float mod_scalefactor = 0.80f * sqrt3_by_2 * 1.0f / std::sqrt(mod_d * mod_d + mod_q * mod_q);
这一行代码。实在不懂这个0.8是啥意思,有大牛指点下我不。。。糊涂了
整个函数如下:
- ODriveIntf::MotorIntf::Error FieldOrientedController::get_alpha_beta_output(
- uint32_t output_timestamp, std::optional<float2D>* mod_alpha_beta,
- std::optional<float>* ibus) {
- if (!vbus_voltage_measured_.has_value() || !Ialpha_beta_measured_.has_value()) {
- // FOC didn't receive a current measurement yet.
- return Motor::ERROR_CONTROLLER_INITIALIZING;
- } else if (abs((int32_t)(i_timestamp_ - ctrl_timestamp_)) > MAX_CONTROL_LOOP_UPDATE_TO_CURRENT_UPDATE_DELTA) {
- // Data from control loop and current measurement are too far apart.
- return Motor::ERROR_BAD_TIMING;
- // TODO: improve efficiency in case PWM updates are requested at a higher
- // rate than current sensor updates. In this case we can reuse mod_d and
- // mod_q from a previous iteration.
- if (!Vdq_setpoint_.has_value()) {
- return Motor::ERROR_UNKNOWN_VOLTAGE_COMMAND;
- } else if (!phase_.has_value() || !phase_vel_.has_value()) {
- return Motor::ERROR_UNKNOWN_PHASE_ESTIMATE;
- } else if (!vbus_voltage_measured_.has_value()) {
- return Motor::ERROR_UNKNOWN_VBUS_VOLTAGE;
- auto [Vd, Vq] = *Vdq_setpoint_;
- float phase = *phase_;
- float phase_vel = *phase_vel_;
- float vbus_voltage = *vbus_voltage_measured_;
- std::optional<float2D> Idq;
- // Park transform
- if (Ialpha_beta_measured_.has_value()) {
- auto [Ialpha, Ibeta] = *Ialpha_beta_measured_;
- float I_phase = phase + phase_vel * ((float)(int32_t)(i_timestamp_ - ctrl_timestamp_) / (float)TIM_1_8_CLOCK_HZ);
- float c_I = our_arm_cos_f32(I_phase);
- float s_I = our_arm_sin_f32(I_phase);
- Idq = {
- c_I * Ialpha + s_I * Ibeta,
- c_I * Ibeta - s_I * Ialpha
- Id_measured_ += I_measured_report_filter_k_ * (Idq->first - Id_measured_);
- Iq_measured_ += I_measured_report_filter_k_ * (Idq->second - Iq_measured_);
- } else {
- Id_measured_ = 0.0f;
- Iq_measured_ = 0.0f;
- float mod_to_V = (2.0f / 3.0f) * vbus_voltage;
- float V_to_mod = 1.0f / mod_to_V;
- float mod_d;
- float mod_q;
- if (enable_current_control_) {
- // Current control mode
- if (!pi_gains_.has_value()) {
- return Motor::ERROR_UNKNOWN_GAINS;
- } else if (!Idq.has_value()) {
- return Motor::ERROR_UNKNOWN_CURRENT_MEASUREMENT;
- } else if (!Idq_setpoint_.has_value()) {
- return Motor::ERROR_UNKNOWN_CURRENT_COMMAND;
- auto [p_gain, i_gain] = *pi_gains_;
- auto [Id, Iq] = *Idq;
- auto [Id_setpoint, Iq_setpoint] = *Idq_setpoint_;
- float Ierr_d = Id_setpoint - Id;
- float Ierr_q = Iq_setpoint - Iq;
- // Apply PI control (V{d,q}_setpoint act as feed-forward terms in this mode)
- mod_d = V_to_mod * (Vd + v_current_control_integral_d_ + Ierr_d * p_gain);
- mod_q = V_to_mod * (Vq + v_current_control_integral_q_ + Ierr_q * p_gain);
- // Vector modulation saturation, lock integrator if saturated
- // TODO make maximum modulation configurable
- float mod_scalefactor = 0.80f * sqrt3_by_2 * 1.0f / std::sqrt(mod_d * mod_d + mod_q * mod_q);
- if (mod_scalefactor < 1.0f) {
- mod_d *= mod_scalefactor;
- mod_q *= mod_scalefactor;
- // TODO make decayfactor configurable
- v_current_control_integral_d_ *= 0.99f;
- v_current_control_integral_q_ *= 0.99f;
- } else {
- v_current_control_integral_d_ += Ierr_d * (i_gain * current_meas_period);
- v_current_control_integral_q_ += Ierr_q * (i_gain * current_meas_period);
- } else {
- // Voltage control mode
- mod_d = V_to_mod * Vd;
- mod_q = V_to_mod * Vq;
- // Inverse park transform
- float pwm_phase = phase + phase_vel * ((float)(int32_t)(output_timestamp - ctrl_timestamp_) / (float)TIM_1_8_CLOCK_HZ);
- float c_p = our_arm_cos_f32(pwm_phase);
- float s_p = our_arm_sin_f32(pwm_phase);
- float mod_alpha = c_p * mod_d - s_p * mod_q;
- float mod_beta = c_p * mod_q + s_p * mod_d;
- // Report final applied voltage in stationary frame (for sensorless estimator)
- final_v_alpha_ = mod_to_V * mod_alpha;
- final_v_beta_ = mod_to_V * mod_beta;
- *mod_alpha_beta = {mod_alpha, mod_beta};
- if (Idq.has_value()) {
- *ibus = mod_d * Id + mod_q * Iq;
- power_ = vbus_voltage * (*ibus).value();
- return Motor::ERROR_NONE;
复制代码 |
