发表于 2017-5-31 19:36:28
弹出这样一个提示,有解决办法吗
// 32 x 32 bit multiplication with 32 bit result
#ifdef _PIC18
#define _Has_hardware_multiply 1
#else
#define _Has_hardware_multiply 0
#if defined(_PIC14E) || defined(_PIC14EX) || defined(_PIC18)
#define _Has_large_call_stack 1
#else
#define _Has_large_call_stack 0
unsigned long
__lmul(unsigned long multiplier, unsigned long multiplicand)
unsigned long product;
#define LOWBYTE(x) (*(unsigned char *)(&x))
#define LMIDBYTE(x) (*(((unsigned char *)(&x))+1))
#define HMIDBYTE(x) (*(((unsigned char *)(&x))+2))
#define HIGHBYTE(x) (*(((unsigned char *)(&x))+3))
#if (_Has_hardware_multiply || _Has_large_call_stack) && defined(__OPTIMIZE_SPEED__)
#define USE_SHRINK
a 32-bit multiply can be decomposed into the sum of ten 8-bit multiplies
a b c d
* e f g h
| dh
| ch 0
| bh 0 0
|ah 0 0 0
| dg 0
| cg 0 0
|bg 0 0 0
ag| 0 0 0 0 (we ignore this intermediate product
because it does not affect the low 32 bits of the result)
| df 0 0
|cf 0 0 0
bf| 0 0 0 0 (ignore)
af 0| 0 0 0 0 (ignore)
|de 0 0 0
ce| 0 0 0 0 (ignore)
be 0| 0 0 0 0 (ignore)
+ ae 0 0| 0 0 0 0 (ignore)
product = (unsigned int)LOWBYTE(multiplier) * LOWBYTE(multiplicand);
#if defined(USE_MASKS)
product += ((unsigned long)
((unsigned int)LOWBYTE(multiplier) * LMIDBYTE(multiplicand))
((unsigned int)LMIDBYTE(multiplier) * LOWBYTE(multiplicand)))
<< 8;
((unsigned int)LOWBYTE(multiplier) * HMIDBYTE(multiplicand))
((unsigned int)LMIDBYTE(multiplier) * LMIDBYTE(multiplicand))
((unsigned int)HMIDBYTE(multiplier) * LOWBYTE(multiplicand)))
<< 16;
/* cast to smaller type to avoid adding high bits just to discard */
(unsigned char)
((unsigned int)LOWBYTE(multiplier) * HIGHBYTE(multiplicand))
(unsigned char)
((unsigned int)LMIDBYTE(multiplier) * HMIDBYTE(multiplicand))
(unsigned char)
((unsigned int)HMIDBYTE(multiplier) * LMIDBYTE(multiplicand))
(unsigned char)
((unsigned int)HIGHBYTE(multiplier) * LOWBYTE(multiplicand)))
<< 24;
#elif defined(USE_SHRINK)
/* add direct to upper bytes, rather than shift and add all bytes */
*((unsigned short long*)(((unsigned char*)&product)+1)) +=
((unsigned int)LOWBYTE(multiplier) * LMIDBYTE(multiplicand));
((unsigned int)LMIDBYTE(multiplier) * LOWBYTE(multiplicand));
*((unsigned int*)(((unsigned char*)&product)+2)) +=
((unsigned int)LOWBYTE(multiplier) * HMIDBYTE(multiplicand));
((unsigned int)LMIDBYTE(multiplier) * LMIDBYTE(multiplicand));
((unsigned int)HMIDBYTE(multiplier) * LOWBYTE(multiplicand));
*(((unsigned char*)&product)+3) +=
(unsigned char)
((unsigned int)LOWBYTE(multiplier) * HIGHBYTE(multiplicand));
(unsigned char)
((unsigned int)LMIDBYTE(multiplier) * HMIDBYTE(multiplicand));
(unsigned char)
((unsigned int)HMIDBYTE(multiplier) * LMIDBYTE(multiplicand));
(unsigned char)
((unsigned int)HIGHBYTE(multiplier) * LOWBYTE(multiplicand));
#else
#error No method chosen
#else
product = 0;
do {
if(multiplier & 1)
product += multiplicand;
multiplicand <<= 1;
multiplier >>= 1;
} while(multiplier != 0);
return product;
