大家好,
最近调试产品时用到openwrt,
硬件平台:MT7688
软件版本:openwrt 18.06
需要设置网络参数,google找了一下,可以使用UCI interface,其头文件如下:
- * libuci - Library for the Unified Configuration Interface
- * Copyright (C) 2008 Felix Fietkau <nbd@openwrt.org>
- * This program is free software; you can redistribute it and/or modify
- * it under the terms of the GNU Lesser General Public License version 2.1
- * as published by the Free Software Foundation
- * This program is distributed in the hope that it will be useful,
- * but WITHOUT ANY WARRANTY; without even the implied warranty of
- * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
- * GNU Lesser General Public License for more details.
- #ifndef __LIBUCI_H
- #define __LIBUCI_H
- #ifdef __cplusplus
- extern "C" {
- #endif
- //#include "uci_config.h"
- * you can use these defines to enable debugging behavior for
- * apps compiled against libuci:
- * #define UCI_DEBUG_TYPECAST:
- * enable uci_element typecast checking at run time
- #include <stdbool.h>
- #include <setjmp.h>
- #include <stdio.h>
- #include <stdint.h>
- #define UCI_CONFDIR "/etc/config"
- #define UCI_SAVEDIR "/tmp/.uci"
- #define UCI_DIRMODE 0700
- #define UCI_FILEMODE 0600
- enum
- UCI_OK = 0,
- UCI_ERR_MEM,
- UCI_ERR_INVAL,
- UCI_ERR_NOTFOUND,
- UCI_ERR_IO,
- UCI_ERR_PARSE,
- UCI_ERR_DUPLICATE,
- UCI_ERR_UNKNOWN,
- UCI_ERR_LAST
- struct uci_list;
- struct uci_list
- struct uci_list *next;
- struct uci_list *prev;
- struct uci_ptr;
- struct uci_element;
- struct uci_package;
- struct uci_section;
- struct uci_option;
- struct uci_delta;
- struct uci_context;
- struct uci_backend;
- struct uci_parse_option;
- struct uci_parse_context;
- * uci_alloc_context: Allocate a new uci context
- extern struct uci_context *uci_alloc_context(void);
- * uci_free_context: Free the uci context including all of its data
- extern void uci_free_context(struct uci_context *ctx);
- * uci_perror: Print the last uci error that occured
- * @ctx: uci context
- * @str: string to print before the error message
- extern void uci_perror(struct uci_context *ctx, const char *str);
- * uci_geterror: Get an error string for the last uci error
- * @dest: target pointer for the string
- * @str: prefix for the error message
- * Note: string must be freed by the caller
- extern void uci_get_errorstr(struct uci_context *ctx, char **dest, const char *str);
- * uci_import: Import uci config data from a stream
- * @stream: file stream to import from
- * @name: (optional) assume the config has the given name
- * @package: (optional) store the last parsed config package in this variable
- * @single: ignore the 'package' keyword and parse everything into a single package
- * the name parameter is for config files that don't explicitly use the 'package <...>' keyword
- * if 'package' points to a non-null struct pointer, enable delta tracking and merge
- extern int uci_import(struct uci_context *ctx, FILE *stream, const char *name, struct uci_package **package, bool single);
- * uci_export: Export one or all uci config packages
- * @stream: output stream
- * @package: (optional) uci config package to export
- * @header: include the package header
- extern int uci_export(struct uci_context *ctx, FILE *stream, struct uci_package *package, bool header);
- * uci_load: Parse an uci config file and store it in the uci context
- * @name: name of the config file (relative to the config directory)
- * @package: store the loaded config package in this variable
- extern int uci_load(struct uci_context *ctx, const char *name, struct uci_package **package);
- * uci_unload: Unload a config file from the uci context
- * @package: pointer to the uci_package struct
- extern int uci_unload(struct uci_context *ctx, struct uci_package *p);
- * uci_lookup_ptr: Split an uci tuple string and look up an element tree
- * @ptr: lookup result struct
- * @str: uci tuple string to look up
- * @extended: allow extended syntax lookup
- * if extended is set to true, uci_lookup_ptr supports the following
- * extended syntax:
- * Examples:
- * network.@interface[0].ifname ('ifname' option of the first interface section)
- * network.@interface[-1] (last interface section)
- * Note: uci_lookup_ptr will automatically load a config package if necessary
- * @str must not be constant, as it will be modified and used for the strings inside @ptr,
- * thus it must also be available as long as @ptr is in use.
- * This function returns UCI_ERR_NOTFOUND if the package specified in the tuple
- * string cannot be found. Otherwise it will return UCI_OK.
- * Note that failures in looking up other parts, if they are also specfied,
- * including section and option, will also have a return value UCI_OK but with
- * ptr->flags * UCI_LOOKUP_COMPLETE not set.
- extern int uci_lookup_ptr(struct uci_context *ctx, struct uci_ptr *ptr, char *str, bool extended);
- * uci_add_section: Add an unnamed section
- * @p: package to add the section to
- * @type: section type
- * @res: pointer to store a reference to the new section in
- extern int uci_add_section(struct uci_context *ctx, struct uci_package *p, const char *type, struct uci_section **res);
- * uci_set: Set an element's value; create the element if necessary
- * @ptr: uci pointer
- * The updated/created element is stored in ptr->last
- extern int uci_set(struct uci_context *ctx, struct uci_ptr *ptr);
- * uci_add_list: Append a string to an element list
- * @ptr: uci pointer (with value)
- * Note: if the given option already contains a string value,
- * it will be converted to an 1-element-list before appending the next element
- extern int uci_add_list(struct uci_context *ctx, struct uci_ptr *ptr);
- * uci_del_list: Remove a string from an element list
- extern int uci_del_list(struct uci_context *ctx, struct uci_ptr *ptr);
- * uci_reorder: Reposition a section
- * @s: uci section to reposition
- * @pos: new position in the section list
- extern int uci_reorder_section(struct uci_context *ctx, struct uci_section *s, int pos);
- * uci_rename: Rename an element
- extern int uci_rename(struct uci_context *ctx, struct uci_ptr *ptr);
- * uci_delete: Delete a section or option
- extern int uci_delete(struct uci_context *ctx, struct uci_ptr *ptr);
- * uci_save: save change delta for a package
- * @p: uci_package struct
- extern int uci_save(struct uci_context *ctx, struct uci_package *p);
- * uci_commit: commit changes to a package
- * @p: uci_package struct pointer
- * @overwrite: overwrite existing config data and flush delta
- * committing may reload the whole uci_package data,
- * the supplied pointer is updated accordingly
- extern int uci_commit(struct uci_context *ctx, struct uci_package **p, bool overwrite);
- * uci_list_configs: List available uci config files
- * caller is responsible for freeing the allocated memory behind list
- extern int uci_list_configs(struct uci_context *ctx, char ***list);
- * uci_set_savedir: override the default delta save directory
- * @dir: directory name
- * This will also try adding the specified dir to the end of delta pathes.
- extern int uci_set_savedir(struct uci_context *ctx, const char *dir);
- * uci_set_savedir: override the default config storage directory
- extern int uci_set_confdir(struct uci_context *ctx, const char *dir);
- * uci_add_delta_path: add a directory to the search path for change delta files
- * This function allows you to add directories, which contain 'overlays'
- * for the active config, that will never be committed.
- * Adding a duplicate directory will cause UCI_ERR_DUPLICATE be returned.
- extern int uci_add_delta_path(struct uci_context *ctx, const char *dir);
- * uci_revert: revert all changes to a config item
- extern int uci_revert(struct uci_context *ctx, struct uci_ptr *ptr);
- * uci_parse_argument: parse a shell-style argument, with an arbitrary quoting style
- * @stream: input stream
- * @str: pointer to the current line (use NULL for parsing the next line)
- * @result: pointer for the result
- extern int uci_parse_argument(struct uci_context *ctx, FILE *stream, char **str, char **result);
- * uci_set_backend: change the default backend
- * @name: name of the backend
- * The default backend is "file", which uses /etc/config for config storage
- extern int uci_set_backend(struct uci_context *ctx, const char *name);
- * uci_validate_text: validate a value string for uci options
- * @str: value
- * this function checks whether a given string is acceptable as value
- * for uci options
- extern bool uci_validate_text(const char *str);
- * uci_parse_ptr: parse a uci string into a uci_ptr
- * @ptr: target data structure
- * @str: string to parse
- * str is modified by this function
- int uci_parse_ptr(struct uci_context *ctx, struct uci_ptr *ptr, char *str);
- * uci_lookup_next: lookup a child element
- * @e: target element pointer
- * @list: list of elements
- * @name: name of the child element
- * if parent is NULL, the function looks up the package with the given name
- int uci_lookup_next(struct uci_context *ctx, struct uci_element **e, struct uci_list *list, const char *name);
- * uci_parse_section: look up a set of options
- * @s: uci section
- * @opts: list of options to look up
- * @n_opts: number of options to look up
- * @tb: array of pointers to found options
- void uci_parse_section(struct uci_section *s, const struct uci_parse_option *opts,
- int n_opts, struct uci_option **tb);
- * uci_hash_options: build a hash over a list of options
- * @tb: list of option pointers
- uint32_t uci_hash_options(struct uci_option **tb, int n_opts);
- /* UCI data structures */
- enum uci_type {
- UCI_TYPE_UNSPEC = 0,
- UCI_TYPE_DELTA = 1,
- UCI_TYPE_PACKAGE = 2,
- UCI_TYPE_SECTION = 3,
- UCI_TYPE_OPTION = 4,
- UCI_TYPE_PATH = 5,
- UCI_TYPE_BACKEND = 6,
- UCI_TYPE_ITEM = 7,
- UCI_TYPE_HOOK = 8,
- enum uci_option_type {
- UCI_TYPE_STRING = 0,
- UCI_TYPE_LIST = 1,
- enum uci_flags {
- UCI_FLAG_STRICT = (1 << 0), /* strict mode for the parser */
- UCI_FLAG_PERROR = (1 << 1), /* print parser error messages */
- UCI_FLAG_EXPORT_NAME = (1 << 2), /* when exporting, name unnamed sections */
- UCI_FLAG_SAVED_DELTA = (1 << 3), /* store the saved delta in memory as well */
- struct uci_list list;
- enum uci_type type;
- char *name;
- struct uci_element e;
- char **(*list_configs)(struct uci_context *ctx);
- struct uci_package *(*load)(struct uci_context *ctx, const char *name);
- void (*commit)(struct uci_context *ctx, struct uci_package **p, bool overwrite);
- /* private: */
- const void *ptr;
- void *priv;
- /* list of config packages */
- struct uci_list root;
- /* parser context, use for error handling only */
- struct uci_parse_context *pctx;
- /* backend for import and export */
- struct uci_backend *backend;
- struct uci_list backends;
- /* uci runtime flags */
- enum uci_flags flags;
- char *confdir;
- char *savedir;
- /* search path for delta files */
- struct uci_list delta_path;
- /* private: */
- int err;
- const char *func;
- jmp_buf trap;
- bool internal, nested;
- char *buf;
- int bufsz;
- struct uci_list sections;
- struct uci_context *ctx;
- bool has_delta;
- char *path;
- /* private: */
- void *priv;
- int n_section;
- struct uci_list delta;
- struct uci_list saved_delta;
- struct uci_list options;
- struct uci_package *package;
- bool anonymous;
- char *type;
- struct uci_option
- struct uci_section *section;
- enum uci_option_type type;
- union {
- char *string;
- } v;
- * UCI_CMD_ADD is used for anonymous sections or list values
- enum uci_command {
- UCI_CMD_ADD,
- UCI_CMD_REMOVE,
- UCI_CMD_CHANGE,
- UCI_CMD_RENAME,
- UCI_CMD_REORDER,
- UCI_CMD_LIST_ADD,
- UCI_CMD_LIST_DEL,
- __UCI_CMD_MAX,
- __UCI_CMD_LAST = __UCI_CMD_MAX - 1
- extern char const uci_command_char[];
- struct uci_delta
- enum uci_command cmd;
- char *section;
- char *value;
- struct uci_ptr
- enum uci_type target;
- enum {
- UCI_LOOKUP_DONE = (1 << 0),
- UCI_LOOKUP_COMPLETE = (1 << 1),
- UCI_LOOKUP_EXTENDED = (1 << 2),
- } flags;
- struct uci_package *p;
- struct uci_section *s;
- struct uci_option *o;
- struct uci_element *last;
- const char *package;
- const char *section;
- const char *option;
- const char *value;
- struct uci_parse_option {
- const char *name;
- /* linked list handling */
- #ifndef offsetof
- #define offsetof(TYPE, MEMBER) ((size_t) &((TYPE *)0)->MEMBER)
- #endif
- * container_of - cast a member of a structure out to the containing structure
- * @ptr: the pointer to the member.
- * @type: the type of the container struct this is embedded in.
- * @member: the name of the member within the struct.
- #ifndef container_of
- #define container_of(ptr, type, member) \
- ((type *) ((char *)ptr - offsetof(type,member)))
- #endif
- * uci_list_entry: casts an uci_list pointer to the containing struct.
- * @_type: config, section or option
- * @_ptr: pointer to the uci_list struct
- #define list_to_element(ptr) \
- container_of(ptr, struct uci_element, list)
- * uci_foreach_entry: loop through a list of uci elements
- * @_list: pointer to the uci_list struct
- * @_ptr: iteration variable, struct uci_element
- * use like a for loop, e.g:
- * uci_foreach(&list, p) {
- #define uci_foreach_element(_list, _ptr) \
- for(_ptr = list_to_element((_list)->next); \
- &_ptr->list != (_list); \
- _ptr = list_to_element(_ptr->list.next))
- * uci_foreach_entry_safe: like uci_foreach_safe, but safe for deletion
- * @_tmp: temporary variable, struct uci_element *
- * @_ptr: iteration variable, struct uci_element *
- #define uci_foreach_element_safe(_list, _tmp, _ptr) \
- for(_ptr = list_to_element((_list)->next), \
- _tmp = list_to_element(_ptr->list.next); \
- _ptr = _tmp, _tmp = list_to_element(_ptr->list.next))
- * uci_list_empty: returns true if a list is empty
- * @list: list head
- #define uci_list_empty(list) ((list)->next == (list))
- /* wrappers for dynamic type handling */
- #define uci_type_backend UCI_TYPE_BACKEND
- #define uci_type_delta UCI_TYPE_DELTA
- #define uci_type_package UCI_TYPE_PACKAGE
- #define uci_type_section UCI_TYPE_SECTION
- #define uci_type_option UCI_TYPE_OPTION
- /* element typecasting */
- #ifdef UCI_DEBUG_TYPECAST
- static const char *uci_typestr[] = {
- [uci_type_backend] = "backend",
- [uci_type_delta] = "delta",
- [uci_type_package] = "package",
- [uci_type_section] = "section",
- [uci_type_option] = "option",
- static void uci_typecast_error(int from, int to)
- fprintf(stderr, "Invalid typecast from '%s' to '%s'\n", uci_typestr[from], uci_typestr[to]);
- #define BUILD_CAST(_type) \
- static inline struct uci_ ## _type *uci_to_ ## _type (struct uci_element *e) \
- if (e->type != uci_type_ ## _type) { \
- uci_typecast_error(e->type, uci_type_ ## _type); \
- return (struct uci_ ## _type *) e; \
- BUILD_CAST(backend)
- BUILD_CAST(delta)
- BUILD_CAST(package)
- BUILD_CAST(section)
- BUILD_CAST(option)
- #else
- #define uci_to_backend(ptr) container_of(ptr, struct uci_backend, e)
- #define uci_to_delta(ptr) container_of(ptr, struct uci_delta, e)
- #define uci_to_package(ptr) container_of(ptr, struct uci_package, e)
- #define uci_to_section(ptr) container_of(ptr, struct uci_section, e)
- #define uci_to_option(ptr) container_of(ptr, struct uci_option, e)
- #endif
- * uci_alloc_element: allocate a generic uci_element, reserve a buffer and typecast
- * @type: {package,section,option}
- * @name: string containing the name of the element
- * @datasize: additional buffer size to reserve at the end of the struct
- #define uci_alloc_element(ctx, type, name, datasize) \
- uci_to_ ## type (uci_alloc_generic(ctx, uci_type_ ## type, name, sizeof(struct uci_ ## type) + datasize))
- #define uci_dataptr(ptr) \
- (((char *) ptr) + sizeof(*ptr))
- * uci_lookup_package: look up a package
- * @name: name of the package
- static inline struct uci_package *
- uci_lookup_package(struct uci_context *ctx, const char *name)
- struct uci_element *e = NULL;
- if (uci_lookup_next(ctx, &e, &ctx->root, name) == 0)
- return uci_to_package(e);
- else
- return NULL;
- * uci_lookup_section: look up a section
- * @p: package that the section belongs to
- * @name: name of the section
- static inline struct uci_section *
- uci_lookup_section(struct uci_context *ctx, struct uci_package *p, const char *name)
- if (uci_lookup_next(ctx, &e, &p->sections, name) == 0)
- return uci_to_section(e);
- else
- return NULL;
- * uci_lookup_option: look up an option
- * @section: section that the option belongs to
- * @name: name of the option
- static inline struct uci_option *
- uci_lookup_option(struct uci_context *ctx, struct uci_section *s, const char *name)
- if (uci_lookup_next(ctx, &e, &s->options, name) == 0)
- return uci_to_option(e);
- else
- return NULL;
- static inline const char *
- uci_lookup_option_string(struct uci_context *ctx, struct uci_section *s, const char *name)
- o = uci_lookup_option(ctx, s, name);
- if (!o || o->type != UCI_TYPE_STRING)
- return NULL;
- return o->v.string;
- #ifndef BITS_PER_LONG
- #define BITS_PER_LONG (8 * sizeof(unsigned long))
- #endif
- static inline void uci_bitfield_set(unsigned long *bits, int bit)
- bits[bit / BITS_PER_LONG] |= (1UL << (bit % BITS_PER_LONG));
- #endif
- #endif
交叉编译连接的时候需要指定头文件的位置及库文件的位置,我直接将这两个文件放到了交叉编译工具链的的sysroot里面去了,例如,mipsel-openwrt-linux-gcc -o xxx xxx.c -I./ -luci -lubox [libuci依赖libubox,这两个库文件可以从build_dir/target.../中找到]
Example code:
- static int set_tuple_cfg(char *tuple, const char *param) {
- if((tuple == NULL) || (param == NULL)) {
- return -1;
- struct uci_ptr ptr;
- struct uci_context *ctx = uci_alloc_context();
- if(!ctx) {
- return -1;
- if((uci_lookup_ptr(ctx, &ptr, tuple, false) != UCI_OK) || (ptr.o == NULL || ptr.o->v.string == NULL)) {
- perror("Read tuple error");
- uci_free_context(ctx);
- return -1;
- if(ptr.flags & UCI_LOOKUP_COMPLETE) {
- // strcpy(buffer, ptr.o->v.string);
- ptr.value = param;
- if(uci_set(ctx, &ptr) != UCI_OK) {
- perror("Set tuple %s tuple error");
- return -1;
- if(uci_commit(ctx, &ptr.p, false) != UCI_OK) {
- perror("commit %s tuple error");
- return -1;
- return 0;
- static int get_tuple_cfg(char *tuple, char *param) {
- return -1;
- if(!ctx) {
- return -1;
- return -1;
- strcpy(param, ptr.o->v.string);
- return 0;
- int netget_func(char *ip, char *netmask, char *gw) {
- if((ip == NULL) || (netmask == NULL) || (gw == NULL)) {
- return -1;
- char ip_path[] = "network.lan.ipaddr";
- if(get_tuple_cfg(ip_path, ip) == -1) {
- return -1;
- char mask_path[] = "network.lan.netmask";
- if(get_tuple_cfg(mask_path, netmask) == -1) {
- return -1;
- char gw_path[] = "network.lan.gateway";
- if(get_tuple_cfg(gw_path, gw) == -1) {
- return -1;
- return 0;
- int netcfg_func(const char *ip, const char *netmask, const char *gw) {
- return -1;
- if(set_tuple_cfg(ip_path, ip) == -1) {
- return -1;
- if(set_tuple_cfg(mask_path, netmask) == -1) {
- return -1;
- if(set_tuple_cfg(gw_path, gw) == -1) {
- return -1;
- return 0;
希望对大家有所帮助,相互学习,谢谢。 |
