freemodbus-v1.2, 在网上搜到,现将它上传到这里,给各位搞modbus的朋友参考。
简介:
FreeRTOS Modbus Library: A Modbus serial implementation for FreeRTOS
Copyright (C) 2006 Christian Walter <wolti@sil.at>
The latest version of this document is available on http://freemodbus.berlios.de/api.
FreeModbus is a Modbus ASCII/RTU and Modbus TCP implementation for embedded systems. It provides an implementation of the Modbus Application Protocol v1.1a and supports the RTU/ASCII transmission modes defined in the Modbus over serial line specification 1.0. Since version 0.7 FreeModbus also supports Modbus/TCP. Version 0.9 added the first Modbus/TCP port for embedded systems using the lwIP TCP/IP stack.
支持的微处理器:
支持的 ARM devices:
- STR71X with FreeRTOS/GCC. See STR71X/simple2.c for an example.
- STR71TCP with FreeRTOS/lwIP/GCC. This port includes FreeRTOS, lwIP and a fully working PPP stack. The lwIP, PPP and FreeRTOS part is generic and therefore can be used for other ports ( or other projects ).
- LPC214X with Keil. See LPC214X/demo.c for an example. This port uses the Keil ARM Compiler 2.41.
支持的 AVR devices:
- ATMega8/16/32/128/168/169 with WinAVR. See AVR/demo.c for an example.
支持的 Coldfire devices:
- MCF5235 with GCC. See MCF5235/demo.c for an example.
- MCF5235 with CodeWarrior and FreeRTOS port for ColdFire. See MCF5235CW/demo.c for an example.
- MCF5235/TCP with GCC. This port features FreeRTOS and the lwIP stack. The lwIP part is generic and therefore it should be used as a basis for other lwIP ports.
支持的 MSP430 devices
- MSP430F169 with Rowley Crossworks. See MSP430/demo.c for an example.
- MSP430F169 with GCC. See MSP430/demo.c for an example.
支持的 Z8Encore devices
- Z8F6422 and Z8F1622 port. See Z8ENCORE/demo.c for an example. The port uses ZDS II - Z8 Encore! 4.10.1 as development environment.
支持的 Win32:
- A Win32 Modbus RTU/ASCII Port.
- A Win32 Modbus/TCP Port.
支持的 Linux:
- A Linux (uCLinux or other distributions) Modbus RTU/ASCII Port.
源代码:
点击此处下载armok01164419.rar
编译通过的AVR(M128)的例子:(WINAVR 20060421+AVRStudio4)
点击此处下载armok01164420.rar |
