发表于 2019-10-10 19:59:47
jflash.cpp
#include "stdafx.h"
#include "windows.h"
#include "jlink.h"
#include "jflashAPI.h"
//use printf
#pragma comment(linker, "/subsystem:\"CONSOLE\" /entry:\"WinMainCRTStartup\"")
unsigned int jf_unlock(void)
jlink.JLINKARM_WriteU32(FLASH_KR, FLASH_KR_KEY1);
jlink.JLINKARM_WriteU32(FLASH_KR, FLASH_KR_KEY2);
return 0;
unsigned int jf_lock(void)
unsigned int read = jlink.JLINKARM_ReadU32(FLASH_CR) | FLASH_CR_LOCK;
jlink.JLINKARM_WriteU32(FLASH_CR, read);
return 0;
unsigned int jf_wait_ready(void)
unsigned int read;
while ( (read = jlink.JLINKARM_ReadU32(FLASH_SR) & FLASH_SR_BUSY) )
Sleep(1);
return 0;
unsigned int jf_chip_erase(void)
jf_unlock();
jlink.JLINKARM_WriteU32(FLASH_CR, jlink.JLINKARM_ReadU32(FLASH_CR) | FLASH_CR_CERASE);
jlink.JLINKARM_WriteU32(FLASH_CR, jlink.JLINKARM_ReadU32(FLASH_CR) | FLASH_CR_ESTART);
jf_wait_ready();
jlink.JLINKARM_WriteU32(FLASH_CR, jlink.JLINKARM_ReadU32(FLASH_CR) &~FLASH_CR_CERASE);
jf_lock();
return 0;
unsigned int jf_page_erase(unsigned int startAddr, unsigned int sec)
jf_unlock();
jlink.JLINKARM_WriteU32(FLASH_CR, jlink.JLINKARM_ReadU32(FLASH_CR) | FLASH_CR_PERASE);
for (unsigned int i = 0; i < sec; i++)
jlink.JLINKARM_WriteU32(FLASH_AR, startAddr + PAGE_SIZE * i);
jf_wait_ready();
jlink.JLINKARM_WriteU32(FLASH_CR, jlink.JLINKARM_ReadU32(FLASH_CR) &~FLASH_CR_PERASE);
jf_lock();
return 0;
unsigned int jf_page_write(unsigned int addr, unsigned char *data)
jf_unlock();
jlink.JLINKARM_WriteU32(FLASH_CR, jlink.JLINKARM_ReadU32(FLASH_CR) | FLASH_CR_PWRITE);
for (unsigned int i = 0; i < PAGE_SIZE/2; i++)
jlink.JLINKARM_WriteU16(addr + i * 2, data[i * 2] | (data[i * 2 + 1] << 8));
jf_wait_ready();
jlink.JLINKARM_WriteU32(FLASH_CR, jlink.JLINKARM_ReadU32(FLASH_CR) &~FLASH_CR_PWRITE);
jf_lock();
return 0;
unsigned int jf_chip_write(unsigned int startAddr, unsigned char * data, unsigned int len)
unsigned int n_page = len / PAGE_SIZE;
if ( len %PAGE_SIZE != 0)
jf_page_erase(startAddr, n_page + 1);
jf_page_erase(startAddr, n_page);
unsigned int i = 0;
for (i = 0; i < n_page; i++)
jf_page_write(startAddr + i* PAGE_SIZE, data + i*PAGE_SIZE);
printf("write sec i %d\r\n", i);
if ( len % PAGE_SIZE )
unsigned char buf[PAGE_SIZE] = {0};
for (unsigned int j = 0; j < PAGE_SIZE; j++)
buf[j] = 0xff;
memcpy(buf, data + i*PAGE_SIZE, len%PAGE_SIZE);
jf_page_write(startAddr + i* PAGE_SIZE, buf);
return 0;
jlink.cpp
#include "stdafx.h"
//#include <iostream>
#include "jlink.h"
#pragma comment(lib, "JLinkARM.dll")
dsJlink jlink;
unsigned char JLINKARM_ReadU8(unsigned int addr)
unsigned char ret;
unsigned char st;
jlink.JLINKARM_ReadMemU8(addr, 1, &ret, &st);
return ret;
unsigned short JLINKARM_ReadU16(unsigned int addr)
unsigned short ret;
unsigned char st;
jlink.JLINKARM_ReadMemU16(addr, 1, &ret, &st);
return ret;
unsigned int JLINKARM_ReadU32(unsigned int addr)
unsigned int ret;
unsigned char st;
jlink.JLINKARM_ReadMemU32(addr, 1, &ret, &st);
return ret;
unsigned int InitJLink(void)
#define BUF_MAX_SIZE 600
unsigned char buf[BUF_MAX_SIZE];
//加载动态库
HMODULE hMod = LoadLibrary("JLinkARM.dll");
///根据函数名获取函数指针
jlink.JLINKARM_TIF_Select = (pFunc_TIF_Select)GetProcAddress(hMod, TEXT("JLINKARM_TIF_Select"));
jlink.JLINKARM_ExecCommand = (pFunc_ExecCommand)GetProcAddress(hMod, TEXT("JLINKARM_ExecCommand"));
jlink.JLINKARM_GetId = (pFunc_GetId)GetProcAddress(hMod, TEXT("JLINKARM_GetId"));
jlink.JLINKARM_IsConnected = (pFunc_IsConnected)GetProcAddress(hMod, TEXT("JLINKARM_IsConnected"));
jlink.JLINKARM_Reset = (pFunc_Reset)GetProcAddress(hMod, TEXT("JLINKARM_Reset"));
jlink.JLINKARM_ReadMem = (pFunc_ReadMem)GetProcAddress(hMod, TEXT("JLINKARM_ReadMem"));
jlink.JLINKARM_WriteMem = (pFunc_WriteMem)GetProcAddress(hMod, TEXT("JLINKARM_WriteMem"));
jlink.JLINKARM_SetSpeed = (pFunc_SetSpeed)GetProcAddress(hMod, TEXT("JLINKARM_SetSpeed"));
jlink.JLINKARM_GetSpeed = (pFunc_GetSpeed)GetProcAddress(hMod, TEXT("JLINKARM_GetSpeed"));
jlink.JLINKARM_ReadMemU32 = (pFunc_ReadMemU32)GetProcAddress(hMod, TEXT("JLINKARM_ReadMemU32"));
jlink.JLINKARM_ReadMemU16 = (pFunc_ReadMemU16)GetProcAddress(hMod, TEXT("JLINKARM_ReadMemU16"));
jlink.JLINKARM_ReadMemU8 = (pFunc_ReadMemU8)GetProcAddress(hMod, TEXT("JLINKARM_ReadMemU8"));
jlink.JLINKARM_WriteU32 = (pFunc_WriteU32)GetProcAddress(hMod, TEXT("JLINKARM_WriteU32"));
jlink.JLINKARM_ReadU32 = (pFunc_ReadU32)GetProcAddress(hMod, TEXT("JLINKARM_ReadU32"));
jlink.JLINKARM_WriteU16 = (pFunc_WriteU16)GetProcAddress(hMod, TEXT("JLINKARM_WriteU16"));
jlink.JLINKARM_ReadU16 = (pFunc_ReadU16)GetProcAddress(hMod, TEXT("JLINKARM_ReadU16"));
jlink.JLINKARM_WriteU8 = (pFunc_WriteU8)GetProcAddress(hMod, TEXT("JLINKARM_WriteU8"));
jlink.JLINKARM_ReadU8 = (pFunc_ReadU8)GetProcAddress(hMod, TEXT("JLINKARM_ReadU8"));
jlink.JLINKARM_WriteReg = (pFunc_WriteReg)GetProcAddress(hMod, TEXT("JLINK_WriteReg"));
jlink.JLINKARM_ReadReg = (pFunc_ReadReg)GetProcAddress(hMod, TEXT("JLINK_ReadReg"));
//以下三个函数上面没有一次封装,这里进行二次封装一下
jlink.JLINKARM_ReadU32 = JLINKARM_ReadU32;
jlink.JLINKARM_ReadU16 = JLINKARM_ReadU16;
jlink.JLINKARM_ReadU8 = JLINKARM_ReadU8;
//选择设备
if (jlink.JLINKARM_TIF_Select != NULL)
jlink.JLINKARM_TIF_Select(1);
//设置芯片型号
if (jlink.JLINKARM_ExecCommand != NULL)
unsigned int ret = 0;
//选择芯片类型
ret = jlink.JLINKARM_ExecCommand("Device = Cortex-M3", buf, 64);
//判断jlink是否连接上
if (jlink.JLINKARM_IsConnected != NULL)
ret = jlink.JLINKARM_IsConnected();
printf("isConnected is %d\r\n", ret);
//设置jlink速度
if (jlink.JLINKARM_SetSpeed != NULL)
jlink.JLINKARM_SetSpeed(12000);
printf("set jlink speed ok\r\n");
//获取jlink速度
if (jlink.JLINKARM_GetSpeed != NULL)
unsigned int speed = jlink.JLINKARM_GetSpeed();
printf("get speed is %d khz\r\n", speed);
if (jlink.JLINKARM_WriteMem != NULL)
printf("jlink write mem func not null!\r\n");
return 0;
调用这个就可以刷程序, jf_chip_write
这种方式应该没有你直接用exe来的快
JLINKARM_WriteMem 可以直接对内存进行操作
这个dll的使用在另外一个贴子中提到过,其实也是参照python那个程序修改的
