发表于 2018-11-13 13:07:21
VX.2.3 Update 11 Release Notes
版本 1
由 e53e4df6-7a16-841c-0100-014f8c8dda64 于 2018-10-7 下午9:42创建,最后由 e53e4df6-7a16-841c-0100-014f8c8dda64 于 2018-10-7 下午9:45修改。
Problems Fixed in X-ENTP VX.2.3 Update 11
EDM Server
dts0101330553 - A java.lang.NumberFormatException is written to MGCMDS.log every 5 minutes
dts0101330899 - SSL Certificate fails because systems do not have unfettered access to the Internet to validate the revocation status of an outside-generated certificate
dts0101315791 - Dataloss in xDMLibrary
EDM Library
dts0101332647 - Server deploy stuck at "Initiate Search Indexes" during migration
dts0101334519 - Abnormal change of TOP catalog group ID by drag & drop the catalog to itself
EDM Design
dts0101338500 - [EDM-TC Integration] In case of enabled TC integration, second and subsequent calls to ServerDeploy fail
Xpedition Systems Designer
dts0101321238 - The Xpedition System Designer product is checking out a xdesigner201_c license instead of xdesigner301_c
Xpedition AMS
dts0101319870 - Spice netlist doesn't be updated by execute [Netlist]
dts0101309501 - Before running simulation , netlist is not updated after deleting instance value
dts0101318655 - RMB > Model and Symbol Wizard crash depending on SPICEFILE property
dts0101318160 - Customer needs access to ADMS 17.2 (Windows 7 only) & Eldo 17.2
Xpedition Layout
dts0101302458 - Opening design saved in VX1.1 and open in VX2.2, Teardrop disappears and cannot be regenerated same as before
dts0101340534 - xPCB Layout - Interactive Routing performance needs to be faster in this large design. |
