发表于 2017-9-13 16:12:39
Limitations
Licensing and Support
J-Link EDU may only be used for non-commercial purposes. J-Link EDU does not include support.
However you may submit your question to the SEGGER forum.
Terms of use
You may use the J-Link EDU for non profit educational purposes only! Non-profit educational purposes means that you may not use the J-Link EDU and its J-Link software:
directly or indirectly in or for a profit organization or business purposes or other undertaking intended for profit.
direct or indirect within any other commercial environment (e.g. office).
to develop, debug, program or manufacture a commercial product (or parts thereof).
to use it to either earn money or reasonably anticipate the receipt of monetary gain from it.
Any other use of the J-Link EDU is prohibited and illegal! If there is any doubt if a certain use may be considered within the foregoing scope or whether your use of the J-Link EDU applies to an educational situation, it is strongly recommended to get in touch and consult SEGGER prior use.
For clarification purposes: A student using the J-Link EDU direct or indirect in a business or profit organization (e.g. company) is considered a violation of the scope of this agreement.
限制
许可和支持
J-Link EDU只能用于非商业目的。 J-Link EDU不包括支持。
不过您可以将您的问题提交给SEGGER论坛。
使用条款
您可以使用J-Link EDU仅用于非营利性教育用途!非营利性教育意味着您不得使用J-Link EDU及其J-Link软件:
直接或间接在利润组织或业务目的或为谋取利润的其他承诺。
在任何其他商业环境(如办公室)内直接或间接。
开发,调试,编程或制造商业产品(或其部分)。
使用它来赚钱或合理预期收到货币收益。
任何其他用途的J-Link EDU是禁止和非法的!如果有任何疑问,如果某种用途可能在上述范围内考虑,或者您使用J-Link EDU是否适用于教育情况,强烈建议您先与我们联系并咨询SEGGER。
澄清目的:在商业或利润组织(如公司)中直接或间接使用J-Link EDU的学生被认为违反了本协议的范围。 |
