发表于 2016-8-16 18:59:48
POSIX优化实现
- #include <sys/mman.h>
- #include <stdlib.h>
- #include <unistd.h>
- #define report_exceptional_condition() abort ()
- struct ring_buffer
- void * address;
- unsigned long count_bytes;
- unsigned long write_offset_bytes;
- unsigned long read_offset_bytes;
- //Warning order should be at least 12 for Linux
- void ring_buffer_create( struct ring_buffer * buffer, unsigned long order )
- char path[ ] = "/dev/shm/ring-buffer-XXXXXX";
- int file_descriptor;
- void * address;
- int status;
- file_descriptor = mkstemp( path );
- if ( file_descriptor < 0 )
- report_exceptional_condition();
- status = unlink( path );
- if ( status )
- buffer->count_bytes = 1UL << order;
- buffer->write_offset_bytes = 0;
- buffer->read_offset_bytes = 0;
- status = ftruncate( file_descriptor, buffer->count_bytes );
- if ( status )
- buffer->address = mmap( NULL, buffer->count_bytes << 1, PROT_NONE, MAP_ANONYMOUS | MAP_PRIVATE, - 1, 0 );
- if ( buffer->address == MAP_FAILED )
- address = mmap( buffer->address, buffer->count_bytes, PROT_READ | PROT_WRITE, MAP_FIXED | MAP_SHARED, file_descriptor,
- 0 );
- if ( address != buffer->address )
- address = mmap( buffer->address + buffer->count_bytes, buffer->count_bytes, PROT_READ | PROT_WRITE, MAP_FIXED |
- MAP_SHARED, file_descriptor, 0 );
- if ( address != buffer->address + buffer->count_bytes )
- status = close( file_descriptor );
- if ( status )
- void ring_buffer_free( struct ring_buffer * buffer )
- int status;
- status = munmap( buffer->address, buffer->count_bytes << 1 );
- if ( status )
- void * ring_buffer_write_address( struct ring_buffer * buffer )
- /*** void pointer arithmetic is a constraint violation. ***/
- return buffer->address + buffer->write_offset_bytes;
- void ring_buffer_write_advance( struct ring_buffer * buffer, unsigned long count_bytes )
- buffer->write_offset_bytes += count_bytes;
- void * ring_buffer_read_address( struct ring_buffer * buffer )
- return buffer->address + buffer->read_offset_bytes;
- void ring_buffer_read_advance( struct ring_buffer * buffer, unsigned long count_bytes )
- buffer->read_offset_bytes += count_bytes;
- if ( buffer->read_offset_bytes >= buffer->count_bytes )
- /*如果读指针大于等于缓冲区长度,那些读写指针同时折返回[0, buffer_size]范围内 */
- buffer->read_offset_bytes -= buffer->count_bytes;
- buffer->write_offset_bytes -= buffer->count_bytes;
- unsigned long ring_buffer_count_bytes( struct ring_buffer * buffer )
- return buffer->write_offset_bytes - buffer->read_offset_bytes;
- unsigned long ring_buffer_count_free_bytes( struct ring_buffer * buffer )
- return buffer->count_bytes - ring_buffer_count_bytes( buffer );
- void ring_buffer_clear( struct ring_buffer * buffer )
- * Note, that initial anonymous mmap() can be avoided - after initial mmap() for descriptor fd,
- * you can try mmap() with hinted address as (buffer->address + buffer->count_bytes)
- * and if it fails - another one with hinted address as (buffer->address - buffer->count_bytes).
- * Make sure MAP_FIXED is not used in such case, as under certain situations it could end with segfault.
- * The advantage of such approach is, that it avoids requirement to map twice the amount
- * you need initially (especially useful e.g. if you want to use hugetlbfs and the allowed amount is limited)
- * and in context of gcc/glibc - you can avoid certain feature macros
- * (MAP_ANONYMOUS usually requires one of: _BSD_SOURCE, _SVID_SOURCE or _GNU_SOURCE).
复制代码 |
