发表于 2020-4-8 10:38:59
Python build finished successfully!
The necessary bits to build these optional modules were not found:
_bz2 _curses _curses_panel
_dbm _gdbm _hashlib
_lzma _sqlite3 _ssl
_tkinter _uuid readline
zlib
To find the necessary bits, look in setup.py in detect_modules() for the module's name.
The following modules found by detect_modules() in setup.py, have been
built by the Makefile instead, as configured by the Setup files:
_abc atexit pwd
time
Failed to build these modules:
_ctypes
Could not build the ssl module!
Python requires an OpenSSL 1.0.2 or 1.1 compatible libssl with X509_VERIFY_PARAM_set1_host().
LibreSSL 2.6.4 and earlier do not provide the necessary APIs, https://github.com/libressl-portable/portable/issues/381
running build_scripts
creating build/scripts-3.7
copying and adjusting /home/kyq/python/Python-3.7.5/Tools/scripts/pydoc3 -> build/scripts-3.7
copying and adjusting /home/kyq/python/Python-3.7.5/Tools/scripts/idle3 -> build/scripts-3.7
copying and adjusting /home/kyq/python/Python-3.7.5/Tools/scripts/2to3 -> build/scripts-3.7
copying and adjusting /home/kyq/python/Python-3.7.5/Tools/scripts/pyvenv -> build/scripts-3.7
changing mode of build/scripts-3.7/pydoc3 from 664 to 775
changing mode of build/scripts-3.7/idle3 from 664 to 775
changing mode of build/scripts-3.7/2to3 from 664 to 775
changing mode of build/scripts-3.7/pyvenv from 664 to 775
renaming build/scripts-3.7/pydoc3 to build/scripts-3.7/pydoc3.7
renaming build/scripts-3.7/idle3 to build/scripts-3.7/idle3.7
renaming build/scripts-3.7/2to3 to build/scripts-3.7/2to3-3.7
renaming build/scripts-3.7/pyvenv to build/scripts-3.7/pyvenv-3.7
/usr/bin/install -c -m 644 ./Tools/gdb/libpython.py python-gdb.py
arm-linux-gnueabihf-gcc -c -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -std=c99 -Wextra -Wno-unused-result -Wno-unused-parameter -Wno-missing-field-initializers -Werror=implicit-function-declaration -I. -I./Include -DPy_BUILD_CORE -o Programs/_testembed.o ./Programs/_testembed.c
arm-linux-gnueabihf-gcc -Xlinker -export-dynamic -o Programs/_testembed Programs/_testembed.o libpython3.7m.a -lcrypt -lpthread -ldl -lpthread -lutil -lm
sed -e "s,@EXENAME@,/home/kyq/python/Python-3.7.5/pyinstall/bin/python3.7m," < ./Misc/python-config.in >python-config.py
LC_ALL=C sed -e 's,\$(\([A-Za-z0-9_]*\)),\$\{\1\},g' < Misc/python-config.sh >python-config |
