尝试用go语言操作gpio驱动oled,驱动方式是spi,io操作方式是文件方式。由于这种方式需要不断写文件,oled刷新有点慢。后期会改成mmap方式。
oled_spi的github
oled驱动:
- package oled
- import (
- "oled_spi/gpio"
- "time"
- const (
- OLED_CLK = "gpio131"
- OLED_DI = "gpio132"
- OLED_RST = "gpio133"
- OLED_DC = "gpio138"
- OLED_CS = "gpio139"
- OLED_CMD = 0 //写命令
- OLED_DATA = 1 //写数据
- SIZE = 16
- Max_Column = 128
- Max_Row = 64
- func Init() {
- gpio.OpenGpioFile(OLED_CLK)
- gpio.OpenGpioFile(OLED_DI)
- gpio.OpenGpioFile(OLED_RST)
- gpio.OpenGpioFile(OLED_DC)
- gpio.OpenGpioFile(OLED_CS)
- SetRst()
- time.Sleep(time.Millisecond * 100)
- ClrRst()
- SetRst()
- WriteByte(0xAE, OLED_CMD) //--turn off oled panel
- WriteByte(0x00, OLED_CMD) //---set low column address
- WriteByte(0x10, OLED_CMD) //---set high column address
- WriteByte(0x40, OLED_CMD) //--set start line address Set Mapping RAM Display Start Line (0x00~0x3F)
- WriteByte(0x81, OLED_CMD) //--set contrast control register
- WriteByte(0x66, OLED_CMD) // Set SEG Output Current Brightness
- WriteByte(0xA1, OLED_CMD) //--Set SEG/Column Mapping 0xa0左右反置 0xa1正常
- WriteByte(0xC8, OLED_CMD) //Set COM/Row Scan Direction 0xc0上下反置 0xc8正常
- WriteByte(0xA6, OLED_CMD) //--set normal display
- WriteByte(0xA8, OLED_CMD) //--set multiplex ratio(1 to 64)
- WriteByte(0x3f, OLED_CMD) //--1/64 duty
- WriteByte(0xD3, OLED_CMD) //-set display offset Shift Mapping RAM Counter (0x00~0x3F)
- WriteByte(0x00, OLED_CMD) //-not offset
- WriteByte(0xd5, OLED_CMD) //--set display clock divide ratio/oscillator frequency
- WriteByte(0x80, OLED_CMD) //--set divide ratio, Set Clock as 100 Frames/Sec
- WriteByte(0xD9, OLED_CMD) //--set pre-charge period
- WriteByte(0xF1, OLED_CMD) //Set Pre-Charge as 15 Clocks & Discharge as 1 Clock
- WriteByte(0xDA, OLED_CMD) //--set com pins hardware configuration
- WriteByte(0x12, OLED_CMD)
- WriteByte(0xDB, OLED_CMD) //--set vcomh
- WriteByte(0x40, OLED_CMD) //Set VCOM Deselect Level
- WriteByte(0x20, OLED_CMD) //-Set Page Addressing Mode (0x00/0x01/0x02)
- WriteByte(0x02, OLED_CMD) //
- WriteByte(0x8D, OLED_CMD) //--set Charge Pump enable/disable
- WriteByte(0x14, OLED_CMD) //--set(0x10) disable
- WriteByte(0xA4, OLED_CMD) // Disable Entire Display On (0xa4/0xa5)
- WriteByte(0xA6, OLED_CMD) // Disable Inverse Display On (0xa6/a7)
- WriteByte(0xAF, OLED_CMD) //--turn on oled panel
- WriteByte(0xAF, OLED_CMD) /*display ON*/
- Clear()
- SetPos(0, 0)
- func SetClk() {
- gpio.GpioNSetValue(OLED_CLK, "1")
- func ClrClk() {
- gpio.GpioNSetValue(OLED_CLK, "0")
- func SetDi() {
- gpio.GpioNSetValue(OLED_DI, "1")
- func ClrDi() {
- gpio.GpioNSetValue(OLED_DI, "0")
- func SetRst() {
- gpio.GpioNSetValue(OLED_RST, "1")
- func ClrRst() {
- gpio.GpioNSetValue(OLED_RST, "0")
- func SetDc() {
- gpio.GpioNSetValue(OLED_DC, "1")
- func ClrDc() {
- gpio.GpioNSetValue(OLED_DC, "0")
- func SetCs() {
- gpio.GpioNSetValue(OLED_CS, "1")
- func ClrCs() {
- gpio.GpioNSetValue(OLED_CS, "0")
- func WriteByte(dat, cmd byte) {
- if cmd != 0 {
- SetDc()
- } else {
- ClrDc()
- ClrCs()
- for i := 0; i < 8; i++ {
- ClrClk()
- if dat&0x80 != 0 {
- SetDi()
- } else {
- ClrDi()
- SetClk()
- dat <<= 1
- SetCs()
- SetDc()
- func SetPos(x, y byte) {
- WriteByte(0xb0+y, OLED_CMD)
- WriteByte(((x&0xf0)>>4)|0x10, OLED_CMD)
- WriteByte((x&0x0f)|0x01, OLED_CMD)
- func Clear() {
- for i := byte(0); i < 8; i++ {
- WriteByte(0xb0+i, OLED_CMD) //设置页地址(0~7)
- WriteByte(0x00, OLED_CMD) //设置显示位置—列低地址
- WriteByte(0x10, OLED_CMD) //设置显示位置—列高地址
- for n := 0; n < 128; n++ {
- WriteByte(0, OLED_DATA) //更新显示
- func ShowChar(x, y, chr byte) {
- c := chr - ' ' //得到偏移后的值
- if x > Max_Column-1 {
- x = 0
- y = y + 2
- if SIZE == 16 {
- SetPos(x, y)
- WriteByte(F8X16[int(c)*16+i], OLED_DATA)
- SetPos(x, y+1)
- WriteByte(F8X16[int(c)*16+i+8], OLED_DATA)
- } else {
- SetPos(x, y+1)
- func ShowString(x, y byte, chrs string) {
- for _, v := range []byte(chrs) {
- ShowChar(x, y, v)
- x += 8
- if x > 120 {
- x = 0
- y += 2
复制代码 |
一整个繁琐流程,就是为了出锅时那一嘴滚烫流油的热饺子。
