return hi2c->Mode;
- * @brief Return the I2C error code.
- * @retval I2C Error Code
- uint32_t HAL_I2C_GetError(I2C_HandleTypeDef *hi2c)
- return hi2c->ErrorCode;
- /** @addtogroup I2C_Private_Functions
- * @brief Handle Interrupt Flags Master Transmit Mode
- uint16_t DevAddress;
- __HAL_LOCK(hi2c);
- if(__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_TXIS) == SET)
- hi2c->Instance->TXDR = (*hi2c->pBuffPtr++);
- hi2c->XferSize--;
- hi2c->XferCount--;
- else if(__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_TCR) == SET)
- if((hi2c->XferSize == 0)&&(hi2c->XferCount!=0))
- DevAddress = (hi2c->Instance->CR2 & I2C_CR2_SADD);
- if(hi2c->XferCount > MAX_NBYTE_SIZE)
- else
- I2C_TransferConfig(hi2c, DevAddress, hi2c->XferCount, I2C_AUTOEND_MODE, I2C_NO_STARTSTOP);
- hi2c->XferSize = hi2c->XferCount;
- else
- /* Wrong size Status regarding TCR flag event */
- hi2c->ErrorCode |= HAL_I2C_ERROR_SIZE;
- else if(__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_TC) == SET)
- if(hi2c->XferCount == 0)
- else
- else if(__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_STOPF) == SET)
- if(__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_AF) == SET)
- hi2c->ErrorCode |= HAL_I2C_ERROR_AF;
- /* Disable ERR, TC, STOP, NACK, TXI interrupts */
- __HAL_I2C_DISABLE_IT(hi2c,I2C_IT_ERRI | I2C_IT_TCI| I2C_IT_STOPI| I2C_IT_NACKI | I2C_IT_TXI );
- /* Flush TX register if not empty */
- if(__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_TXE) == RESET)
- __HAL_I2C_CLEAR_FLAG(hi2c, I2C_FLAG_TXE);
- /* Call the correct callback to inform upper layer */
- if(hi2c->ErrorCode != HAL_I2C_ERROR_NONE)
- else
- if (hi2c->Mode == HAL_I2C_MODE_MEM)
- HAL_I2C_MemTxCpltCallback(hi2c);
- else
- HAL_I2C_MasterTxCpltCallback(hi2c);
- else if(__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_AF) == SET)
- return HAL_OK;
- * @brief Handle Interrupt Flags Master Receive Mode
- __HAL_LOCK(hi2c);
- (*hi2c->pBuffPtr++) = hi2c->Instance->RXDR;
- hi2c->XferSize--;
- else
- else
- else
- /* Disable ERR, TC, STOP, NACK, RXI interrupts */
- __HAL_I2C_DISABLE_IT(hi2c,I2C_IT_ERRI | I2C_IT_TCI| I2C_IT_STOPI| I2C_IT_NACKI | I2C_IT_RXI );
- else
- HAL_I2C_MemRxCpltCallback(hi2c);
- else
- HAL_I2C_MasterRxCpltCallback(hi2c);
- return HAL_OK;
- * @brief Handle Interrupt Flags Slave Transmit Mode
- /* Process locked */
- __HAL_LOCK(hi2c);
- if(__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_AF) != RESET)
- /* Check that I2C transfer finished */
- /* if yes, normal usecase, a NACK is sent by the MASTER when Transfer is finished */
- /* Mean XferCount == 0*/
- /* So clear Flag NACKF only */
- else
- /* if no, error usecase, a Non-Acknowledge of last Data is generated by the MASTER*/
- /* Set ErrorCode corresponding to a Non-Acknowledge */
- /* Call the Error callback to prevent upper layer */
- else if(__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_ADDR) == SET)
- __HAL_I2C_CLEAR_FLAG(hi2c, I2C_FLAG_ADDR);
- /* Check first if STOPF is set */
- /* to prevent a Write Data in TX buffer */
- /* which is stuck in TXDR until next */
- /* communication with Master */
- /* Disable ERRI, TCI, STOPI, NACKI, ADDRI, RXI, TXI interrupts */
- __HAL_I2C_DISABLE_IT(hi2c,I2C_IT_ERRI | I2C_IT_TCI| I2C_IT_STOPI| I2C_IT_NACKI | I2C_IT_ADDRI | I2C_IT_RXI | I2C_IT_TXI );
- HAL_I2C_SlaveTxCpltCallback(hi2c);
- else if(__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_TXIS) == SET)
- /* Write data to TXDR only if XferCount not reach "0" */
- /* A TXIS flag can be set, during STOP treatment */
- if(hi2c->XferCount > 0)
- return HAL_OK;
- * @brief Handle Interrupt Flags Slave Receive Mode
- __HAL_LOCK(hi2c);
- else if(__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_RXNE) == SET)
- hi2c->XferSize--;
- __HAL_I2C_DISABLE_IT(hi2c, I2C_IT_ERRI | I2C_IT_TCI | I2C_IT_STOPI | I2C_IT_NACKI | I2C_IT_ADDRI | I2C_IT_RXI | I2C_IT_TXI);
- HAL_I2C_SlaveRxCpltCallback(hi2c);
- return HAL_OK;
- * @brief Master sends target device address followed by internal memory address for write request.
- I2C_TransferConfig(hi2c, DevAddress, MemAddSize, I2C_RELOAD_MODE, I2C_GENERATE_START_WRITE);
- return HAL_ERROR;
- else
- /* If Memory address size is 8Bit */
- if(MemAddSize == I2C_MEMADD_SIZE_8BIT)
- /* Send Memory Address */
- hi2c->Instance->TXDR = I2C_MEM_ADD_LSB(MemAddress);
- /* If Memory address size is 16Bit */
- else
- /* Send MSB of Memory Address */
- hi2c->Instance->TXDR = I2C_MEM_ADD_MSB(MemAddress);
- return HAL_ERROR;
- else
- /* Send LSB of Memory Address */
- return HAL_OK;
- * @brief Master sends target device address followed by internal memory address for read request.
- I2C_TransferConfig(hi2c, DevAddress, MemAddSize, I2C_SOFTEND_MODE, I2C_GENERATE_START_WRITE);
- return HAL_ERROR;
- else
- else
- return HAL_ERROR;
- else
- return HAL_OK;
- * @brief DMA I2C master transmit process complete callback.
- * @param hdma DMA handle
- * @retval None
- I2C_HandleTypeDef* hi2c = (I2C_HandleTypeDef*)((DMA_HandleTypeDef*)hdma)->Parent;
- /* Check if last DMA request was done with RELOAD */
- if(I2C_WaitOnFlagUntilTimeout(hi2c, I2C_FLAG_TCR, RESET, I2C_TIMEOUT_TCR) != HAL_OK)
- hi2c->ErrorCode |= HAL_I2C_ERROR_TIMEOUT;
- /* Disable DMA Request */
- hi2c->Instance->CR1 &= ~I2C_CR1_TXDMAEN;
- /* Check if Errors has been detected during transfer */
- else
- hi2c->XferCount = 0;
- else
- hi2c->pBuffPtr += hi2c->XferSize;
- hi2c->XferCount -= hi2c->XferSize;
- else
- HAL_DMA_Start_IT(hi2c->hdmatx, (uint32_t)hi2c->pBuffPtr, (uint32_t)&hi2c->Instance->TXDR, hi2c->XferSize);
- else
- else
- else
- else
- else
- else
- * @brief DMA I2C slave transmit process complete callback.
- * @retval None
- /* Normal Use case, a AF is generated by master */
- /* to inform slave the end of transfer */
- else
- if(I2C_WaitOnFlagUntilTimeout(hi2c, I2C_FLAG_BUSY, SET, I2C_TIMEOUT_BUSY) != HAL_OK)
- else
- * @brief DMA I2C master receive process complete callback
- * @retval None
- hi2c->Instance->CR1 &= ~I2C_CR1_RXDMAEN;
- else
- else
- else
- HAL_DMA_Start_IT(hi2c->hdmarx, (uint32_t)&hi2c->Instance->RXDR, (uint32_t)hi2c->pBuffPtr, hi2c->XferSize);
- else
- else
- else
- else
- else
- else
- * @brief DMA I2C slave receive process complete callback.
- * @retval None
- else
- /* Clear STOPF flag */
- else
- * @brief DMA I2C Memory Write process complete callback
- * @retval None
- I2C_HandleTypeDef* hi2c = ( I2C_HandleTypeDef* )((DMA_HandleTypeDef* )hdma)->Parent;
- else
- else
- else
- else
- else
- else
- else
- else
- else
- * @brief DMA I2C Memory Read process complete callback
- * @retval None
- else
- else
- else
- else
- else
- else
- else
- else
- else
- * @brief DMA I2C communication error callback.
- * @retval None
- /* Disable Acknowledge */
- hi2c->ErrorCode |= HAL_I2C_ERROR_DMA;
- * @brief This function handles I2C Communication Timeout.
- * @param Flag Specifies the I2C flag to check.
- * @param Status The new Flag status (SET or RESET).
- uint32_t tickstart = HAL_GetTick();
- /* Wait until flag is set */
- if(Status == RESET)
- while(__HAL_I2C_GET_FLAG(hi2c, Flag) == RESET)
- /* Check for the Timeout */
- hi2c->State= HAL_I2C_STATE_READY;
- else
- while(__HAL_I2C_GET_FLAG(hi2c, Flag) != RESET)
- return HAL_OK;
- * @brief This function handles I2C Communication Timeout for specific usage of TXIS flag.
- while(__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_TXIS) == RESET)
- /* Check if a NACK is detected */
- if(I2C_IsAcknowledgeFailed(hi2c, Timeout) != HAL_OK)
- return HAL_ERROR;
- return HAL_OK;
- * @brief This function handles I2C Communication Timeout for specific usage of STOP flag.
- uint32_t tickstart = 0x00;
- while(__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_STOPF) == RESET)
- return HAL_ERROR;
- return HAL_OK;
- * @brief This function handles I2C Communication Timeout for specific usage of RXNE flag.
- while(__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_RXNE) == RESET)
- return HAL_ERROR;
- /* Check if a STOPF is detected */
- if(__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_STOPF) == SET)
- return HAL_ERROR;
- return HAL_OK;
- * @brief This function handles Acknowledge failed detection during an I2C Communication.
- /* Wait until STOP Flag is reset */
- /* AutoEnd should be initiate after AF */
- /* Clear NACKF Flag */
- hi2c->ErrorCode = HAL_I2C_ERROR_AF;
- return HAL_ERROR;
- return HAL_OK;
- * @brief Handles I2Cx communication when starting transfer or during transfer (TC or TCR flag are set).
- * @param hi2c I2C handle.
- * @param DevAddress Specifies the slave address to be programmed.
- * @param Size Specifies the number of bytes to be programmed.
- * This parameter must be a value between 0 and MAX_NBYTE_SIZE.
- * @param Mode New state of the I2C START condition generation.
- * This parameter can be one of the following values:
- * @arg @ref I2C_RELOAD_MODE Enable Reload mode .
- * @arg @ref I2C_AUTOEND_MODE Enable Automatic end mode.
- * @arg @ref I2C_SOFTEND_MODE Enable Software end mode.
- * @param Request New state of the I2C START condition generation.
- * @arg @ref I2C_NO_STARTSTOP Don't Generate stop and start condition.
- * @arg @ref I2C_GENERATE_STOP Generate stop condition (Size should be set to 0).
- * @arg @ref I2C_GENERATE_START_READ Generate Restart for read request.
- * @arg @ref I2C_GENERATE_START_WRITE Generate Restart for write request.
- * @retval None
- uint32_t tmpreg = 0;
- assert_param(IS_TRANSFER_MODE(Mode));
- assert_param(IS_TRANSFER_REQUEST(Request));
- /* Get the CR2 register value */
- tmpreg = hi2c->Instance->CR2;
- /* clear tmpreg specific bits */
- tmpreg &= (uint32_t)~((uint32_t)(I2C_CR2_SADD | I2C_CR2_NBYTES | I2C_CR2_RELOAD | I2C_CR2_AUTOEND | I2C_CR2_RD_WRN | I2C_CR2_START | I2C_CR2_STOP));
- /* update tmpreg */
- tmpreg |= (uint32_t)(((uint32_t)DevAddress & I2C_CR2_SADD) | (((uint32_t)Size << 16 ) & I2C_CR2_NBYTES) | \
- (uint32_t)Mode | (uint32_t)Request);
- /* update CR2 register */
- hi2c->Instance->CR2 = tmpreg;
- #endif /* HAL_I2C_MODULE_ENABLED */
- /************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
- int main(void)
- /* USER CODE BEGIN 1 */
- /* USER CODE END 1 */
- /* MCU Configuration----------------------------------------------------------*/
- /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
- HAL_Init();
- /* Configure the system clock */
- SystemClock_Config();
- /* Initialize all configured peripherals */
- MX_GPIO_Init();
- MX_I2C1_Init();
- MX_SPI1_Init();
- //MX_USART1_UART_Init();
- i2c_status=HAL_I2C_Slave_Transmit_IT(&hi2c1,&EDID_Default[0],256);
- /* USER CODE BEGIN 2 */
- /* USER CODE END 2 */
- /* Infinite loop */
- /* USER CODE BEGIN WHILE */
- while (1)
- /* USER CODE END WHILE */
- /* USER CODE BEGIN 3 */
- /* USER CODE END 3 */
- #include "i2c.h"
- #include "gpio.h"
- /* USER CODE BEGIN 0 */
- /* USER CODE END 0 */
- I2C_HandleTypeDef hi2c1;
- /* I2C1 init function */
- void MX_I2C1_Init(void)
- hi2c1.Instance = I2C1;
- hi2c1.Init.Timing = 0x00201D2B;//0x2000090E;
- hi2c1.Init.OwnAddress1 = 0xA0;
- hi2c1.Init.AddressingMode = I2C_ADDRESSINGMODE_7BIT;
- hi2c1.Init.DualAddressMode = I2C_DUALADDRESS_DISABLED;
- hi2c1.Init.OwnAddress2 = 0;
- hi2c1.Init.OwnAddress2Masks = I2C_OA2_NOMASK;
- hi2c1.Init.GeneralCallMode = I2C_GENERALCALL_DISABLED;
- hi2c1.Init.NoStretchMode = I2C_NOSTRETCH_DISABLED;
- HAL_I2C_Init(&hi2c1);
- /**Configure Analogue filter
- HAL_I2CEx_AnalogFilter_Config(&hi2c1, I2C_ANALOGFILTER_ENABLED);
- void HAL_I2C_MspInit(I2C_HandleTypeDef* hi2c)
- GPIO_InitTypeDef GPIO_InitStruct;
- if(hi2c->Instance==I2C1)
- /* USER CODE BEGIN I2C1_MspInit 0 */
- /* USER CODE END I2C1_MspInit 0 */
- /**I2C1 GPIO Configuration
- PA9 ------> I2C1_SCL
- PA10 ------> I2C1_SDA
- GPIO_InitStruct.Pin = GPIO_PIN_9|GPIO_PIN_10;
- GPIO_InitStruct.Mode = GPIO_MODE_AF_OD;
- GPIO_InitStruct.Pull = GPIO_PULLUP;
- GPIO_InitStruct.Speed = GPIO_SPEED_HIGH;
- GPIO_InitStruct.Alternate = GPIO_AF4_I2C1;
- HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
- /* Peripheral clock enable */
- __I2C1_CLK_ENABLE();
- /* Peripheral interrupt init*/
- HAL_NVIC_SetPriority(I2C1_IRQn, 1, 0);
- HAL_NVIC_EnableIRQ(I2C1_IRQn);
- /* USER CODE BEGIN I2C1_MspInit 1 */
- /* USER CODE END I2C1_MspInit 1 */
- void HAL_I2C_MspDeInit(I2C_HandleTypeDef* hi2c)
- /* USER CODE BEGIN I2C1_MspDeInit 0 */
- /* USER CODE END I2C1_MspDeInit 0 */
- /* Peripheral clock disable */
- __I2C1_CLK_DISABLE();
- HAL_GPIO_DeInit(GPIOA, GPIO_PIN_9|GPIO_PIN_10);
- /* Peripheral interrupt Deinit*/
- HAL_NVIC_DisableIRQ(I2C1_IRQn);
- /* USER CODE BEGIN I2C1_MspDeInit 1 */
- /* USER CODE END I2C1_MspDeInit 1 */
复制代码 |
