发表于 2017-3-12 20:38:27
用delay软件延时的吗,还是用dma+pwm驱动的好点.
http://www.cnblogs.com/shangdawei/p/4762102.html
- #include "ws2812.h"
- #include <stm32f4xx.h>
- #include <stm32f4xx_rcc.h>
- #include <stm32f4xx_gpio.h>
- #include <stm32f4xx_tim.h>
- #include <stm32f4xx_dma.h>
- static uint16_t PWM_Buffer[ PWM_BUFFER_SIZE ];
- uint32_t frame_pos = 0;
- int incomplete_return = 0;
- void Update_Buffer( uint16_t* buffer );
- static void start_dma( void )
- static DMA_InitTypeDef dma_init =
- { .DMA_BufferSize = PWM_BUFFER_SIZE, .DMA_Channel = DMA_Channel_5, .DMA_DIR =
- DMA_DIR_MemoryToPeripheral, .DMA_FIFOMode = DMA_FIFOMode_Disable,
- .DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull, .DMA_Memory0BaseAddr =
- (uint32_t) PWM_Buffer, .DMA_MemoryBurst = DMA_MemoryBurst_Single,
- .DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord, .DMA_MemoryInc =
- DMA_MemoryInc_Enable, .DMA_Mode = DMA_Mode_Circular,
- .DMA_PeripheralBaseAddr = (uint32_t) &TIM3->CCR4, .DMA_PeripheralBurst =
- DMA_PeripheralBurst_Single, .DMA_PeripheralDataSize =
- DMA_PeripheralDataSize_HalfWord, .DMA_PeripheralInc =
- DMA_PeripheralInc_Disable, .DMA_Priority = DMA_Priority_Medium };
- DMA_Init( DMA1_Stream2, &dma_init );
- DMA_Cmd( DMA1_Stream2, ENABLE );
- TIM_DMACmd( TIM3, TIM_DMA_CC4, ENABLE );
- static void init_buffers( void )
- for ( int i = 0; i < PWM_BUFFER_SIZE; i++ )
- PWM_Buffer[ i ] = 0;
- for ( int i = 0; i < FRAMEBUFFER_SIZE; i++ )
- ws2812_framebuffer[ i ].red = 0;
- ws2812_framebuffer[ i ].green = 0;
- ws2812_framebuffer[ i ].blue = 0;
- void ws2812_init( )
- init_buffers( );
- //InitStructures...
- GPIO_InitTypeDef GPIO_InitStructure;
- TIM_TimeBaseInitTypeDef TIM_TimeBase_InitStructure;
- TIM_OCInitTypeDef TIM_OC_InitStructure;
- NVIC_InitTypeDef nvic_init;
- //Clock für GPIO setzen
- RCC_AHB1PeriphClockCmd( RCC_AHB1Periph_GPIOC, ENABLE );
- //Clock für TIM4 setzen
- RCC_APB1PeriphClockCmd( RCC_APB1Periph_TIM3, ENABLE );
- //GPIO_PIN konfigurieren
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
- GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
- GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
- GPIO_Init( GPIOC, &GPIO_InitStructure );
- //GPIO Alternate function verbinden
- GPIO_PinAFConfig( GPIOC, GPIO_PinSource9, GPIO_AF_TIM3 );
- TIM_TimeBase_InitStructure.TIM_ClockDivision = TIM_CKD_DIV1;
- TIM_TimeBase_InitStructure.TIM_CounterMode = TIM_CounterMode_Up;
- TIM_TimeBase_InitStructure.TIM_Period = 104;
- TIM_TimeBase_InitStructure.TIM_Prescaler = 0;
- TIM_TimeBaseInit( TIM3, &TIM_TimeBase_InitStructure );
- TIM_OC_InitStructure.TIM_OCMode = TIM_OCMode_PWM1;
- TIM_OC_InitStructure.TIM_OCIdleState = TIM_OCIdleState_Reset;
- TIM_OC_InitStructure.TIM_OCNIdleState = TIM_OCNIdleState_Set;
- TIM_OC_InitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
- TIM_OC_InitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;
- TIM_OC_InitStructure.TIM_OutputState = TIM_OutputState_Enable;
- TIM_OC_InitStructure.TIM_OutputNState = TIM_OutputNState_Disable;
- TIM_OC_InitStructure.TIM_Pulse = 0;
- TIM_OC4Init( TIM3, &TIM_OC_InitStructure );
- TIM_CtrlPWMOutputs( TIM3, ENABLE );
- TIM_OC4PreloadConfig( TIM3, TIM_OCPreload_Enable );
- TIM_ARRPreloadConfig( TIM3, ENABLE );
- TIM_CCxCmd( TIM3, TIM_Channel_4, TIM_CCx_Enable );
- TIM_Cmd( TIM3, ENABLE );
- // DMA
- RCC_AHB1PeriphClockCmd( RCC_AHB1Periph_DMA1, ENABLE );
- DMA_ITConfig( DMA1_Stream2, DMA_IT_HT, ENABLE );
- DMA_ITConfig( DMA1_Stream2, DMA_IT_TC, ENABLE );
- start_dma( );
- // NVIC for DMA
- nvic_init.NVIC_IRQChannel = DMA1_Stream2_IRQn;
- nvic_init.NVIC_IRQChannelPreemptionPriority = 4;
- nvic_init.NVIC_IRQChannelSubPriority = 0;
- nvic_init.NVIC_IRQChannelCmd = ENABLE;
- NVIC_Init( &nvic_init );
- // writes the pwm values of one byte into the array which will be used by the dma
- static inline void color2pwm( uint16_t ** const dest, const uint8_t color )
- uint8_t mask = 0x80;
- do
- if ( color & mask )
- * *dest = 49;
- else
- * *dest = 20;
- *dest += 1;
- mask >>= 1;
- }while ( mask != 0 );
- struct led *framebufferp;
- uint32_t i, j;
- uint16_t * bufp;
- for ( i = 0; i < ( PWM_BUFFER_SIZE / 2 ) / 24; i++ )
- if ( incomplete_return )
- incomplete_return = 0;
- for ( j = 0; j < 24; j++ )
- buffer[ i * 24 + j ] = 0;
- else
- if ( frame_pos == FRAMEBUFFER_SIZE )
- incomplete_return = 1;
- frame_pos = 0;
- else
- framebufferp = &ws2812_framebuffer[ frame_pos++ ];
- bufp = buffer + ( i * 24 );
- // edit here to change order of colors in "ws2812_framebuffer" (0x00RRGGBB, 0x00GGBBRR, etc)
- // the chip needs G R B
- color2pwm( &bufp, framebufferp->green ); // green
- color2pwm( &bufp, framebufferp->red ); // red
- color2pwm( &bufp, framebufferp->blue ); // blue
- void DMA1_Stream2_IRQHandler( void )
- // Half-Transfer completed
- if ( DMA_GetITStatus( DMA1_Stream2, DMA_IT_HTIF2 ) )
- DMA_ClearITPendingBit( DMA1_Stream2, DMA_IT_HTIF2 );
- Update_Buffer( PWM_Buffer );
- // Transfer completed
- if ( DMA_GetITStatus( DMA1_Stream2, DMA_IT_TCIF2 ) )
- DMA_ClearITPendingBit( DMA1_Stream2, DMA_IT_TCIF2 );
- Update_Buffer( PWM_Buffer + ( PWM_BUFFER_SIZE / 2 ) );
复制代码 |
