最近有一个项目需要用到RGB LED,选了内置IC的LED灯珠,MCU用GD32F330,PWM+DMA方式,用示波器发现波形不太对,高占空比切到低占空比没有问题,但从低占空比切到高占空比时就出现第一个高占空比波形不对
下面是代码:
#include "rgb_led.h"
const uint8_t g_red[3] = {0x00, 0xff, 0x00};
const uint8_t g_green[3] = {0xff, 0x00, 0x00};
const uint8_t g_blue[3] = {0x00, 0x00, 0xff};
uint16_t g_rgb_led_buf[(24*7+24)]=
// ZERO,ZERO,ZERO,ZERO,ONE,ONE,ONE,ONE,
// ZERO,ZERO,ZERO,ZERO,ZERO,ZERO,ZERO,ZERO,
ZERO
// uint8_t g_rgb_led_buf[48]=
// 0,0,0,0,0,0,0,0,
// 0,0,0,0,0,0,0,0,
// 0,0,0,0,0,0,0,0
void rgb_led_gpio_init(void)
rcu_periph_clock_enable(RCU_GPIOB);
/*Configure PB5(TIMER2_CH1) as alternate function*/
gpio_mode_set(GPIOB, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_4);
gpio_output_options_set(GPIOB, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ,GPIO_PIN_4);
gpio_af_set(GPIOB, GPIO_AF_1, GPIO_PIN_4);
void timer2_init(void)
/* TIMER2 configuration: generate PWM signals with different duty cycles:
TIMER2CLK = SystemCoreClock / 1 = 84MHz */
timer_oc_parameter_struct timer_ocintpara;
timer_parameter_struct timer_initpara;
rcu_periph_clock_enable(RCU_TIMER2);
timer_deinit(TIMER2);
/* TIMER0 configuration */
timer_initpara.prescaler = 1-1;
timer_initpara.alignedmode = TIMER_COUNTER_EDGE;
timer_initpara.counterdirection = TIMER_COUNTER_UP;
timer_initpara.period = 94-1; //PWM频率893K
timer_initpara.clockdivision = TIMER_CKDIV_DIV1;
timer_init(TIMER2,&timer_initpara);
/* CH0 configuration in PWM mode */
timer_ocintpara.outputstate = TIMER_CCX_ENABLE;
timer_ocintpara.ocpolarity = TIMER_OC_POLARITY_HIGH;
timer_channel_output_config(TIMER2,TIMER_CH_0,&timer_ocintpara);
timer_channel_output_pulse_value_config(TIMER2,TIMER_CH_0,0); //占空比66%
timer_channel_output_mode_config(TIMER2,TIMER_CH_0,TIMER_OC_MODE_PWM0);
timer_channel_output_shadow_config(TIMER2,TIMER_CH_0,TIMER_OC_SHADOW_DISABLE);
/* auto-reload preload enable */
//timer_auto_reload_shadow_enable(TIMER2);
timer_dma_disable(TIMER2, TIMER_DMA_CH0D);
void rgb_dma_init(void)
dma_parameter_struct dma_init_struct;
/* enable DMA clock */
rcu_periph_clock_enable(RCU_DMA);
/* initialize DMA channel */
dma_deinit(DMA_CH3);
/* DMA channel3 initialize */
dma_struct_para_init(&dma_init_struct);
dma_init_struct.direction = DMA_MEMORY_TO_PERIPHERAL;
dma_init_struct.memory_addr = (uint32_t)g_rgb_led_buf;
dma_init_struct.memory_inc = DMA_MEMORY_INCREASE_ENABLE;
dma_init_struct.memory_width = DMA_MEMORY_WIDTH_16BIT;
dma_init_struct.number = 0;
dma_init_struct.periph_addr = (uint32_t)TIMER2_CH0CV_ADDR;
dma_init_struct.periph_inc = DMA_PERIPH_INCREASE_DISABLE;
dma_init_struct.periph_width = DMA_PERIPHERAL_WIDTH_16BIT;
dma_init_struct.priority = DMA_PRIORITY_ULTRA_HIGH;
dma_init(DMA_CH3,&dma_init_struct);
/* 使能循环模式 */
//dma_circulation_enable(DMA_CH3);
/* enable DMA channel3 */
void rgb_led_init(void)
rgb_led_gpio_init();
rgb_dma_init();
timer2_init();
void rgb_led_show(const uint8_t color[], uint16_t len)
uint8_t i = 0;
uint16_t memaddr = 0;
uint16_t buffersize = 0;
buffersize = (len * 24)+24; // number of bytes needed is #LEDs * 24 bytes + 42 trailing bytes
// memaddr = 0; // reset buffer memory index
while (len)
/* green data */
for(i = 0; i < 8; i++)
g_rgb_led_buf[memaddr] = ((color[0] << i) & 0x80) ? ONE : ZERO;
memaddr++;
/* red data */
g_rgb_led_buf[memaddr] = ((color[1] << i) & 0x80) ? ONE : ZERO;
memaddr++;
/* blue data */
g_rgb_led_buf[memaddr] = ((color[2] << i) & 0x80) ? ONE : ZERO;
memaddr++;
len--;
timer_counter_value_config(TIMER2, 0);
dma_transfer_number_config(DMA_CH3, buffersize);
timer_dma_enable(TIMER2, TIMER_DMA_CH0D);
dma_channel_enable(DMA_CH3);
timer_enable(TIMER2);
while(!dma_flag_get(DMA_CH3, DMA_FLAG_FTF));
timer_disable(TIMER2);
dma_channel_disable(DMA_CH3);
dma_flag_clear(DMA_CH3, DMA_FLAG_FTF);
