发表于 2024-8-3 11:42:43
网址中前面的方法也试过?比如下面两个:
Method 2: Hard Reset/Factory Reset Using Master Reset Code (One)
Step 1: Grab your Nokia 225 4G.
Step 2: Now, dial the code *2767*3855#.
Step 3: After dialing the above code, you will see the option “Restore Factory Settings”.
Step 4: Simply, choose the option in order to start the factory resetting process.
Step 5: When ask about the password, simply type in any code from the following.
0000, 1122, 4321, 12345
Method 3: Hard Reset/Factory Reset Using Master Reset Code (Two)
Step 2: Now, dial the code *#*#7780#*#*.
0000, 1122, 4321, 12345 |
