自从在网上看到DIY音乐频谱显示后,就想着自己折腾一块板,现在板子已经打样回来,并手工焊好.接上OLED也能正常工作,在论坛找了好多资料之后,用CUBE MX照着写了一个程序,也不知道行不行得通.如果采集到信号并FFT转换后,如何在OLED显示音柱?因为只有初中文化水平,对FFT没有任何认识.还请大家耐心指点一下.谢谢了.以下是主要的代码,请大神帮忙瞅瞅.
ADC部分初始化
/* ADC1 init function */
static void MX_ADC1_Init(void)
ADC_ChannelConfTypeDef sConfig;
/**Common config
hadc1.Instance = ADC1;
hadc1.Init.ScanConvMode = ADC_SCAN_DISABLE;
hadc1.Init.ContinuousConvMode = DISABLE;
hadc1.Init.DiscontinuousConvMode = DISABLE;
hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START;
hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;
hadc1.Init.NbrOfConversion = 1;
if (HAL_ADC_Init(&hadc1) != HAL_OK)
_Error_Handler(__FILE__, __LINE__);
/**Configure Regular Channel
sConfig.Channel = ADC_CHANNEL_0;
sConfig.Rank = 1;
sConfig.SamplingTime = ADC_SAMPLETIME_13CYCLES_5;
if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)
TIMER3 初始化部分
/* TIM3 init function */
static void MX_TIM3_Init(void)
TIM_ClockConfigTypeDef sClockSourceConfig;
TIM_MasterConfigTypeDef sMasterConfig;
htim3.Instance = TIM3;
htim3.Init.Prescaler = 71; //71分频后 得到1MHZ的频率
htim3.Init.CounterMode = TIM_COUNTERMODE_UP;
htim3.Init.Period = 24; //40K的采样频率
htim3.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
htim3.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_DISABLE;
if (HAL_TIM_Base_Init(&htim3) != HAL_OK)
sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL;
if (HAL_TIM_ConfigClockSource(&htim3, &sClockSourceConfig) != HAL_OK)
sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET;
sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE;
if (HAL_TIMEx_MasterConfigSynchronization(&htim3, &sMasterConfig) != HAL_OK)
//取模程序
void powerMag(uint32_t nfill)
int32_t lX,lY;
uint32_t i;
for (i=0; i < nfill; i++)
lX= (lBUFOUT<<16)>>16; /* sine_cosine --> cos */
lY= (lBUFOUT >> 16); /* sine_cosine --> sin */
float X= 64*((float)lX)/32768;
float Y = 64*((float)lY)/32768;
float Mag = sqrt(X*X+ Y*Y)/nfill; // 先平方和,再开方
lBUFMAG = (uint32_t)(Mag*65536); //
int main(void)
/* USER CODE BEGIN 1 */
uint8_t i;
/* USER CODE END 1 */
/* MCU Configuration----------------------------------------------------------*/
/* Reset of all peripherals, Initializes the Flash interface and the Systick. */
HAL_Init();
/* USER CODE BEGIN Init */
/* USER CODE END Init */
/* Configure the system clock */
SystemClock_Config();
/* USER CODE BEGIN SysInit */
/* USER CODE END SysInit */
/* Initialize all configured peripherals */
MX_GPIO_Init();
MX_TIM3_Init();
MX_ADC1_Init();
/* Initialize interrupts */
MX_NVIC_Init();
/* USER CODE BEGIN 2 */
HAL_TIM_Base_Start_IT(&htim3 );
HAL_ADC_Start(&hadc1);
HAL_ADC_Start_IT(&hadc1);
OLED_Init() ; //初始化OLED
OLED_Clear();
HAL_Delay(2000);
/* USER CODE END 2 */
/* Infinite loop */
/* USER CODE BEGIN WHILE */
while (1)
/* USER CODE END WHILE */
/* USER CODE BEGIN 3 */
if(Value) //采集64点信号完成标志
cr4_fft_64_stm32(lBUFOUT, lBUFIN, NPT); //FFT计算
powerMag(NPT); //取模
for(i=0;i<NPT;i++) //这是在OLED上显示采集到的ADC数据和取模后的数据
HAL_Delay(100);
OLED_ShowNum(0,0,ADC_Value,12,16);
OLED_ShowNum(0,2,lBUFIN,12,16);
OLED_ShowNum(0,4,i,4,16);
OLED_ShowNum(0,6,lBUFMAG,8,16);
value=0;
Value=0;
以下是TIMER中断和ADC中断
/********** 定时器中断入口 ***********/
void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim)
if(htim==&htim3) //
ADC_Value[value]=ADC_ConvertedValue;
lBUFIN[value]=ADC_ConvertedValue<<16;
if(value<NPT)
value++;
HAL_TIM_Base_Stop_IT(&htim3 );
Value=1;
//HAL_ADC_Start(&hadc1);
//HAL_ADC_Start_IT(&hadc1);
void HAL_ADC_ConvCpltCallback(ADC_HandleTypeDef* hadc)
ADC_ConvertedValue=HAL_ADC_GetValue(&hadc1);
HAL_ADC_Stop(&hadc1);
HAL_ADC_Stop_IT(&hadc1);
附件是网上找的原理图和MDK工程文件. |
