发表于 2020-4-16 15:37:10
- #include "Globals.h"
- #define LCD_RST_1 GPIO_SetBits(GPIOA,GPIO_Pin_11)
- #define LCD_RST_0 GPIO_ResetBits(GPIOA,GPIO_Pin_11)
- #define LCD_CS_1 GPIO_SetBits(GPIOC,GPIO_Pin_8)
- #define LCD_CS_0 GPIO_ResetBits(GPIOC,GPIO_Pin_8)
- #define LCD_CLK_1 GPIO_SetBits(GPIOA,GPIO_Pin_8)
- #define LCD_CLK_0 GPIO_ResetBits(GPIOA,GPIO_Pin_8)
- #define LCD_SID_1 GPIO_SetBits(GPIOC,GPIO_Pin_9)
- #define LCD_SID_0 GPIO_ResetBits(GPIOC,GPIO_Pin_9)
- void Mmemcpy(unsigned char *Out,const char *In, unsigned char L)
- { unsigned char i;for(i=0;i<L;i++)Out[i]=In[i];
- unsigned char LCDdat[64];//此处不能用 idata 显示缓存
- void write(char cmd, unsigned char dat) //写指令或数据
- { unsigned char i,j,Temp;
- LCD_CS_1;
- LCD_CLK_0;
- for(j=0;j<3;j++)
- if (j==0){ Temp =( cmd? 0xfa:0xf8);} //数据cmd=1:0xfa 命令cmd=0:0xf8
- else if (j==1){ Temp =((dat<<0) & 0xf0);}
- else if (j==2){ Temp =((dat<<4) & 0xf0);}
- for(i=0;i<8;i++)
- (Temp&0x80)?(LCD_SID_1):(LCD_SID_0); Temp<<=1; delay_us(1); //左移
- LCD_CLK_1; delay_us(1); //_nop_();_nop_();//移入
- LCD_CLK_0; delay_us(1); //_nop_();_nop_();_nop_(); //读出
- } //_nop_();_nop_();_nop_();_nop_(); //延时
- LCD_CS_0;
- void LCD_setWhite2(unsigned char x,unsigned char y,unsigned char left,unsigned char right)
- unsigned char i;
- if(y>1)
- y-=2;
- x+=8;
- write(0,0x34);
- write(0,0x36);
- for(i=0;i<16;i++)
- write(0,0x80+i+y*16);
- write(0,0x80+x);
- write(1,left);
- write(1,right);
- // write(0,0x36);
- write(0,0x30);
- void LCD_ClearGM(void)
- unsigned char i,j;
- write(0,0x34);
- write(0,0x36);
- for(j=0;j<32;j++)
- write(0,0x80+j);
- write(0,0x80);
- for(i=0;i<16;i++)
- write(1,0x00);
- for(j=0;j<32;j++)
- write(0,0x80+j);
- write(0,0x88);
- for(i=0;i<16;i++)
- write(1,0x00);
- write(0,0x30);
- void LCD_RefreshALL(void) //模拟刷屏12864
- unsigned char X,Y,Addr;
- for(X=0;X<4;X++) //送四行汉字
- { switch(X) //一次送一个汉字
- { case 0: Addr=0x80;break;
- case 1: Addr=0x90;break;
- case 2: Addr=0x88;break;
- case 3: Addr=0x98;break;
- default:Addr=0x80;break;
- } write(0,Addr); //先送地址后送16个字符
- for(Y=0;Y<16;Y++){write(1,LCDdat[(X*16)+Y]);}
- //测试
- void LCD_Test(void)
- const char Tab[][16]={
- Mmemcpy(LCDdat+0, Tab[0],16); //送出
- Mmemcpy(LCDdat+16,Tab[1],16); //送出
- Mmemcpy(LCDdat+32,Tab[2],16); //送出
- Mmemcpy(LCDdat+48,Tab[3],16); //送出
- LCD_RefreshALL(); //更新显示
- void LCD_Clear(void)
- LCD_ClearGM();
- //显示一行
- void LCD_ShowLine(unsigned char y,char *pStr)
- Mmemcpy(LCDdat+16*y, pStr,16); //送出
- // printf("==%s \r\n",pStr);
- //此函数有个缺陷,就是无法知道二维字符串的一维的长度,会把后面的字符串也显示出来
- void LCD_ShowString(unsigned char x,unsigned char y,const char *pStr)
- unsigned char i;
- unsigned int strLen;
- // unsigned char strBuff[16]; //一行字符缓存
- strLen = strlen(pStr); //字符串长度用 strlen(); 类型长度 sizeof();
- // if(strLen>16) strLen = 16;
- // strLen = (sizeof(pStr)/sizeof(pStr[0]));
- // printf("Str Len=%d \r\n",strLen);
- if(strLen>16) strLen = 16; //一行总长度最多显示16个字符,多余的不显示
- else if(strLen==0) return; //空
- // memset(strBuff,' ',sizeof(strBuff));
- for(i=0;i<strLen;i++)
- LCDdat[16*y+x+i] = pStr[i];
- void LCD_ShowStringLen(unsigned char x,unsigned char y,const char *pStr,unsigned char len)
- unsigned char i;
- strLen = len; //字符串长度用 strlen(); 类型长度 sizeof();
- void LCD_ShowNumber(unsigned char x,unsigned char y,long num,unsigned char disLen,unsigned char align)
- unsigned char i;
- char strBuff[16]; //一行字符缓存
- char disBuff[16]; //一行字符缓存用于显示
- unsigned int strLen; //字符串长度用 strlen(); 类型长度 sizeof();
- if(disLen>16 || disLen==0) return;
- memset(strBuff,0,sizeof(strBuff));
- memset(disBuff,0,sizeof(disBuff));
- sprintf(strBuff,"%ld",num);
- strLen = strlen(strBuff);
- // printf("%s : ",strBuff);
- // printf("%d \r\n",strLen);
- if(align==0) //左对齐
- if(strLen>=disLen) //当数字位数大于要显示的长度时,显示高位
- for(i=0;i<disLen;i++)
- disBuff[i] = strBuff[i];
- else
- if(i<strLen)
- else
- disBuff[i] = ' '; //后面补空格
- else //右对齐
- else
- unsigned char dx = disLen-strLen;
- if(i<dx)
- disBuff[i] = ' '; //前面补空格
- else
- disBuff[i] = strBuff[i-dx];
- LCD_ShowString(x,y,disBuff);
- LCD初始化
- void LCD_Config(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- // RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOC, ENABLE );
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8|GPIO_Pin_9;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;
- GPIO_Init(GPIOC, &GPIO_InitStructure);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8|GPIO_Pin_11;
- GPIO_Init(GPIOA, &GPIO_InitStructure);
- LCD_RST_0; delay_ms(500);
- LCD_RST_1; delay_ms(500);//复位
- write(0,0x30); //8 位介面,基本指令集
- write(0,0x0c); //显示打开,光标关,反白关
- write(0,0x01); //清屏,将DDRAM的地址计数器归零
- delay_ms(500);
- LCD_Clear();
- LCD_Test();
复制代码 |
