mulitblock 读取 好像读取到的数据 不太正常 我用查询的方法来进行
调用
SD_ReadDisk(sdbuf,0,2); //通过 cmd18 SD_CMD_READ_MULT_BLOCK 读取开始两个扇区 的 1024 个字节
SD_ReadDisk(sdbuf,0,1); //通过 cmd17 SD_CMD_READ_SINGLE_BLOCK 读取第0扇区的 512字节
SD_ReadDisk(sdbuf,512,1); //通过 cmd17 SD_CMD_READ_SINGLE_BLOCK 读取第1扇区的 512字节
结果: SD_ReadDisk(sdbuf,0,2);的前512字节 和 SD_ReadDisk(sdbuf,0,1); 开头 4个字节 不一样
SD_ReadDisk(sdbuf,0,2);的后512字节 和 SD_ReadDisk(sdbuf,512,1); 完全不一样
SD_ReadDisk(sdbuf,0,2);前512字节
D8 C5 0E 00 53 44 4F 53 35 2E 30 00 02 08 E6 04
02 00 00 00 00 F8 00 00 3F 00 FF 00 00 00 00 00
00 70 76 00 8D 1D 00 00 00 00 00 00 02 00 00 00
01 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00
80 00 29 9F 93 9C E8 4E 4F 20 4E 41 4D 45 20 20
20 20 46 41 54 33 32 20 20 20 33 C9 8E D1 BC F4
7B 8E C1 8E D9 BD 00 7C 88 4E 02 8A 56 40 B4 41
BB AA 55 CD 13 72 10 81 FB 55 AA 75 0A F6 C1 01
74 05 FE 46 02 EB 2D 8A 56 40 B4 08 CD 13 73 05
B9 FF FF 8A F1 66 0F B6 C6 40 66 0F B6 D1 80 E2
3F F7 E2 86 CD C0 ED 06 41 66 0F B7 C9 66 F7 E1
66 89 46 F8 83 7E 16 00 75 38 83 7E 2A 00 77 32
66 8B 46 1C 66 83 C0 0C BB 00 80 B9 01 00 E8 2B
00 E9 2C 03 A0 FA 7D B4 7D 8B F0 AC 84 C0 74 17
3C FF 74 09 B4 0E BB 07 00 CD 10 EB EE A0 FB 7D
EB E5 A0 F9 7D EB E0 98 CD 16 CD 19 66 60 80 7E
02 00 0F 84 20 00 66 6A 00 66 50 06 53 66 68 10
00 01 00 B4 42 8A 56 40 8B F4 CD 13 66 58 66 58
66 58 66 58 EB 33 66 3B 46 F8 72 03 F9 EB 2A 66
33 D2 66 0F B7 4E 18 66 F7 F1 FE C2 8A CA 66 8B
D0 66 C1 EA 10 F7 76 1A 86 D6 8A 56 40 8A E8 C0
E4 06 0A CC B8 01 02 CD 13 66 61 0F 82 75 FF 81
C3 00 02 66 40 49 75 94 C3 42 4F 4F 54 4D 47 52
20 20 20 20 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 0D 0A 52 65
6D 6F 76 65 20 64 69 73 6B 73 20 6F 72 20 6F 74
68 65 72 20 6D 65 64 69 61 2E FF 0D 0A 44 69 73
6B 20 65 72 72 6F 72 FF 0D 0A 50 72 65 73 73 20
61 6E 79 20 6B 65 79 20 74 6F 20 72 65 73 74 61
72 74 0D 0A 00 00 00 00 00 AC CB D8 00 00 55 AA
SD_ReadDisk(sdbuf,0,2);后512字节
00 00 00 00 00 55 AA B2 B5 DA 22 B6 3F 51 A5 FF
FF FF FF FF FF FF FF FF FF FF FF 00 00 00 00 00
SD_ReadDisk(sdbuf,0,1);输出数据
EB 58 90 4D 53 44 4F 53 35 2E 30 00 02 08 E6 04
SD_ReadDisk(sdbuf,512,1);输出数据
52 52 61 41 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 72 72 41 61 D8 C5 0E 00 2A 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 55 AA
代码如下
- SD_Error SD_ReadBlock(u8 *buf,long long addr,u16 blksize,u32 nblks)
- SD_Error errorstatus=SD_OK;
- u32 blkcnt;
- u32 i;
- u32 timeout=SDIO_DATATIMEOUT,d;
- u32 *tempbuff=(u32*)buf; //转换为u32指针
- if(CardType==SDIO_HIGH_CAPACITY_SD_CARD)//大容量卡
- blksize=512;
- addr>>=9;
- SDIO_Send_Cmd(SD_CMD_SET_BLOCKLEN,1,blksize); //发送CMD16+设置数据长度为blksize,短响应
- errorstatus=CmdResp1Error(SD_CMD_SET_BLOCKLEN); //等待R1响应
- if(errorstatus!=SD_OK) return errorstatus; //响应错误
- SDIO_Send_Data_Cfg(SD_DATATIMEOUT,nblks*blksize,blksize,1); //nblks*blksize,块大小恒为512,卡到控制器
- TEST_SDIOx->BUF_CTL &= ~(1<<14);
- TEST_SDIOx->MMC_INT_MASK =0;
- TEST_SDIOx->CLR_MMC_INT = 0xFF; //清除中断标志位
- //TEST_SDIOx->MMC_CTRL|=(1<<9); //使能sd 中断
- printf("nblks=%d\r\n",nblks);
- if(nblks>1) //多块读
- SDIO_Send_Cmd(SD_CMD_READ_MULT_BLOCK,1,addr); //发送CMD18+从addr地址出读取数据,短响应
- errorstatus=CmdResp1Error(SD_CMD_READ_MULT_BLOCK); //等待R1响应
- if(errorstatus!=SD_OK)return errorstatus; //响应错误
- }else //单块读
- SDIO_Send_Cmd(SD_CMD_READ_SINGLE_BLOCK,1,addr); //发送CMD17+从addr地址出读取数据,短响应
- errorstatus=CmdResp1Error(SD_CMD_READ_SINGLE_BLOCK); //等待R1响应
- //SD_DMA_Config((u32*)buf,nblks*blksize,0); ]
- i=0;
- for(blkcnt=0;blkcnt<nblks;blkcnt++)
- ClearSdMsg();
- //TEST_SDIOx->MMC_INT_MASK=INT_MASK; //使能sd 中断(1<<0)|(1<<1)|(1<<6)|(1<<7);
- TEST_SDIOx->MMC_IO|=3;
- //TEST_SDIOx->BUF_CTL |= (1<<14); //SDIO DMA使能
- while(!(TEST_SDIOx->CLR_MMC_INT&((1<<2)|(1<<6)|(1<<1))));
- //errorstatus=WaitSdMsg(0);
- printf("msg:%d\r\n",errorstatus);
- while(!(TEST_SDIOx->BUF_CTL&(1<<1)))
- d=TEST_SDIOx->DATA_BUF0;
- printf("%02X %02X %02X %02X ",(d>>0)&0xff,(d>>8)&0xff,(d>>16)&0xff,(d>>24)&0xff);
- if(++i%4==0) printf("\r\n");
- if(nblks>1)
- SDIO_Send_Cmd(SD_CMD_STOP_TRANSMISSION,1,0); //发送CMD12+结束传输
- errorstatus=CmdResp1Error(SD_CMD_STOP_TRANSMISSION); //等待R1响应
- return errorstatus;
