发表于 2019-7-17 15:54:13
贴一张串口日志图,证明代码是工作的 。开机默认所有继电器都关闭了,需要可以自己修改默认策略,也可以改成掉电保存上一次的状态啥的。
- 15:50:37.598 -> Loop!
- 15:50:39.578 -> Loop!
- 15:50:41.602 -> Loop!
- 15:50:43.584 -> Loop!
- 15:50:45.596 -> Loop!
- 15:50:47.598 -> Loop!
- 15:50:49.608 -> Connecting to MQTT Server ...
- 15:50:49.678 -> MQTT Connected!
- 15:50:49.713 -> {"id":"123","version":"1.0","method":"thing.event.property.post","params":{"Temperature":31.000000,"Humidity":13.000000,"LightSwitch":0,"LightSwitch1":0,"LightSwitch2":0,"CurtainSwitch":0,"CurtainSwitch1":0,"CurtainSwitch2":0}}
- 15:50:49.713 -> publish:0 失败;1成功1
- 15:50:49.713 -> Loop!
- 15:50:51.705 -> Loop!
- 15:50:53.710 -> Loop!
- 15:50:55.714 -> Loop!
- 15:50:57.686 -> Loop!
- 15:50:59.693 -> Loop!
- 15:51:01.722 -> Message arrived [/sys/a1myZkJoTPx/esp8266_01/thing/service/property/set] {"method":"thing.service.property.set","id":"944037471","params":{"LightSwitch1":1},"version":"1.0.0"}
- 15:51:01.722 -> LightSwitch1: 1Loop!
- 15:51:03.757 -> {"id":"123","version":"1.0","method":"thing.event.property.post","params":{"Temperature":32.000000,"Humidity":13.000000,"LightSwitch":0,"LightSwitch1":1,"LightSwitch2":0,"CurtainSwitch":0,"CurtainSwitch1":0,"CurtainSwitch2":0}}
- 15:51:03.757 -> publish:0 失败;1成功1
- 15:51:03.757 -> Loop!
- 15:51:05.766 -> Loop!
- 15:51:07.753 -> Message arrived [/sys/a1myZkJoTPx/esp8266_01/thing/service/property/set] {"method":"thing.service.property.set","id":"944038010","params":{"LightSwitch1":0},"version":"1.0.0"}
- 15:51:07.753 -> LightSwitch1: 0Loop!
- 15:51:09.805 -> {"id":"123","version":"1.0","method":"thing.event.property.post","params":{"Temperature":32.000000,"Humidity":13.000000,"LightSwitch":0,"LightSwitch1":0,"LightSwitch2":0,"CurtainSwitch":0,"CurtainSwitch1":0,"CurtainSwitch2":0}}
- 15:51:09.805 -> publish:0 失败;1成功1
- 15:51:09.805 -> Loop!
- 15:51:11.797 -> Loop!
- 15:51:13.815 -> Message arrived [/sys/a1myZkJoTPx/esp8266_01/thing/service/property/set] {"method":"thing.service.property.set","id":"944038559","params":{"LightSwitch":1},"version":"1.0.0"}
- 15:51:13.815 -> LightSwitch: 1Loop!
- 15:51:15.862 -> {"id":"123","version":"1.0","method":"thing.event.property.post","params":{"Temperature":32.000000,"Humidity":13.000000,"LightSwitch":1,"LightSwitch1":0,"LightSwitch2":0,"CurtainSwitch":0,"CurtainSwitch1":0,"CurtainSwitch2":0}}
- 15:51:15.862 -> publish:0 失败;1成功1
- 15:51:15.862 -> Loop!
- 15:51:17.850 -> Loop!
- 15:51:19.872 -> Message arrived [/sys/a1myZkJoTPx/esp8266_01/thing/service/property/set] {"method":"thing.service.property.set","id":"944039031","params":{"LightSwitch":0},"version":"1.0.0"}
- 15:51:19.872 -> LightSwitch: 0Loop!
- 15:51:21.906 -> {"id":"123","version":"1.0","method":"thing.event.property.post","params":{"Temperature":32.000000,"Humidity":13.000000,"LightSwitch":0,"LightSwitch1":0,"LightSwitch2":0,"CurtainSwitch":0,"CurtainSwitch1":0,"CurtainSwitch2":0}}
- 15:51:21.906 -> publish:0 失败;1成功1
- 15:51:21.906 -> Loop!
- 15:51:23.892 -> Loop!
- 15:51:25.898 -> Loop!
- 15:51:27.905 -> Message arrived [/sys/a1myZkJoTPx/esp8266_01/thing/service/property/set] {"method":"thing.service.property.set","id":"944039692","params":{"CurtainSwitch1":1},"version":"1.0.0"}
- 15:51:27.905 -> CurtainSwitch1: 1Loop!
- 15:51:29.952 -> {"id":"123","version":"1.0","method":"thing.event.property.post","params":{"Temperature":32.000000,"Humidity":13.000000,"LightSwitch":0,"LightSwitch1":0,"LightSwitch2":0,"CurtainSwitch":0,"CurtainSwitch1":1,"CurtainSwitch2":0}}
- 15:51:29.952 -> publish:0 失败;1成功1
- 15:51:29.952 -> Loop!
- 15:51:31.940 -> Loop!
- 15:51:33.940 -> Loop!
- 15:51:35.948 -> Loop!
- 15:51:37.958 -> Loop!
- 15:51:39.943 -> Loop!
- 15:51:41.942 -> Loop!
复制代码 |
