SDK版本:esp8266_nonos_sdk_v1.5.4
1、system_uart_swap()函数要放到什么地方才能屏蔽上电打印呢?
2、使用UART1打印日志,将官网的程序复制过来,总是出现错误。
官网程序:
void ICACHE_FLASH_ATTR uart_init_new(void)
// Wait for FIFOs to be emptied
UART_WaitTxFifoEmpty(UART0);
UART_WaitTxFifoEmpty(UART1);
// Configure UART settings
UART_ConfigTypeDef uart_config;
uart_config.baud_rate = BIT_RATE_74880;
uart_config.data_bits = UART_WordLength_8b;
uart_config.parity = USART_Parity_None;
uart_config.stop_bits = USART_StopBits_1
uart_config.flow_ctrl = USART_HardwareFlowControl_None;
uart_config.UART_RxFlowThresh = 120;
uart_config.UART_InverseMask = UART_None_Inverse;
UART_ParamConfig(UART0, &uart_config);
UART_IntrConfTypeDef uart_intr;
uart_intr.UART_IntrEnMask = UART_RXFIFO_TOUT_INT_ENA | UART_FRM_ERR_INT_ENA | UART_RXFIFO_FULL_INT_ENA;
uart_intr.UART_RX_FifoFullIntrThresh = 100;
uart_intr.UART_RX_TimeOutIntrThresh = 2;
uart_intr.UART_TX_FifoEmptyIntrThresh = 20;
UART_IntrConfig(UART0, &uart_intr);
// Set UART1 for printing
UART_SetPrintPort(UART1);
// Register interrupt handler
UART_intr_handler_register(uart0_rx_intr_handler);
ETS_UART_INTR_ENABLE();
错误:
user_main.c: In function 'uart_init_new':
user_main.c:38:13: error: unknown type name 'UART_ConfigTypeDef'
user_main.c:39:24: error: request for member 'baud_rate' in something not a structure or union
user_main.c:40:24: error: request for member 'data_bits' in something not a structure or union
user_main.c:40:39: error: 'UART_WordLength_8b' undeclared (first use in this function)
user_main.c:40:39: note: each undeclared identifier is reported only once for each function it appears in
user_main.c:41:24: error: request for member 'parity' in something not a structure or union
user_main.c:41:38: error: 'USART_Parity_None' undeclared (first use in this function)
user_main.c:42:24: error: request for member 'stop_bits' in something not a structure or union
user_main.c:42:39: error: 'USART_StopBits_1' undeclared (first use in this function)
user_main.c:43:13: error: expected ';' before 'uart_config'
user_main.c:44:24: error: request for member 'UART_RxFlowThresh' in something not a structure or union
user_main.c:45:24: error: request for member 'UART_InverseMask' in something not a structure or union
user_main.c:47:13: error: unknown type name 'UART_IntrConfTypeDef'
user_main.c:48:22: error: request for member 'UART_IntrEnMask' in something not a structure or union
user_main.c:49:22: error: request for member 'UART_RX_FifoFullIntrThresh' in something not a structure or union
user_main.c:50:22: error: request for member 'UART_RX_TimeOutIntrThresh' in something not a structure or union
user_main.c:51:22: error: request for member 'UART_TX_FifoEmptyIntrThresh' in something not a structure or union
user_main.c:56:40: error: 'uart0_rx_intr_handler' undeclared (first use in this function)
