发表于 2019-4-15 20:25:56
以下摘自我使用的18650的手册:
7.4 安全性能 Safety Performance.
7.4.1 外部短路测试 External Short-Circuiting Test (25±2ºC)
电芯以标准模式充电, 将电芯的正极和负极以一根电阻为100mΩ的导线相连接, 并维持1小时。
标准: 不起火,不爆炸, 电芯表面温度不超过150℃。
Cells are charged per Standard Charge, and the positive and negative terminal is connected by a 100mΩ-wire for 1hour .
Criteria : No fire, No explosion, The temp of the exterior cell shall not exceed 150℃.
7.4.2 热冲击测试 Heating Test
电芯以标准模式充电, 置入鼓风烘箱中并以5℃/min的速率升温至130℃,在130℃下维
持30min。
标准: 不起火,不爆炸
Cells are charged per Standard Charge and heated in a circulating air oven at a rate of 5ºC
per minute to 130ºC. and remain then oven at 130ºC for 30 minutes.
Criteria: No fire, No explosion.
7.4.3 过充电测试 Overcharge Test
电芯以标准模式放电, 然后以3C恒定电流充电直到电压达到5V并维持7.小时, 测
试中应没有任何保护措施。
标准: 不起火,不爆炸
Cells are discharged per Standard Charge, then charged at constant current of 3C till the voltage reaches 5V for 7hrs. Not should have any protect during testing.
7.4.4 过放电测试 Overdischarge Test
电芯以标准模式放电后,然后用30Ω的电阻将电池正负极相连24h。
标准: 不起火,不爆炸
Cells are discharged per Standard Charge, then connect the positive and negative terminals with a resistor of 30Ω for 24 hours.
