https://eagle-updates.circuits.io/downloads/latest.html
- Release notes for EAGLE 9.0.0
- * PCB Design Manager:
- - The Design Manager in the Layout Editor window allows you to quickly and easily
- browse, filter, and inspect complex data in your Layout. By clicking on the entries
- in the Design Manager you can
- + identify and highlight your components and signals on the board, explore their
- relationship and inspect various attributes (location, span, pin count, via count,
- airwire and routed wire length...),
- + browse and filter items hierarchically by name/keyword, as well as object type,
- allowing you to quickly drill down in the minutest details,
- + select items across the board that might be hard to select otherwise,
- + directly launch the object's Properties dialog, as well as commonly used ROUTE
- and RIPUP command options.
- * BUS Refresh:
- - New simple workflow and user interface for creating busses that flows
- as follows: start BUS command, draw bus, define specification, (optional) place label.
- - New "Prefix Nets" checkbox option in new bus dialog that allows for simple bus
- member prefixing when creating new buses (i.e., SPI1:SPI1_MISO,SPI1_MOSI,SPI1_CLK).
- - New BREAKOUTBUS command in schematic, used from a bus right-click context menu,
- allows user to breakout a single net, selection of nets, or all nets as new nets
- with labels extending from the bus.
- - New PINBREAKOUT command that allows user to right-click on a part instance (or a
- pre-selected group of part instances) in schematic, and breakout all, or a selection
- of pins from the part. New nets are created that are connected to the chosen pins,
- with labels that match a one of a user-selectable list of label formats.
- New CLI format "PINBREAKOUT partname type" allows for making the label format type
- choice and to select which part to breakout.
- - New BUSFROMSEL command allows the user to select any number of nets in schematic,
- and create a bus using those selected nets to pre-fill the bus specification.
- Select nets, then right-click and choose "Make Bus", or type BUSFROMSEL on the
- commandline, then continue on through finalizing the new bus per new normal workflow.
- - New PINTOBUS command allows the user to automatically breakout nets from parts in
- schematic to nearby buses facing the corresponding part pins. Select one or more
- buses, then right-click on a part and choose "Connect pins to bus". If any of the
- members of the selected bus match any of the names of pins on the part, and if
- there is no connection already made from those pins, and there is a straight
- horizontal or vertical line path available out to the bus from the corresponding pins,
- then new nets will be created from the part pins to the nearby bus(es).
- * SPICE Simulation:
- - New REMOVE MODEL command added to be able to remove all SPICE
- attributes and properties from mapped parts.
- - Use the DeviceSet prefix (if set) as first guess for spice type when in
- Library Device editor and setting SPICE type in Add Model dialog.
- - Improvement to SPICE model support: support subcircuits that require input
- parameters when verifying simulation models.
- * Library Editor:
- - New "In Design" tab in library manager shows libraries open in the current
- schematic/board. A banner notification is shown if the user opens a design that
- references libraries that can be downloaded or updated.
- - The 3D packages of device variants are now shown in the device editor.
- - New right-click context menu items for adding devices to a schematic or packages to a
- board directly from the library editor table-of-contents view.
- - New dialog for importing 3D packages from other libraries.
- - New UI and command line syntax for replacing the package and 3D package of an
- existing device variant ("PACKAGE @vname package", etc).
- * CAM Processor:
- - Excellon drill output now correctly creates individual drill files for each specific
- via layer span.
- - When a CAM job file or CAM template contains an integer or decimal significant
- digits specification that falls outside the legal range, the CAM processor now
- produces an error message, instead of an unexpected condition.
- * LAUNCH Command:
- - Command line syntax for launching the package generator and web-based package search
- updated to "LAUNCH package3d-generator" and "LAUNCH package3d-web-search" respectively.
- * PACKAGE Command:
- - New command line syntax for replacing the package and 3D package of an existing
- device variant. See HELP PACKAGE.
- * RIPUP Command:
- - The RIPUP command now has a number of modes that can be selected with the right mouse button
- or with the icons on the parameter toolbar. There are the following modes available:
- Default, Signal, Connected Copper, Connected Copper on Same Layer, Between Components,
- All Signals, All Polygons.
- * ROUTE Command:
- - Performance improvement in several cases of obstacle avoidance, mostly involving
- collisions with board edge.
- - When starting a route from a multi-layer object, Shift+Middle mouse key now presents
- a start layer selection dialog.
- - Several new routing modes are added: Quick Route Airwire, Quick Route Signal,
- Quick Route Multi-Signals, and Smooth Route.
- - When routing in Walkaround or Push Obstacles mode, Enter key now auto-completes the
- route to the airwire anchor object.
- * Miscellaneous:
- - The algorithm for highlighting allows for greater range of darker and brighter values.
- - Now EAGLE supports Unicode on Windows out of the box. The Option.Codec setting was removed
- and UTF-8 encoding is used for all files on all platforms.
- - Offline period extended from 14 to 30 days.
- * Bugfixes:
- - Fixed a bug in the Display/Layer dialog where cancelling or pressing ESC after
- changing the layer filter would adversely affect which layers were visible.
复制代码 |
