发表于 2019-10-20 16:40:50
修改驱动中的发送函数:
* @brief Sends an Ethernet frame.
* @param heth pointer to a ETH_HandleTypeDef structure that contains
* the configuration information for ETHERNET module
* @param FrameLength Amount of data to be sent
* @retval HAL status
HAL_StatusTypeDef HAL_ETH_TransmitFrame(ETH_HandleTypeDef *heth, uint32_t FrameLength)
uint32_t bufcount = 0U, size = 0U, i = 0U;
/* Process Locked */
__HAL_LOCK(heth);
/* Set the ETH peripheral state to BUSY */
heth->State = HAL_ETH_STATE_BUSY;
if (FrameLength == 0U)
/* Set ETH HAL state to READY */
heth->State = HAL_ETH_STATE_READY;
/* Process Unlocked */
__HAL_UNLOCK(heth);
return HAL_ERROR;
/* Check if the descriptor is owned by the ETHERNET DMA (when set) or CPU (when reset) */
if(((heth->TxDesc)->Status & ETH_DMATXDESC_OWN) != (uint32_t)RESET)
/* OWN bit set */
heth->State = HAL_ETH_STATE_BUSY_TX;
__HAL_UNLOCK(heth);
return HAL_ERROR;
/* Get the number of needed Tx buffers for the current frame */
if (FrameLength > ETH_TX_BUF_SIZE)
bufcount = FrameLength/ETH_TX_BUF_SIZE;
if (FrameLength % ETH_TX_BUF_SIZE)
bufcount++;
bufcount = 1U;
if (bufcount == 1U)
/* Set LAST and FIRST segment */
heth->TxDesc->Status |=ETH_DMATXDESC_FS|ETH_DMATXDESC_LS|ETH_DMATXDESC_DP;//有修改,帧小于64byte时,自带补齐64B数据,原来为:heth->TxDesc->Status |=ETH_DMATXDESC_FS|ETH_DMATXDESC_LS;
/* Set frame size */
heth->TxDesc->ControlBufferSize = (FrameLength & ETH_DMATXDESC_TBS1);
/* Set Own bit of the Tx descriptor Status: gives the buffer back to ETHERNET DMA */
heth->TxDesc->Status |= ETH_DMATXDESC_OWN;
/* Point to next descriptor */
heth->TxDesc= (ETH_DMADescTypeDef *)(heth->TxDesc->Buffer2NextDescAddr);
for (i=0U; i< bufcount; i++)
/* Clear FIRST and LAST segment bits */
heth->TxDesc->Status &= ~(ETH_DMATXDESC_FS | ETH_DMATXDESC_LS);
if (i == 0U)
/* Setting the first segment bit */
heth->TxDesc->Status |= ETH_DMATXDESC_FS;
/* Program size */
heth->TxDesc->ControlBufferSize = (ETH_TX_BUF_SIZE & ETH_DMATXDESC_TBS1);
if (i == (bufcount-1U))
/* Setting the last segment bit */
heth->TxDesc->Status |= ETH_DMATXDESC_LS;
size = FrameLength - (bufcount-1U)*ETH_TX_BUF_SIZE;
heth->TxDesc->ControlBufferSize = (size & ETH_DMATXDESC_TBS1);
/* point to next descriptor */
heth->TxDesc = (ETH_DMADescTypeDef *)(heth->TxDesc->Buffer2NextDescAddr);
/* When Tx Buffer unavailable flag is set: clear it and resume transmission */
if (((heth->Instance)->DMASR & ETH_DMASR_TBUS) != (uint32_t)RESET)
/* Clear TBUS ETHERNET DMA flag */
(heth->Instance)->DMASR = ETH_DMASR_TBUS;
/* Resume DMA transmission*/
(heth->Instance)->DMATPDR = 0U;
/* Set ETH HAL State to Ready */
__HAL_UNLOCK(heth);
/* Return function status */
return HAL_OK;
