发表于 2017-6-24 21:17:32
porttcp.c
这个应该有很大的问题!
* FreeModbus Libary: lwIP Port
* Copyright (C) 2006 Christian Walter <wolti@sil.at>
* This library is free software; you can redistribute it and/or
* modify it under the terms of the GNU Lesser General Public
* License as published by the Free Software Foundation; either
* version 2.1 of the License, or (at your option) any later version.
* This library is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
* Lesser General Public License for more details.
* You should have received a copy of the GNU Lesser General Public
* License along with this library; if not, write to the Free Software
* Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
* File: $Id: porttcp.c,v 1.1 2006/08/30 23:18:07 wolti Exp $
/* ----------------------- System includes ----------------------------------*/
#include <stdio.h>
#include <string.h>
#include "port.h"
#include "w5500.h"
#include "socket.h"
/* ----------------------- Modbus includes ----------------------------------*/
#include "mb.h"
#include "mbport.h"
/* ----------------------- MBAP Header --------------------------------------*/
#define MB_TCP_UID 6
#define MB_TCP_LEN 4
#define MB_TCP_FUNC 7
#define MB_TCP_DEFAULT_PORT 502 /* TCP listening port. */
#define MB_TCP_BUF_SIZE ( 256 + 7 ) /* Must hold a complete Modbus TCP frame. */
/* ----------------------- Prototypes ---------------------------------------*/
static UCHAR aucTCPBuf[MB_TCP_BUF_SIZE]; //接收缓冲区
static USHORT usTCPBufLen;
BOOL
xMBTCPPortInit( USHORT usTCPPort )
BOOL bOkay = FALSE;
USHORT usPort;
if( usTCPPort == 0 )
usPort = MB_TCP_DEFAULT_PORT;
usPort = (USHORT)usTCPPort;
// // 侦听端口 Modbus-TCP 端口
// Socket0_Config(usPort);
// Socket_Listen(0);
listen(0);
bOkay = TRUE;
return bOkay;
void
vMBTCPPortClose( )
void
vMBTCPPortDisable( void )
BOOL
xMBTCPPortGetRequest( UCHAR ** ppucMBTCPFrame, USHORT * usTCPLength )
*ppucMBTCPFrame = &aucTCPBuf[0];
*usTCPLength = usTCPBufLen;
/* Reset the buffer. */
usTCPBufLen = 0;
return TRUE;
BOOL
xMBTCPPortSendResponse(const UCHAR * pucMBTCPFrame, USHORT usTCPLength )
// Write_SOCK_Data_Buffer( 0,(UCHAR*)pucMBTCPFrame, usTCPLength);
send(0,(UCHAR*)pucMBTCPFrame, usTCPLength);
return TRUE;
BOOL
xMBPortTCPPool( void )
unsigned short int us_rlen;
unsigned char i;
// i=Read_1_Byte(SIR);
i=getSn_IR(SIR);
// if(getSn_SR(0)&0x01)
// if(i&0x01)
// i=Read_SOCK_1_Byte(0,Sn_IR); //读W5500中断
// Write_SOCK_1_Byte(0,Sn_IR,i);
// us_rlen = Read_SOCK_Data_Buffer(0, aucTCPBuf); //读新数据放到aucTCPBuf中
if(getSn_IR(0) & Sn_IR_CON)
setSn_IR(0, Sn_IR_CON); /*清除接收中断标志位*/
us_rlen=getSn_RX_RSR(0); /*定义len为已接收数据的长度*/
recv(0,aucTCPBuf,us_rlen); /*接收来自Server的数据*/
if(us_rlen==0)
return FALSE;
usTCPBufLen = us_rlen; //读到新数据,得到长度
( void )xMBPortEventPost( EV_FRAME_RECEIVED ); //发送已接收到新数据到Modbus-TCP状态机
if(i&Sn_IR_DISCON) /* TCP Disconnect */
listen(0); //重新监听SOCK 0
if(i&Sn_IR_TIMEOUT) //超时
return TRUE;
void
EnterCriticalSection( void )
__disable_irq();
void
ExitCriticalSection( void )
__enable_irq();
