发表于 2017-10-13 18:19:59
https://github.com/ARMmbed/mbed- ... orm/mbed_critical.h
https://github.com/ARMmbed/mbed- ... orm/mbed_critical.c
- bool core_util_atomic_cas_u8(uint8_t *ptr, uint8_t *expectedCurrentValue, uint8_t desiredValue)
- uint8_t currentValue = __LDREXB((volatile uint8_t*)ptr);
- if (currentValue != *expectedCurrentValue) {
- *expectedCurrentValue = currentValue;
- __CLREX();
- return false;
- return !__STREXB(desiredValue, (volatile uint8_t*)ptr);
- bool core_util_atomic_cas_u16(uint16_t *ptr, uint16_t *expectedCurrentValue, uint16_t desiredValue)
- uint16_t currentValue = __LDREXH((volatile uint16_t*)ptr);
- __CLREX();
- return false;
- return !__STREXH(desiredValue, (volatile uint16_t*)ptr);
- bool core_util_atomic_cas_u32(uint32_t *ptr, uint32_t *expectedCurrentValue, uint32_t desiredValue)
- uint32_t currentValue = __LDREXW((volatile uint32_t*)ptr);
- __CLREX();
- return false;
- return !__STREXW(desiredValue, (volatile uint32_t*)ptr);
- uint8_t core_util_atomic_incr_u8(uint8_t *valuePtr, uint8_t delta)
- uint8_t newValue;
- do {
- newValue = __LDREXB((volatile uint8_t*)valuePtr) + delta;
- } while (__STREXB(newValue, (volatile uint8_t*)valuePtr));
- return newValue;
- uint16_t core_util_atomic_incr_u16(uint16_t *valuePtr, uint16_t delta)
- uint16_t newValue;
- do {
- newValue = __LDREXH((volatile uint16_t*)valuePtr) + delta;
- } while (__STREXH(newValue, (volatile uint16_t*)valuePtr));
- return newValue;
- uint32_t core_util_atomic_incr_u32(uint32_t *valuePtr, uint32_t delta)
- uint32_t newValue;
- do {
- newValue = __LDREXW((volatile uint32_t*)valuePtr) + delta;
- } while (__STREXW(newValue, (volatile uint32_t*)valuePtr));
- return newValue;
- uint8_t core_util_atomic_decr_u8(uint8_t *valuePtr, uint8_t delta)
- uint8_t newValue;
- do {
- newValue = __LDREXB((volatile uint8_t*)valuePtr) - delta;
- return newValue;
- uint16_t core_util_atomic_decr_u16(uint16_t *valuePtr, uint16_t delta)
- do {
- newValue = __LDREXH((volatile uint16_t*)valuePtr) - delta;
- return newValue;
- uint32_t core_util_atomic_decr_u32(uint32_t *valuePtr, uint32_t delta)
- do {
- newValue = __LDREXW((volatile uint32_t*)valuePtr) - delta;
- return newValue;
复制代码 |
