发表于 2020-1-10 12:30:23
1 Features
1• Wide Power-Supply Range:
±5 V (10 V) to ±50 V (100 V)
• High-Output Load Drive: IO > ±50 mA
Electrical Characteristics: VS = ±50 V (continued)
(1) = 25°C, RL = 4.8 kΩ to mid-supply, VCM = VOUT = mid-supply, unless otherwise noted.
PARAMETER TEST CONDITIONS MIN TYP MAX UNIT
(8) See typical characteristic curve, Output Voltage Swing vs Output Current (Figure 10).
(9) Measured using Figure 56.
(10) See Typical Characteristics curves for current limit behavior.
(11) See typical characteristic curve, IENABLE vs VENABLE (Figure 45).
(12) High enables the outputs.
OUTPUT
VO Voltage output swing from rail(8)
RL = 49 kΩ, AOL ≥ 100 dB,
IO = 1 mA (V–) + 1 (V+) – 1 V
RL = 4.8 kΩ, AOL ≥ 100 dB,
IO = 10 mA (V–) + 1 (V+) – 2 V
RL = 1880 Ω, AOL ≥ 80 dB,
IO = 26 mA (V–) + 2 (V+) – 3 V
这是手册上的数据 |
