关于SElinux的移植,已经搞了一个多月了,还是有一些问题,没有解决,具体如下
内核与文件系统中开启selinux支持后,先是用源码refpolicy来编译策略库,发现编译出来的策略库偏大,自带的策略过多,随后采用seedit的源码来编译策略库,这是一个比较精简的策略库源码,移植之后提示一些类未定义,在access文件中定义后解决,提示mmap_zero,有问题,发现没有这个类定义,将其定义之后,提示ave denied,在设置允许mmap_zero的规则后问题解决,那么现在的问题如下:
UBIFS: recovery completed
UBIFS: mounted UBI device 0, volume 0, name "rootfs0"
UBIFS: file system size: 417751040 bytes (407960 KiB, 398 MiB, 3290 LEBs)
UBIFS: journal size: 20951040 bytes (20460 KiB, 19 MiB, 165 LEBs)
UBIFS: media format: w4/r0 (latest is w4/r0)
UBIFS: default compressor: lzo
UBIFS: reserved for root: 4952683 bytes (4836 KiB)
VFS: Mounted root (ubifs filesystem) on device 0:14.
Freeing init memory: 164K
type=1403 audit(946684811.510:2): policy loaded auid=4294967295 ses=4294967295
Mounting /proc and /sys
mount: mounting sys on /sys failed: Device or resource busy
Starting the hotplug events dispatcher udevd
Synthesizing initial hotplug events
Setting the hostname to freescale
Mounting filesystems
cp: getfscreatecon: No such file or directory
mount: mounting usbfs on /proc/bus/usb failed: No such file or directory
Starting syslogd and klogd
Running sysctl
Setting up networking on loopback device:
Setting up networking on eth0:
eth0: Freescale FEC PHY driver [Generic PHY] (mii_bus:phy_addr=0:00, irq=-1)
sed: /etc/hosts: No such file or directory
mv: cannot set setfscreatecon system_u:object_r:tmpfs_t: No such file or directory
Adding static route for default gateway to 192.168.0.1:
Setting nameserver to 192.168.0.1 in /etc/resolv.conf:
BusyBox v1.15.0 () built-in shell (ash)
Enter 'help' for a list of built-in commands.
root@freescale /$
root@freescale /$
root@freescale /$
问题1,这一串cp是哪里出来的?内核,文件系统,还是库?如何解决?
问题2,最后两个sed貌似和前边的cp错误是同一类的么?像是文件系统挂载中出现问题,有哪位遇到过?该如何解决?
坛友多费心多帮忙,多谢!
