回复: 14
STM32串口DMA空闲中断求救
发表于 2019-2-12 09:36:56 | 显示全部楼层 |阅读模式
F1使用串口3  DMA空闲中断,设置缓冲区100个字节,发现每次接收到》100个字节才产生一次空闲中断,如何修改设置成接收不定长字节就能空闲中断,贴代码:
void uart_init(u32 bound)
    USART_InitTypeDef USART_InitStructure;
    NVIC_InitTypeDef NVIC_InitStructure;
    DMA_InitTypeDef DMA_InitStructure;
   RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE); //??USART1,GPIOA??
   RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE); //??DMA??
   RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3,ENABLE);//??USART2??
   USART_DeInit(USART3);  //????1
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //??????
    GPIO_Init(GPIOB, &GPIO_InitStructure); //???PA9
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//????
    //Usart1 NVIC ??
    NVIC_InitStructure.NVIC_IRQChannel = USART3_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=3 ;//?????3
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3; //????3
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ????
    NVIC_Init(&NVIC_InitStructure); //??????????VIC???
   //USART ?????
  USART_InitStructure.USART_BaudRate = bound;//?????9600;
  USART_InitStructure.USART_WordLength = USART_WordLength_8b;//???8?????
  USART_InitStructure.USART_StopBits = USART_StopBits_1;//?????
  USART_InitStructure.USART_Parity = USART_Parity_No;//??????
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//????????
  USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; //????
    USART_Init(USART3, &USART_InitStructure); //?????
    USART_ITConfig(USART3, USART_IT_IDLE, ENABLE);//??????
    USART_DMACmd(USART3,USART_DMAReq_Rx,ENABLE);   //????1 DMA??
    USART_Cmd(USART3, ENABLE);                    //????
    //???DMA??
  DMA_DeInit(DMA1_Channel3);   //?DMA???5?????????  ??1????DMA??5
  DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)&USART3->DR;  //DMA??ADC???
  DMA_InitStructure.DMA_MemoryBaseAddr = (u32)RxBuffer3;  //DMA?????
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;  //??????,??????????
  DMA_InitStructure.DMA_BufferSize = 100;  //DMA???DMA?????
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;  //?????????
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;  //?????????
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;  //?????8?
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte; //?????8?
  DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;  //?????????
  DMA_InitStructure.DMA_Priority = DMA_Priority_Medium; //DMA?? x??????
  DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;  //DMA??x????????????
  DMA_Init(DMA1_Channel3, &DMA_InitStructure);  //??DMA_InitStruct?????????DMA???
    DMA_Cmd(DMA1_Channel3, ENABLE);  //????DMA??
u8 flag1=0;
void USART3_IRQHandler(void)
     if(USART_GetFlagStatus(USART3,USART_IT_IDLE)!= RESET)
             u8 num;
            num = USART3->SR;
            num = USART3->DR; //?USART_IT_IDLE??
            DMA_Cmd(DMA1_Channel3,DISABLE);    //??DMA
            num = 100 -  DMA_GetCurrDataCounter(DMA1_Channel3);      //??????????
            RxBuffer3[num] = '\0';
            DMA1_Channel3->CNDTR=100;       //??????????
            DMA_Cmd(DMA1_Channel3,ENABLE);  //??DMA
            flag1=1;           //????????1
发表于 2019-2-12 10:27:53 | 显示全部楼层
我用过的DMA用法就是这样了,缓存满就产生中断。设置100就是100了。楼主想达到任意中断,为何不用串口自身的字节接收完毕中断呢?
出0入442汤圆
发表于 2019-2-12 10:37:10 来自手机 | 显示全部楼层
HalenYU 发表于 2019-2-12 10:27
我用过的DMA用法就是这样了,缓存满就产生中断。设置100就是100了。楼主想达到任意中断,为何不用串口自身 ...
曰,进一次中断几us没有了,你当cpu资源无限啊。
发表于 2019-2-12 10:47:16 | 显示全部楼层
你用波特率算过字节传输时间吗?单就这一个串口中断来说这几us相对于字节传输的时间算个屁,你其它应用中断也很密集频繁,对资源要求极高则另当别论。
发表于 2019-2-12 10:56:34 | 显示全部楼层
有个空闲标志位。IDLE.
 楼主| 发表于 2019-2-12 11:11:26 | 显示全部楼层
沉默胜过白金 发表于 2019-2-12 10:56
有个空闲标志位。IDLE.
复制代码的时候不小心删除了 ,这个是有的          if(USART_GetFlagStatus(USART3,USART_IT_IDLE)!= RESET)
发表于 2019-2-12 11:14:52 | 显示全部楼层
yangzi8000 发表于 2019-2-12 11:11
复制代码的时候不小心删除了 ,这个是有的          if(USART_GetFlagStatus(USART3,USART_IT_IDLE)!= RESET) ...
没见你配置空闲中断啊?
cr1寄存器第四位还是第五位忘了,查下手册吧。
发表于 2019-2-12 11:16:01 | 显示全部楼层
看发送端字节间隔,标准的就用总线空闲标志位idle;要是间隔规则但间隔时间长的用定时器超时检测;没规律的就只能单个字节接受或者用大缓冲接收后再慢慢分析
发表于 2019-2-13 07:46:30 来自手机 | 显示全部楼层
空闲中断再启动一个定时器,等到溢出中断了才认为接收完成。
发表于 2019-2-13 10:28:00 | 显示全部楼层
这个有什么好讨论的。无非是开了个DMA接收数据,然后又开了空闲中断。好比DMA缓存区100字节。正常的通信指令可能就1-20个字节。收到1-20个字节就空闲,然后去DMA拿数据就好了。
楼主是代码没写好,于是发生了,非要发100个字节才能中断。那你这个是DMA接收完成中断,而不是空闲中断。
看一下库的例子吧。这种都是基础代码了。没什么好讨论的
发表于 2020-1-2 16:15:27 | 显示全部楼层
你的缓存设置的小了,不定长的话要以可能接收到最大程度为准。这个DMA中这个size对应你缓存长度大小,dma靠它判断是否产生缓存已满中断。
发表于 2020-1-2 17:35:01 | 显示全部楼层
接收脚如果没外部上拉的话,最好配置成内部上拉输入,空闲中断配置好就进入空闲中断了
发表于 2020-1-2 21:11:02 | 显示全部楼层
串口空闲中断,不是DMA空闲中断。你搞错了吧。
出190入0汤圆
发表于 2020-1-2 22:33:45 | 显示全部楼层
串口接收要使用空闲中断+dma完成中断才爽。
楼主代码有2个基本问题:
1,num = USART3->DR;这个本来是用来清除IDLE中断,但存在被优化掉的风险;
2, 在再次开启dma中断时,rxBuffer已接受的数据会被下一次串口数据覆盖掉(恰巧dma打开串口上就有数据);
另外,不知楼主如何判断是>100字节才有空闲中断产生的。
发表于 2020-1-2 23:21:02 | 显示全部楼层
只用过DMA+Timeout中断,IDLE时间太短了,分包容易错误
GMT+8, 2024-4-17 07:55
