因为手上的这份代码被修改过,在不到源码了。
注释部分的说明是:
- RSA.C - RSA routines for RSAEURO
- Copyright (c) J.S.A.Kapp 1994 - 1996.
- RSAEURO - RSA Library compatible with RSAREF(tm) 2.0.
- All functions prototypes are the Same as for RSAREF(tm).
- To aid compatiblity the source and the files follow the
- same naming comventions that RSAREF(tm) uses. This should aid
- direct importing to your applications.
- This library is legal everywhere outside the US. And should
- NOT be imported to the US and used there.
- All Trademarks Acknowledged.
- RSA encryption performed as defined in the PKCS (#1) by RSADSI.
- Revision history
- 0.90 First revision, code produced very similar to that
- of RSAREF(tm), still it worked fine.
- 0.91 Second revision, code altered to aid speeding up.
- Used pointer accesses to arrays to speed up some parts,
- mainly during the loops.
- 1.03 Third revision, Random Structure initialization
- double check, RSAPublicEncrypt can now return RE_NEED_RANDOM.
复制代码 |
