发表于 2019-7-9 10:29:49
目前支持抬起识别。可以修改支持短按按下识别,短按抬起识别,长按按下识别,长按抬起识别。
- void MatrixKeyScan(unsigned char ucKeyValue[4][4])
- static unsigned char ucKeyState[4][4] = {KEY_STATE_0, KEY_STATE_0, KEY_STATE_0, KEY_STATE_0};
- static unsigned char ucKeyTime[4][4] = {0, 0, 0, 0};
- unsigned char ucKeyPress[4], i = 0, j = 0;
- for(j = 0; j < 4; j++)
- LineOutCtrl(j, SET);
- for(i = 0; i < 4; i++)
- ColumnScan(i, ucKeyPress);
- //printf("\r\n %d %d %d", j, i, ucKeyPress[i]);
- switch (ucKeyState[j][i])
- case KEY_STATE_0:
- if (!ucKeyPress[i])
- ucKeyState[j][i] = KEY_STATE_1;
- break;
- case KEY_STATE_1:
- ucKeyTime[j][i] = 0;
- ucKeyState[j][i] = KEY_STATE_2;
- else
- ucKeyState[j][i] = KEY_STATE_0;
- break;
- case KEY_STATE_2:
- if(ucKeyPress[i])
- else
- ucKeyTime[j][i]++;
- if(ucKeyTime[j][i] == 1)
- ucKeyState[j][i] = KEY_STATE_3;
- break;
- case KEY_STATE_3:
- if (ucKeyPress[i])
- ucKeyValue[j][i] = (i + j * 4 + 1);
- else
- break;
- default:
- break;
- LineOutCtrl(j, RESET);
- void ColumnScan(U8 Index, U8 *KeyPress)
- switch(Index)
- case 0:
- if(GPIO_ReadInputDataBit(KEYIN1_PORT, KEYIN1_PIN) == RESET)
- KeyPress[Index] = 0;//按下
- else
- KeyPress[Index] = 1;//抬起
- break;
- case 1:
- if(GPIO_ReadInputDataBit(KEYIN2_PORT, KEYIN2_PIN) == RESET)
- else
- break;
- case 2:
- if(GPIO_ReadInputDataBit(KEYIN3_PORT, KEYIN3_PIN) == RESET)
- else
- break;
- case 3:
- if(GPIO_ReadInputDataBit(KEYIN4_PORT, KEYIN4_PIN) == RESET)
- else
- break;
- default:
- break;
- //printf("\r\n %d %d", Index, KeyPress[Index]);
- void LineOutCtrl(U8 Index, U8 en)
- switch(Index)
- case 0:
- if(!en)
- GPIO_SetBits(KEYOUT1_PORT, KEYOUT1_PIN);
- else
- GPIO_ResetBits(KEYOUT1_PORT, KEYOUT1_PIN);
- break;
- case 1:
- if(!en)
- GPIO_SetBits(KEYOUT2_PORT, KEYOUT2_PIN);
- else
- GPIO_ResetBits(KEYOUT2_PORT, KEYOUT2_PIN);
- break;
- case 2:
- if(!en)
- GPIO_SetBits(KEYOUT3_PORT, KEYOUT3_PIN);
- else
- GPIO_ResetBits(KEYOUT3_PORT, KEYOUT3_PIN);
- break;
- case 3:
- if(!en)
- GPIO_SetBits(KEYOUT4_PORT, KEYOUT4_PIN);
- else
- GPIO_ResetBits(KEYOUT4_PORT, KEYOUT4_PIN);
- break;
- default:
- break;
- #define KEYOUT1_PORT GPIOA
- #define KEYOUT1_PIN GPIO_Pin_0
- #define KEYOUT2_PORT GPIOA
- #define KEYOUT2_PIN GPIO_Pin_1
- #define KEYOUT3_PORT GPIOA
- #define KEYOUT3_PIN GPIO_Pin_2
- #define KEYOUT4_PORT GPIOA
- #define KEYOUT4_PIN GPIO_Pin_3
- #define KEYIN1_PORT GPIOA
- #define KEYIN1_PIN GPIO_Pin_4
- #define KEYIN2_PORT GPIOA
- #define KEYIN2_PIN GPIO_Pin_5
- #define KEYIN3_PORT GPIOA
- #define KEYIN3_PIN GPIO_Pin_6
- #define KEYIN4_PORT GPIOA
- #define KEYIN4_PIN GPIO_Pin_7
- #define KEY_STATE_0 0
- #define KEY_STATE_1 1
- #define KEY_STATE_2 2
- #define KEY_STATE_3 3
- #define KEY_STATE_4 4
- #define N_KEY 0xFE
- void Task_10ms(void)
- static U8 ucCount = 0;
- U8 ucKeyValue[4][4] = {
- {N_KEY, N_KEY, N_KEY, N_KEY},
- }, i = 0, j = 0;
- MatrixKeyScan(ucKeyValue);
- if(ucKeyValue[j][i] != N_KEY)
- printf("\r\n ucKeyValue 测试计数:%d %d",ucCount++, ucKeyValue[j][i]);
