发表于 2011-1-20 08:55:29
呵呵 不好意思会您晚了点哈 我下载的是Quartus II v10.1 Web Edtion和modelsim-Altera starter Edtion 6.6c for Quartus II v10.1,有liscence的,她们俩都能单独打开的。下面是我操作步骤你看看哪儿错了:1,写好Verilog 代码,然后Starte Conpilation 2,编写Test Bench ,3,编好后进行设置Assignments-setting-simulation,设置Tool name,format for output netlist,timescal,compli test bench,点击Test Bengch 4,在弹出的Test Bengch 窗口添加文件,再点击New 5,在弹出的New Test Bench窗口填写各种名字这填写的可以保证都对。6,然后再compliation.7,进行调用modelsim-altera 进行RTL级仿真Tools-Run EDA Simulation Tool-EDA RTL Simulation时,就弹出下面的窗口窗口描述Can't launch the ModelSim-Altera software -- the path to the location of the executables for the ModelSim-Altera software were not specified or the executables were not found at specified path.下面是路径。你看看我是不是那设置错了,,万分感谢。。。 |
