我在打包IP时出现了以下警告, 能问一下这些警告是怎么产生的吗以及哪些是可以忽略的,另外当自定义IP中需要引用Xilinx ip时,在 "Synthesis Options" 中是选择"Global" 还是"Out of Context per IP",(是不是网表文件不能嵌套使用)
General Messages[IP_Flow 19-5226] Project source file 'd:/xilinx_project/EIT/ip_repo/SAMPLE_EIT_1.0/component.xml' ignored by IP packager.
IP PackagerPorts and Interfaces Wizard[IP_Flow 19-3157] Bus Interface 'adc_rst_n': Bus parameter POLARITY is ACTIVE_LOW but port 'adc_rst_n' is not *resetn - please double check the POLARITY setting.
[IP_Flow 19-5661] Bus Interface 'ad_clk' does not have any bus interfaces associated with it.
[IP_Flow 19-5661] Bus Interface 'da_clk' does not have any bus interfaces associated with it.
[IP_Flow 19-5661] Bus Interface 'clk_in1' does not have any bus interfaces associated with it.
[IP_Flow 19-5661] Bus Interface 'clk_10m' does not have any bus interfaces associated with it.
[IP_Flow 19-4751] Bus Interface 'ad_clk': FREQ_HZ bus parameter is missing for output clock interface.
[IP_Flow 19-4751] Bus Interface 'da_clk': FREQ_HZ bus parameter is missing for output clock interface.
[IP_Flow 19-4751] Bus Interface 'clk_10m': FREQ_HZ bus parameter is missing for output clock interface. |
