发表于 2020-3-23 18:32:32
u8 AdcOk;
u8 Cy_Spa; //功率采样间隔
/*************本程序实现4个半字循环刷新****************/
s16 SPI1_Rx_Buff1[Rx_Len]; //DMA指向内存地址,存放SPI接收数据
s16 SPI1_Rx_Buff2[Rx_Len]; //DMA指向内存地址,存放SPI接收数据
u16 SPI1_Tx_Buff[4]={0xd000,0xd000,0xd000,0xd000}; //存放SPI发送数据
u16 VinMax=0;
u16 VinMin=0;
u16 IinMax=0;
u16 IinMin=0;
struct data Adc_Data;
/**********************程序开始**********************/
//u16 SPI1_Rx_Buff[40]; //DMA指向内存地址,存放SPI接收数据
//u16 SPI1_Tx_Buff[8]={0xd000,0xd100,0xd200,0xd300,0xd000,0xd100,0xd200,0xd300}; //存放SPI发送数据
void GPIO_Config(void)
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);//使能GPIOB时钟
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC, ENABLE);//使能GPIOB时钟
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOE, ENABLE);//使能GPIOG时钟
//GPIOC4
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;//RESET
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;//输出
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;//推挽输出
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;//100MHz
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;//上拉
GPIO_Init(GPIOC, &GPIO_InitStructure);//初始化
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5; //BUSY
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;//普通输入模式
GPIO_Init(GPIOC, &GPIO_InitStructure);//初始化GPIOE2,3,4
void SPI1_Init(void)
SPI_InitTypeDef SPI_InitStructure;
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA,ENABLE);//使能GPIOA时钟
RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1,ENABLE);//使能SPI1时钟
//PA5,6,7初始化设置
GPIO_InitStructure.GPIO_Pin =GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6;//|GPIO_Pin_7;//PA5~7复用功能输出
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;//复用功能
GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化
//GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4|GPIO_Pin_7; //BUSY
//GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;//普通输入模式
//GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;//100M
//GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;//上拉
//GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化GPIOE2,3,4
GPIO_PinAFConfig(GPIOA, GPIO_PinSource4, GPIO_AF_SPI1);//PA4复用为 SPI1
GPIO_PinAFConfig(GPIOA, GPIO_PinSource5, GPIO_AF_SPI1);//PA5复用为 SPI1
GPIO_PinAFConfig(GPIOA, GPIO_PinSource6, GPIO_AF_SPI1);//PA6复用为 SPI1
//GPIO_PinAFConfig(GPIOA, GPIO_PinSource7, GPIO_AF_SPI1);//PA7复用为 SPI1
//这里只针对SPI口初始化
RCC_APB2PeriphResetCmd(RCC_APB2Periph_SPI1,ENABLE);//复位SPI1
RCC_APB2PeriphResetCmd(RCC_APB2Periph_SPI1,DISABLE);//停止复位SPI1
SPI_InitStructure.SPI_Direction = SPI_Direction_1Line_Rx;//SPI_Direction_2Lines_FullDuplex;
SPI_InitStructure.SPI_Mode = SPI_Mode_Slave;//SPI_Mode_Master; //为主SPI
SPI_InitStructure.SPI_DataSize = SPI_DataSize_16b; //SPI发送接收16位帧结构
SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;//Low; //串行同步时钟的空闲状态为低电平
SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge; //串行同步时钟的第二个跳变沿(上升或下降)数据被采样
SPI_InitStructure.SPI_NSS = SPI_NSS_Hard;//SPI_NSS_Soft; //NSS信号由软件管理
SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_8; //波特率预分频值为4(21MHz)
SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB; //数据从MSB位开始
SPI_InitStructure.SPI_CRCPolynomial = 7; //CRC值计算的多项式
SPI_Init(SPI1, &SPI_InitStructure);
SPI_Cmd(SPI1, ENABLE); //使能SPI外设
void DMA_Config(void)
DMA_InitTypeDef DMA_InitStructure;
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2, ENABLE);
/* DMA disable*/
DMA_Cmd(DMA2_Stream2, DISABLE);
DMA_Cmd(DMA2_Stream3, DISABLE);
DMA_DeInit(DMA2_Stream2);
DMA_DeInit(DMA2_Stream3);
// SPI1 RX DMA 配置 Stream2
DMA_InitStructure.DMA_Channel = DMA_Channel_3;//DMA_Channel_6;
DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)&SPI1->DR; //指定DMA的外设基地址为SPI1的数据地址
DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)SPI1_Rx_Buff1; //指定DMA的内存基地址
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory; //DMA传输方向为读外设 写到内存
DMA_InitStructure.DMA_BufferSize = Rx_Len;//DataSize; //传输数量(0-65535,不能为0)
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; //失能外设地址增长
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; //使能内存地址增长 免去FOR循环
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; //PSIZE=16bit
DMA_InitStructure.DMA_MemoryDataSize = DMA_PeripheralDataSize_HalfWord; //MSIZE=16bit
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; //DMA_Mode_Normal; //DMA模式为非循环模式,非循环模式只进行单次传输。
DMA_InitStructure.DMA_Priority = DMA_Priority_High; //优先权为高
DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable; //失能FIFO模式
DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull; //FIFO的阀值为半满
DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single; //内存突发传输为单一
DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single; //外设突发传输为单一
DMA_DoubleBufferModeConfig(DMA2_Stream2, (uint32_t)SPI1_Rx_Buff2, DMA_Memory_0);//DMA双缓存模式
DMA_DoubleBufferModeCmd(DMA2_Stream2, ENABLE);
DMA_Init(DMA2_Stream2, &DMA_InitStructure); //初始化DMA2_Stream2
//DMA_ITConfig(DMA2_Stream2, DMA_IT_TC, ENABLE);//使能传输完成中断
// SPI1 TX DMA 配置 Stream3
DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)SPI1_Tx_Buff; //指定DMA的内存基地址
DMA_InitStructure.DMA_DIR = DMA_DIR_MemoryToPeripheral; //DMA传输方向为读内存,写外设
DMA_InitStructure.DMA_BufferSize = 2;//DataSize; //传输数量(0-65535,不能为0)
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; //失能内存地址增长
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;//DMA_Mode_Normal; // //DMA模式为非循环模式,非循环模式只进行单次传输。
DMA_InitStructure.DMA_Priority = DMA_Priority_Medium ; //优先权为中等
DMA_Init(DMA2_Stream3, &DMA_InitStructure); //初始化DMA2_Stream3
//DMA_ITConfig(DMA2_Stream3, DMA_IT_TC, ENABLE); //因为是发送虚拟数据。不需要中断
/* Enable the SPI Rx DMA request */
SPI_I2S_DMACmd(SPI1, SPI_I2S_DMAReq_Rx, ENABLE);
SPI_I2S_DMACmd(SPI1, SPI_I2S_DMAReq_Tx, ENABLE);
/* 打开DMA通道 */
/* DMA enable*/
DMA_Cmd(DMA2_Stream2, ENABLE);
DMA_Cmd(DMA2_Stream3, ENABLE);
void SPI1_DMA_NVIC_Config(void)
NVIC_InitTypeDef NVIC_InitStructure;
//Enable the DMA2 Stream2 (SPI1_RX) Interrupt
NVIC_InitStructure.NVIC_IRQChannel = DMA2_Stream2_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
//Enable the DMA2 Stream3 (SPI1_TX) Interrupt
NVIC_InitStructure.NVIC_IRQChannel = DMA2_Stream3_IRQn;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;
void TIM1_Init(u16 period)//period设置24以1MHz采样,period设置240以100KHz采样,period设置2400以10KHz采样,period设置24000以1KHz采样,
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
TIM_OCInitTypeDef TIM_OCInitStructure;
//TIM_BDTRInitTypeDef TIM1_BDTRInitStruct;
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOE, ENABLE);//使能GPIOE时钟
RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_9 | GPIO_Pin_10 |GPIO_Pin_11| GPIO_Pin_12 |GPIO_Pin_13;
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF;//模式必须为复用
//GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
GPIO_InitStructure.GPIO_Speed=GPIO_Speed_100MHz;//频率为快速
GPIO_InitStructure.GPIO_PuPd=GPIO_PuPd_UP;
GPIO_Init(GPIOE, &GPIO_InitStructure);
//GPIO_PinAFConfig(GPIOE, GPIO_PinSource8, GPIO_AF_TIM1);//PE8 作为 AD的/convst信号
GPIO_PinAFConfig(GPIOE, GPIO_PinSource9, GPIO_AF_TIM1);
GPIO_PinAFConfig(GPIOE, GPIO_PinSource10, GPIO_AF_TIM1);//PE12 作为 AD的/CS信号
GPIO_PinAFConfig(GPIOE, GPIO_PinSource11, GPIO_AF_TIM1);
GPIO_PinAFConfig(GPIOE, GPIO_PinSource12, GPIO_AF_TIM1);//PE12 作为 AD的/CS信号
GPIO_PinAFConfig(GPIOE, GPIO_PinSource13, GPIO_AF_TIM1);
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_7;
GPIO_PinAFConfig(GPIOA, GPIO_PinSource7, GPIO_AF_TIM1);//PE8 作为 AD的/convst信号
//初始化
TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; //死区控制用。
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Down;//Up; //向上计数
TIM_TimeBaseStructure.TIM_Prescaler = 1;//7 - 1; //Timer clock = 168M /(TIM_Prescaler+1) = 24M
TIM_TimeBaseStructure.TIM_RepetitionCounter = 4;
TIM_TimeBaseStructure.TIM_Period = period - 1;
TIM_TimeBaseInit(TIM1,&TIM_TimeBaseStructure);
/****** 配置BDTR寄存器,配置死区时间****************/
定时器时钟 72M TIM_ClockDivision = TIM_CKD_DIV1时, Tdts = 13.89ns
0 - 1.764us 用算法一
1.778us - 3.505us 用算法二
3.556us - 7.000us 用算法三
7.1117us - 14us 用算法四
需要更长时间,使用TIM_ClockDivision分频
TIM1_BDTRInitStruct.TIM_OSSRState = TIM_OSSRState_Disable; //工作模式下死区刹车
TIM1_BDTRInitStruct.TIM_OSSIState = TIM_OSSIState_Disable; //空闲模式下死区刹车
TIM1_BDTRInitStruct.TIM_LOCKLevel = TIM_LOCKLevel_OFF; // 锁定配置
TIM1_BDTRInitStruct.TIM_DeadTime = 205; //死区时间 72:1us 172:3us 205:5us
TIM_BDTRConfig(TIM1,&TIM1_BDTRInitStruct);//*/
//配置输出比较,产生PWM方波
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;//PWM1为正常占空比模式,PWM2为反极性模式
TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;//输出反相 TIM_OCNPolarity_Low;//输出同相,
TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCNIdleState_Reset;
TIM_OCInitStructure.TIM_Pulse = 1;//130 CS脉冲出现后多久出现时钟信号
TIM_OC1Init(TIM1,&TIM_OCInitStructure);//触发DMA2_Stream3 channel6
TIM_OCInitStructure.TIM_Pulse =3;//ccr2;
TIM_OC2Init(TIM1,&TIM_OCInitStructure);//触发DMA2_Stream2 channel6
TIM_OCInitStructure.TIM_Pulse =3;//230ccr3;//PE12 作为 AD的/CS信号
TIM_OC3Init(TIM1,&TIM_OCInitStructure);
//TIM_Cmd(TIM1,ENABLE);
TIM_CtrlPWMOutputs(TIM1,ENABLE);
//TIM_SelectSlaveMode(TIM1,0x06);
//TIM_SelectInputTrigger(TIM1, TIM_TS_ITR3);
//TIM_SelectOnePulseMode(TIM1, TIM_OPMode_Repetitive);//TIM_OPMode_Single);
TIM_SelectSlaveMode(TIM1, TIM_SlaveMode_Gated);//);//TIM_SlaveMode_Reset);//TIM_SlaveMode_Gated); //TIM1门控模式
TIM_SelectInputTrigger(TIM1, TIM_TS_ITR3); //控制源TIM4
//TIM1->SMCR = 0x8035;//TIM1受控TIM4(复位模式)
/* TIM1 DMA 请求使能 */
TIM_DMACmd(TIM1, TIM_DMA_CC1 | TIM_DMA_CC2, ENABLE);//
//TIM_DMACmd(TIM1, TIM_DMA_CC2, ENABLE);//
TIM_Cmd(TIM1,DISABLE);//ENABLE);
void TIM4_Init(u16 period)
//NVIC_InitTypeDef NVIC_InitStructure;
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4,ENABLE); //TIM4时钟使能
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE); //是能 PORTD时钟
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD, ENABLE); //是能 PORTD时钟
GPIO_PinAFConfig(GPIOD,GPIO_PinSource14,GPIO_AF_TIM4); //GD14复用为TIM4
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14; //GPIO D14
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; //复用功能
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz; //速度100MHz
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; //推挽复用输出
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; //上拉
GPIO_Init(GPIOD,&GPIO_InitStructure); //初始化PD14*/
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6|GPIO_Pin_7; //GPIO D14
GPIO_Init(GPIOB,&GPIO_InitStructure); //初始化PD14
GPIO_PinAFConfig(GPIOB, GPIO_PinSource6, GPIO_AF_TIM4);//PD12 作为 AD的/触发信号
GPIO_PinAFConfig(GPIOB, GPIO_PinSource7, GPIO_AF_TIM4);//PD13 作为 AD的/CS信号
//GPIO_PinAFConfig(GPIOD, GPIO_PinSource12, GPIO_AF_TIM4);//PD12 作为 AD的/触发信号
//GPIO_PinAFConfig(GPIOD, GPIO_PinSource13, GPIO_AF_TIM4);//PD13 作为 AD的/CS信号
//GPIO_PinAFConfig(GPIOD, GPIO_PinSource14, GPIO_AF_TIM4);
//GPIO_PinAFConfig(GPIOD, GPIO_PinSource15, GPIO_AF_TIM4);
//初始化
TIM_TimeBaseInit(TIM4,&TIM_TimeBaseStructure);
//配置输出比较,产生PWM方波
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;//High;
TIM_OCInitStructure.TIM_Pulse = 79;//160/2;//202/2 ccr1;//PD12 作为 AD_CS脉冲宽度
TIM_OC1Init(TIM4,&TIM_OCInitStructure);//触发DMA2_Stream3 channel6
TIM_OCInitStructure.TIM_Pulse = 1;//ccr2;
TIM_OC2Init(TIM4,&TIM_OCInitStructure);//触发DMA2_Stream2 channel6
TIM_OCInitStructure.TIM_Pulse = 1;//ccr3;//PD14 作为 AD的/CS信号
TIM_OC3Init(TIM4,&TIM_OCInitStructure);
// TIM_Cmd(TIM4,ENABLE);
TIM_CtrlPWMOutputs(TIM4,ENABLE);
TIM_SelectMasterSlaveMode(TIM4, TIM_MasterSlaveMode_Enable);
TIM_SelectOutputTrigger(TIM4, TIM_TRGOSource_OC1Ref);//TIM_TRGOSource_OC1Ref);//TIM_TRGOSource_OC1Ref);
/*TIM2中断设置*/
//TIM_ClearFlag(TIM4,TIM_IT_CC1);
//TIM_ITConfig(TIM4,TIM_IT_CC1,ENABLE);
//NVIC_SetPriorityGrouping(NVIC_PriorityGroup_0);
//NVIC_InitStructure.NVIC_IRQChannel = TIM4_IRQn;
//NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
//NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
//NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
//NVIC_Init(&NVIC_InitStructure);
TIM_Cmd(TIM4,DISABLE);//ENABLE);
/* TIM4 DMA 请求使能 */
//TIM_DMACmd(TIM4, TIM_DMA_CC1 | TIM_DMA_CC2, ENABLE);//
* Function Name : void ad7606_init(void)
* Description : AD7606初始化
* Input :
* Output : None
* Return :
GPIO_Config();
SPI1_Init();
DMA_Config();
SPI1_DMA_NVIC_Config();
TIM1_Init(5); //SPI时钟
TIM4_Init(3500);//350_100KHz 3500_10k//采样速度 调整采样速度需同时调整采样间隔以满足数据读取要求
RST = 1;
delay_ms(300);
RST = 0;
最终还是采用了从模式,TIM1产生时钟,TIM4产生CS、CON信号。 |
