下面是设置读保护的代码,设置后读出来验证是没问题的,但是实际上下一次重启(软件重启、硬件重启),或者断电重启都无效。。。
- int FLASH_SetRDP(uint8_t level)
- FLASH_OBProgramInitTypeDef OBInit;
- if (level == OB_RDP_LEVEL_2) {
- return -1;
- __HAL_FLASH_PREFETCH_BUFFER_DISABLE();
- printf("\n==> 0x%08x\n", (*(__IO uint32_t*)(OPTCR_BYTE0_ADDRESS)));
- HAL_FLASHEx_OBGetConfig(&OBInit);
- if(OBInit.RDPLevel == OB_RDP_LEVEL_0 && level == OB_RDP_LEVEL_1)
- printf("set RDP to %02x\n", OB_RDP_LEVEL_1);
- OBInit.OptionType = OPTIONBYTE_RDP;
- OBInit.RDPLevel = OB_RDP_LEVEL_1;
- HAL_FLASH_Unlock();
- HAL_FLASH_OB_Unlock();
- //Flash interface register: 0x40023C00 - 0x40023FFF
- HAL_FLASHEx_OBProgram(&OBInit);
- HAL_FLASH_OB_Lock();
- HAL_FLASH_Lock();
- } else {
- printf("RDP Level already: 0x%02x\n", OBInit.RDPLevel);
- __HAL_FLASH_PREFETCH_BUFFER_ENABLE();
- return 0;
复制代码 |
