发表于 2017-12-16 14:51:48
昨天又发布了更新
Version 3.34
Build
Added missing __powidf2 and __powisf2 compiler helper functions.
Updated the LLVM/Clang tools build to use the 5.0.0 source release.
Added EmbeddedStudioVersionNumber system macro.
The inttypes.h header file now includes stdint.h as per the c99 standard.
Added "Math Errno" project option.
Dependency files are now deleted on project rebuild/clean.
Does not link Externally Built Executable projects that have a specified Load File.
Does not compile files in Externally Built Executable projects that do not have compile command(s).
Debug
Added missing JLinkDevices.xml file and accompanying flash loaders.
J-Link Control Panel window now works with multiple J-Links attached.
Fixed generation of symbols when address_symbol and size_symbol attributes are used in a memory map or section placement files.
Fixed crash with IAR v8 generated elf files.
Fixed usage of brackets in debug watch expressions.
Additional load files can be relative to the project directory.
Fixed crash when scrolling the disassembly window with the mouse wheel when debugger is not running.
Documented the file format for the "Type Interpretation File" project property.
Updated shipped J-Link software to V6.22d.
IDE
Environment option descriptions are now selectable.
Improved performance of text editor brace matching in long files.
Added Text Editor > Formatting > Additional Formatting Styles environment option.
Added case sensitivity, whole word and regular expression options to code edit's incremental search dialog.
Code editor's incremental search dialog no longer resets find dialog settings.
Fixed drag and drop of file onto a project explorer file node from an external program.
Fixed loss of focus when an expanded project explorer node is deleted.
Fixed renaming of build configurations not applying when clicking on another build configuration after change.
Fixed crash when pressing Ctrl+Shift+T.
Modified macOS text editor cursor key mapping to be more like other macOS text editors.
Double clicking on company logo images in package manager and new project wizard now has no effect.
Fixed update of registers window status message when no registers are selected.
Fixed display of multi-line messages in output window's task view.
Code editor suggestions now inserted on all lines when in block edit mode.
Code editor replace all now only replaces text within block when in block selection mode.
WebKit web browser now uses display scaling factor.
Show Large Icons In Toolbars option now applies to docking windows.
Added keyboard shortcut editor to environment options dialog.
Fixed crash that occured when cancelling the new project wizard when on the edit common project settings page.
Fixed code editor suggestion popup not restoring opacity when ctrl key is released.
Pasting of a block selection is now done as a block insertion even if text editor is not in block edit mode.
Fixed text terminal not staying at end of file when maximum line limit is reached.
Licensing
Fix macro expansion of "Target Device" on license check.
Do license check when active project is changed.
License check now applies to "Library" project types based on the "Core Type".
Fixed installation of license strings containing UNICODE characters.
Fixed wireless network interfaces not being included in list of network adapters on Windows. |
