发表于 2020-7-7 17:11:44
分配DMA3位DAC2服务!
输入Flash的数据表格地址,和长度!
void DMA_SetChannel3_for_DAC2(const unsigned short *flashAdr,unsigned int cnt){
DMA_InitTypeDef DMA_InitStructure;
DMA_DeInit(DMA1_Channel3);
DMA_InitStructure.DMA_PeripheralBaseAddr =(unsigned int)&(DAC->DHR12R2); //指向右对齐寄存器12位
DMA_InitStructure.DMA_MemoryBaseAddr =(u32)flashAdr;
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;
DMA_InitStructure.DMA_BufferSize = cnt;
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; //数据采用覆盖方式
DMA_InitStructure.DMA_Priority = DMA_Priority_High;
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
DMA_Init(DMA1_Channel3, &DMA_InitStructure);
/* Enable DMA1 Channel3 */
DMA_Cmd(DMA1_Channel3, ENABLE);
分配DMA2位DAC1服务!
输入Flash的数据表格地址,和长度!
void DMA_SetChannel2_for_DAC1(const unsigned short *flashAdr,unsigned int cnt){
DMA_DeInit(DMA1_Channel2);
DMA_InitStructure.DMA_PeripheralBaseAddr =(unsigned int)&(DAC->DHR12R1); //指向右对齐寄存器12位
DMA_Init(DMA1_Channel2, &DMA_InitStructure);
DMA_Cmd(DMA1_Channel2, ENABLE);
定时器6触发,同步输出DAC1,DAC2
必须事先生成双字节数据表在Flash里。 DAC_DHR12RD
void DMA_Set_for_DAC12(unsigned int *flashAdr,unsigned int cnt){
DMA_InitStructure.DMA_PeripheralBaseAddr =(unsigned int)&(DAC->DHR12RD); //指向右对齐寄存器12位
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Word;
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Word;
//DMA for ADC
//DMA 1 为ADC-1-2服务
void DMA_SetChannel1_for_ADC1(unsigned short *pBuf,unsigned int cnt){
/* DMA1 channel1 configuration */
DMA_DeInit(DMA1_Channel1);
DMA_InitStructure.DMA_PeripheralBaseAddr = (unsigned int)&(ADC1->DR);
DMA_InitStructure.DMA_MemoryBaseAddr = (unsigned int)pBuf;
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC; //adc-->ram
DMA_InitStructure.DMA_MemoryInc =DMA_MemoryInc_Enable;// DMA_MemoryInc_Disable;//当前存储器地址不变!
DMA_InitStructure.DMA_Mode = DMA_Mode_Normal ; //传送完毕后产生中断,并停止!
DMA_Init(DMA1_Channel1, &DMA_InitStructure);
/* Enable DMA1 Channel6 Transfer Complete interrupt */
DMA_ITConfig(DMA1_Channel1, DMA_IT_TC, ENABLE);
/* Enable DMA1 channel1 */
DMA_Cmd(DMA1_Channel1, DISABLE);
//DMA 1 为ADC-3ch-6ch服务
void DMA_SetChannel1_for_ADC3(unsigned short *pBuf,unsigned int cnt){
DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)&pBuf;
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular ; //传送完毕后产生中断,并停止!
DMA_ITConfig(DMA1_Channel1, DMA_IT_TC, DISABLE);
DMA_Cmd(DMA1_Channel1, ENABLE);
