发表于 2021-1-18 12:42:49
不知道你用的什么开发环境,去menuconfig 那里,
将UART for console output 设置成none . 这样就可以用UART0 了。
其它两个串口默认是开放可用的。
uart_config_t uart_config = {
.baud_rate = 115200,
.data_bits = UART_DATA_8_BITS,
.parity = UART_PARITY_DISABLE,
.stop_bits = UART_STOP_BITS_1,
.flow_ctrl = UART_HW_FLOWCTRL_DISABLE
uart_param_config(UART_NUM_0, &uart_config);
uart_set_pin(UART_NUM_0, GPIO_NUM_1, GPIO_NUM_3, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE);
uart_param_config(UART_NUM_1, &uart_config); //
uart_set_pin(UART_NUM_1, GPIO_NUM_4, GPIO_NUM_5, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE);
uart_param_config(UART_NUM_2, &uart_config);
uart_set_pin(UART_NUM_2, GPIO_NUM_17, GPIO_NUM_16, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE);
