发表于 2019-12-4 11:04:00
找到个链接,10 月份就有人用 CubeMX 5.4 版本时发现了这个问题
https://community.st.com/s/quest ... when-generate-codes
ST Employee 给了这么一个解决办法,可以在 Project Manager - Advanced Settings 中调整函数调用顺序:
Hello,
The initialization order can be changed directly within STM32CubeMX, just go in the "Project Settings" tab, "Advanced Setting: section.
In the table "Generated Function Calls", you can select each line and thanks to two buttons at the bottom of the window, you can increase or decrease the rank of each function call.
同时还有另一位 ST Employee 承认了这是个问题,会在下一版本中修正,只是这个下一版本出得也太慢了。
Hello @User15718249183912214912 (Community Member) ,
Thanks for your feedback, this issue has already reported and it will be fixed in a next release.
Best Regards,
Khouloud
