温度值是:0x333 =819是啥意思啊
气压只是:0xBBC4 =48068
求大神指点啊
怎么搞得对不上呀
源代码
// F31x_SMBus_EEPROM.c
// Copyright 2006 Silicon Laboratories, Inc.
// http://www.silabs.com
// Program Description:
// This example demonstrates how the C8051F31x SMBus interface can communicate
// with a 256 byte I2C Serial EEPROM (Microchip 24LC02B).
// - Interrupt-driven SMBus implementation
// - Only master states defined (no slave or arbitration)
// - Timer1 used as SMBus clock source
// - Timer3 used by SMBus for SCL low timeout detection
// - SCL frequency defined by <SMB_FREQUENCY> constant
// - Pinout:
// P0.0 -> SDA (SMBus)
// P0.1 -> SCL (SMBus)
// P3.0 -> C2D (debugging interface)
// P3.3 -> LED (on the 'F310 TB)
// all other port pins unused
// How To Test:
// 1) Download code to a 'F31x device that is connected to a 24LC02B serial
// EEPROM (see the EEPROM datasheet for the pinout information).
// 2) Run the code:
// a) the test will indicate proper communication with the EEPROM by
// turning on the LED at the end the end of the test
// b) the test can also be verified by running to the if statements
// in main and checking the sent and received values by adding
// the variables to the Watch Window
// FID: 31X000008
// Target: C8051F31x
// Tool chain: Keil C51 7.50 / Keil EVAL C51
// Command Line: None
// Release 1.0
// -Initial Revision (TP)
// -02 MAR 2006
// Includes
#include <C8051F310.h>
// Global CONSTANTS
#define SYSCLK 24500000 // System clock frequency in Hz
#define SMB_FREQUENCY 50000 // Target SCL clock rate
// This example supports between 10kHz
// and 100kHz
#define WRITE 0x00 // SMBus WRITE command
#define READ 0x01 // SMBus READ command
// Device addresses (7 bits, lsb is a don't care)
#define BMP180_ADDR 0xEE // Device address for slave target
// Note: This address is specified
// in the Microchip 24LC02B
// datasheet.
// SMBus Buffer Size
#define SMB_BUFF_SIZE 0x08 // Defines the maximum number of bytes
// that can be sent or received in a
// single transfer
// Status vector - top 4 bits only
#define SMB_MTSTA 0xE0 // (MT) start transmitted
#define SMB_MTDB 0xC0 // (MT) data byte transmitted
#define SMB_MRDB 0x80 // (MR) data byte received
// End status vector definition
const unsigned char OSS = 0; // Oversampling Setting
// Calibration values
int idata ac1;
int idata ac2;
int idata ac3;
unsigned int idata ac4;
unsigned int idata ac5;
unsigned int idata ac6;
int idata b1;
int idata b2;
int idata mb;
int idata mc;
int idata md;
long idata bmp180_presure; //bmp180
unsigned int idata bmp180_temp;
// Global VARIABLES
unsigned char* pSMB_DATA_IN; // Global pointer for SMBus data
// All receive data is written here
unsigned char SMB_SINGLEBYTE_OUT; // Global holder for single byte writes.
unsigned char* pSMB_DATA_OUT; // Global pointer for SMBus data.
// All transmit data is read from here
unsigned char SMB_DATA_LEN; // Global holder for number of bytes
// to send or receive in the current
// SMBus transfer.
unsigned char WORD_ADDR; // Global holder for the EEPROM word
// address that will be accessed in
// the next transfer
unsigned char TARGET; // Target SMBus slave address
bit SMB_BUSY = 0; // Software flag to indicate when the
// EEPROM_ByteRead() or
// EEPROM_ByteWrite()
// functions have claimed the SMBus
bit SMB_RW; // Software flag to indicate the
// direction of the current transfer
bit SMB_SENDWORDADDR; // When set, this flag causes the ISR
// to send the 8-bit <WORD_ADDR>
// after sending the slave address.
bit SMB_RANDOMREAD; // When set, this flag causes the ISR
// to send a START signal after sending
// the word address.
// For the 24LC02B EEPROM, a random read
// (a read from a particular address in
// memory) starts as a write then
// changes to a read after the repeated
// start is sent. The ISR handles this
// switchover if the <SMB_RANDOMREAD>
// bit is set.
bit SMB_ACKPOLL; // When set, this flag causes the ISR
// to send a repeated START until the
// slave has acknowledged its address
sfr16 TMR3RL = 0x92; // Timer3 reload registers
sfr16 TMR3 = 0x94; // Timer3 counter registers
sbit LED = P3^3; // LED on port P3.3
sbit SDA = P0^0; // SMBus on P0.0
sbit SCL = P0^1; // and P0.1
// Function PROTOTYPES
void SMBus_Init(void);
void Timer1_Init(void);
void Timer3_Init(void);
void Port_Init(void);
void SMBus_ISR(void);
void Timer3_ISR(void);
void BMP180_ByteWrite(unsigned char addr, unsigned char dat);
void BMP180_WriteArray(unsigned char dest_addr, unsigned char* src_addr,
unsigned char len);
unsigned char BMP180_ByteRead(unsigned char addr);
void BMP180_ReadArray(unsigned char* dest_addr, unsigned char src_addr,
unsigned char len);
void temp_calibration(void);
void Delay(unsigned int nCount);
void test_pressure_main(void);
// MAIN Routine
// Main routine performs all configuration tasks, then loops forever sending
// and receiving SMBus data to the slave EEPROM.
void main (void)
// char in_buff[8] = {0}; // Incoming data buffer
// char out_buff[8] = "ABCDEFG"; // Outgoing data buffer
// bit error_flag = 0; // Flag for checking EEPROM contents
unsigned char i; // Temporary counter variable
PCA0MD &= ~0x40; // WDTE = 0 (disable watchdog timer)
// Set internal oscillator to highest
// setting of 24500000
OSCICN |= 0x03;
// If slave is holding SDA low because of an improper SMBus reset or error
while(!SDA)
// Provide clock pulses to allow the slave to advance out
// of its current state. This will allow it to release SDA.
XBR1 = 0x40; // Enable Crossbar
SCL = 0; // Drive the clock low
for(i = 0; i < 255; i++); // Hold the clock low
SCL = 1; // Release the clock
while(!SCL); // Wait for open-drain
// clock output to rise
for(i = 0; i < 10; i++); // Hold the clock high
XBR1 = 0x00; // Disable Crossbar
Port_Init (); // Initialize Crossbar and GPIO
LED = 0; // Turn off the LED before the test
// starts
Timer1_Init (); // Configure Timer1 for use as SMBus
// clock source
Timer3_Init (); // Configure Timer3 for use with SMBus
// low timeout detect
SMBus_Init (); // Configure and enable SMBus
EIE1 |= 0x01; // Enable the SMBus interrupt
EA = 1; // Global interrupt enable
// Read and write some bytes to the EEPROM and check for proper
// communication
// Write the value 0xAA to location 0x25 in the EEPROM
// EEPROM_ByteWrite(0x25, 0xAA);
// Read the value at location 0x25 in the EEPROM
// temp_char = EEPROM_ByteRead(0x25);
// Check that the data was read properly
// if (temp_char != 0xAA)
// error_flag = 1;
// Write the value 0xBB to location 0x25 in the EEPROM
// EEPROM_ByteWrite(0x25, 0xBB);
// Write the value 0xCC to location 0x38 in the EEPROM
// EEPROM_ByteWrite(0x38, 0xCC);
// if (temp_char != 0xBB)
// error_flag = 1;
// Read the value at location 0x38 in the EEPROM
// temp_char = EEPROM_ByteRead(0x38);
// if (temp_char != 0xCC)
// error_flag = 1;
// Store the outgoing data buffer at EEPROM address 0x50
// EEPROM_WriteArray(0x50, out_buff, sizeof(out_buff));
// Fill the incoming data buffer with data starting at EEPROM address 0x50
// EEPROM_ReadArray(in_buff, 0x50, sizeof(in_buff));
// Check that the data that came from the EEPROM is the same as what was
// sent
// for (i = 0; i < sizeof(in_buff); i++)
// if (in_buff != out_buff)
// error_flag = 1;
// Indicate communication is good
// if (error_flag == 0)
// // LED = ON indicates that the test passed
// LED = 1;
test_pressure_main();
// Initialization Routines
// SMBus_Init()
// Return Value : None
// Parameters : None
// The SMBus peripheral is configured as follows:
// - SMBus enabled
// - Slave mode disabled
// - Timer1 used as clock source. The maximum SCL frequency will be
// approximately 1/3 the Timer1 overflow rate
// - Setup and hold time extensions enabled
// - Free and SCL low timeout detection enabled
void SMBus_Init (void)
SMB0CF = 0x5D; // Use Timer1 overflows as SMBus clock
// source;
// Disable slave mode;
// Enable setup & hold time extensions;
// Enable SMBus Free timeout detect;
// Enable SCL low timeout detect;
SMB0CF |= 0x80; // Enable SMBus;
// Timer1_Init()
// Timer1 is configured as the SMBus clock source as follows:
// - Timer1 in 8-bit auto-reload mode
// - SYSCLK / 12 as Timer1 clock source
// - Timer1 overflow rate => 3 * SMB_FREQUENCY
// - The maximum SCL clock rate will be ~1/3 the Timer1 overflow rate
// - Timer1 enabled
void Timer1_Init (void)
// Make sure the Timer can produce the appropriate frequency in 8-bit mode
// Supported SMBus Frequencies range from 10kHz to 100kHz. The CKCON register
// settings may need to change for frequencies outside this range.
#if ((SYSCLK/SMB_FREQUENCY/3) < 255)
#define SCALE 1
CKCON |= 0x08; // Timer1 clock source = SYSCLK
#elif ((SYSCLK/SMB_FREQUENCY/4/3) < 255)
#define SCALE 4
CKCON |= 0x01;
CKCON &= ~0x0A; // Timer1 clock source = SYSCLK / 4
TMOD = 0x20; // Timer1 in 8-bit auto-reload mode
TH1 = -(SYSCLK/SMB_FREQUENCY/12/3); // Timer1 configured to overflow at 1/3
// the rate defined by SMB_FREQUENCY
TL1 = TH1; // Init Timer1
TR1 = 1; // Timer1 enabled
// Timer3_Init()
// Timer3 configured for use by the SMBus low timeout detect feature as
// follows:
// - Timer3 in 16-bit auto-reload mode
// - SYSCLK/12 as Timer3 clock source
// - Timer3 reload registers loaded for a 25ms overflow period
// - Timer3 pre-loaded to overflow after 25ms
// - Timer3 enabled
void Timer3_Init (void)
TMR3CN = 0x00; // Timer3 configured for 16-bit auto-
// reload, low-byte interrupt disabled
CKCON &= ~0x40; // Timer3 uses SYSCLK/12
TMR3RL = -(SYSCLK/12/40); // Timer3 configured to overflow after
TMR3 = TMR3RL; // ~25ms (for SMBus low timeout detect)
EIE1 |= 0x80; // Timer3 interrupt enable
TMR3CN |= 0x04; // Start Timer3
// PORT_Init
// Configure the Crossbar and GPIO ports.
// P0.0 digital open-drain SMBus SDA
// P0.1 digital open-drain SMBus SCL
// P3.3 digital push-pull LED
// Note: If the SMBus is moved, the SCL and SDA sbit declarations must also
// be adjusted.
void PORT_Init (void)
P0MDOUT = 0x00; // All P0 pins open-drain output
P3MDOUT |= 0x08; // Make the LED (P3.3) a push-pull
// output
XBR0 = 0x04; // Enable SMBus pins
XBR1 = 0x40; // Enable crossbar and weak pull-ups
P0 = 0xFF;
// SMBus Interrupt Service Routine (ISR)
// SMBus ISR state machine
// - Master only implementation - no slave or arbitration states defined
// - All incoming data is written starting at the global pointer <pSMB_DATA_IN>
// - All outgoing data is read from the global pointer <pSMB_DATA_OUT>
void SMBus_ISR (void) interrupt 7
bit FAIL = 0; // Used by the ISR to flag failed
// transfers
static char i; // Used by the ISR to count the
// number of data bytes sent or
// received
static bit SEND_START = 0; // Send a start
switch (SMB0CN & 0xF0) // Status vector
// Master Transmitter/Receiver: START condition transmitted.
case SMB_MTSTA:
SMB0DAT = TARGET; // Load address of the target slave
SMB0DAT &= 0xFE; // Clear the LSB of the address for the
// R/W bit
SMB0DAT |= SMB_RW; // Load R/W bit
STA = 0; // Manually clear START bit
i = 0; // Reset data byte counter
// Master Transmitter: Data byte (or Slave Address) transmitted
case SMB_MTDB:
if (ACK) // Slave Address or Data Byte
{ // Acknowledged?
if (SEND_START)
STA = 1;
SEND_START = 0;
if(SMB_SENDWORDADDR) // Are we sending the word address?
SMB_SENDWORDADDR = 0; // Clear flag
SMB0DAT = WORD_ADDR; // Send word address
if (SMB_RANDOMREAD)
SEND_START = 1; // Send a START after the next ACK cycle
SMB_RW = READ;
if (SMB_RW==WRITE) // Is this transfer a WRITE?
if (i < SMB_DATA_LEN) // Is there data to send?
// send data byte
SMB0DAT = *pSMB_DATA_OUT;
// increment data out pointer
pSMB_DATA_OUT++;
// increment number of bytes sent
i++;
STO = 1; // Set STO to terminte transfer
SMB_BUSY = 0; // Clear software busy flag
else {} // If this transfer is a READ,
// then take no action. Slave
// address was transmitted. A
// separate 'case' is defined
// for data byte recieved.
else // If slave NACK,
if(SMB_ACKPOLL)
STA = 1; // Restart transfer
FAIL = 1; // Indicate failed transfer
} // and handle at end of ISR
// Master Receiver: byte received
case SMB_MRDB:
if ( i < SMB_DATA_LEN ) // Is there any data remaining?
*pSMB_DATA_IN = SMB0DAT; // Store received byte
pSMB_DATA_IN++; // Increment data in pointer
i++; // Increment number of bytes received
ACK = 1; // Set ACK bit (may be cleared later
// in the code)
if (i == SMB_DATA_LEN) // This is the last byte
SMB_BUSY = 0; // Free SMBus interface
ACK = 0; // Send NACK to indicate last byte
// of this transfer
STO = 1; // Send STOP to terminate transfer
default:
if (FAIL) // If the transfer failed,
SMB0CF &= ~0x80; // Reset communication
SMB0CF |= 0x80;
STA = 0;
STO = 0;
ACK = 0;
FAIL = 0;
SI = 0; // Clear interrupt flag
// Timer3 Interrupt Service Routine (ISR)
// A Timer3 interrupt indicates an SMBus SCL low timeout.
// The SMBus is disabled and re-enabled if a timeout occurs.
void Timer3_ISR (void) interrupt 14
SMB0CF &= ~0x80; // Disable SMBus
SMB0CF |= 0x80; // Re-enable SMBus
TMR3CN &= ~0x80; // Clear Timer3 interrupt-pending flag
SMB_BUSY = 0; // Free bus
// Support Functions
// EEPROM_ByteWrite ()
// Parameters :
// 1) unsigned char addr - address to write in the EEPROM
// range is full range of character: 0 to 255
// 2) unsigned char dat - data to write to the address <addr> in the EEPROM
// This function writes the value in <dat> to location <addr> in the EEPROM
// then polls the EEPROM until the write is complete.
while (SMB_BUSY); // Wait for SMBus to be free.
SMB_BUSY = 1; // Claim SMBus (set to busy)
// Set SMBus ISR parameters
TARGET = BMP180_ADDR; // Set target slave address
SMB_RW = WRITE; // Mark next transfer as a write
SMB_SENDWORDADDR = 1; // Send Word Address after Slave Address
SMB_RANDOMREAD = 0; // Do not send a START signal after
// the word address
SMB_ACKPOLL = 1; // Enable Acknowledge Polling (The ISR
// will automatically restart the
// transfer if the slave does not
// acknoledge its address.
// Specify the Outgoing Data
WORD_ADDR = addr; // Set the target address in the
// EEPROM's internal memory space
SMB_SINGLEBYTE_OUT = dat; // Store <dat> (local variable) in a
// global variable so the ISR can read
// it after this function exits
// The outgoing data pointer points to the <dat> variable
pSMB_DATA_OUT = &SMB_SINGLEBYTE_OUT;
SMB_DATA_LEN = 1; // Specify to ISR that the next transfer
// will contain one data byte
// Initiate SMBus Transfer
STA = 1;
// EEPROM_WriteArray ()
// Parameters :
// 1) unsigned char dest_addr - beginning address to write to in the EEPROM
// 2) unsigned char* src_addr - pointer to the array of data to be written
// 3) unsigned char len - length of the array to be written to the EEPROM
// Writes <len> data bytes to the EEPROM slave specified by the <EEPROM_ADDR>
// constant.
unsigned char len)
unsigned char i;
unsigned char* pData = (unsigned char*) src_addr;
for( i = 0; i < len; i++ ){
BMP180_ByteWrite(dest_addr++, *pData++);
// EEPROM_ByteRead ()
// Return Value :
// 1) unsigned char data - data read from address <addr> in the EEPROM
// Parameters :
// 1) unsigned char addr - address to read data from the EEPROM
// This function returns a single byte from location <addr> in the EEPROM then
// polls the <SMB_BUSY> flag until the read is complete.
unsigned char retval; // Holds the return value
SMB_RW = WRITE; // A random read starts as a write
// then changes to a read after
// the repeated start is sent. The
// ISR handles this switchover if
// the <SMB_RANDOMREAD> bit is set.
SMB_RANDOMREAD = 1; // Send a START after the word address
// Specify the Incoming Data
pSMB_DATA_IN = &retval; // The incoming data pointer points to
// the <retval> variable.
STA = 1;
while(SMB_BUSY); // Wait until data is read
return retval;
// EEPROM_ReadArray ()
// Parameters :
// 1) unsigned char* dest_addr - pointer to the array that will be filled
// with the data from the EEPROM
// 2) unsigned char src_addr - beginning address to read data from the EEPROM
// 3) unsigned char len - length of the array to be read from the EEPROM
// Reads up to 256 data bytes from the EEPROM slave specified by the
// <EEPROM_ADDR> constant.
void BMP180_ReadArray (unsigned char* dest_addr, unsigned char src_addr, unsigned char len)
WORD_ADDR = src_addr; // Set the target address in the
// Set the the incoming data pointer
pSMB_DATA_IN = (unsigned char*) dest_addr;
SMB_DATA_LEN = len; // Specify to ISR that the next transfer
// will contain <len> data bytes
STA = 1;
long x1,x2,x3,b3,b5,b6,b7,press_reg,pressure,temp_reg,temp;
//long x1,x2,x3,b3,b5,b6,b7,press_reg,pressure,temp_reg;
unsigned long b4;
//int ret,i;
unsigned char ReadBuffer[10];
//unsigned short ;
//unsigned int ;
char oss = 0; //这个值在读气压时可以置进寄存器
//GPIO_Configuration();
////USART_Configuration();
// I2C_Configuration();
////printf("\r\n****************************************************************\r\n");
//while (1)
////printf("\r\n Read start \r\n");
temp_calibration();
//read uncompensated temperature
// I2C_WriteOneByte(Open_I2C,ADDR_24LC02,0xf4,0x2e);
BMP180_ByteWrite(0xf4, 0x2e);
Delay(5000);//delay 4.5ms
//ret = I2C_Read(Open_I2C,ADDR_24LC02,0xf6,ReadBuffer,2);
// I2C_Read(Open_I2C,ADDR_24LC02,0xf6,ReadBuffer,2);
BMP180_ReadArray (ReadBuffer, 0xf6, 2);
temp_reg = ReadBuffer[0] << 8 | ReadBuffer[1];
////printf("temp_reg %d \r\n",temp_reg);
//calculate true temperature
x1 = ((temp_reg - ac6) * ac5) >> 15;
x2 = ((long) mc << 11) / (x1 + md);
b5 = x1 + x2;
temp = (b5 + 8) >> 4;
bmp180_temp=temp;
////printf("x1:%d, x2:%d, b5:%d, temp(*0.1):%d \r\n",x1,x2,b5,temp);
//read uncompensated pressure
//////write 0x34+(oss<<6) into reg 0xF4, wait 4.5ms
// I2C_WriteOneByte(Open_I2C,ADDR_24LC02,0xf4,(0x34 +(oss<<6)));
BMP180_ByteWrite(0xf4, (0x34 +(oss<<6)));
//I2C_WriteOneByte(Open_I2C,ADDR_24LC02,0xf4,(0x3e + oss<<6));
//I2C_WriteOneByte(Open_I2C,ADDR_24LC02,0xf4,0x3e);
Delay(4500);//delay 4.5ms
//read reg 0xF6 (MSB), 0xF7 (LSB), 0xF8 (XLSB)
// I2C_Read(Open_I2C,ADDR_24LC02,0xf6,ReadBuffer,3);
BMP180_ReadArray (ReadBuffer, 0xf6, 3);
//I2C_Read(Open_I2C,ADDR_24LC02,0xf6,ReadBuffer,2);
//////UP = (MSB<<16 + LSB<<8 + XLSB) >> (8-oss)
press_reg = ((ReadBuffer[0] << 16)+(ReadBuffer[1] << 8)+ReadBuffer[2]) >> (8 - oss);
//press_reg = ((ReadBuffer[0] << 16) | (ReadBuffer[1] << 8) | ReadBuffer[2]) >> (8 - oss);
//press_reg = ReadBuffer[0] << 8 | ReadBuffer[1];
//press_reg &= 0x00FFFF;
////printf("press_reg %d \r\n",press_reg);
b6 = b5 - 4000;
//X1 = (B2 * (B6 * B6 / 2^12)) / 2^11
x1 = (b2 * ((b6 * b6) >> 12)) >> 11;
//X2 = AC2 * B6 / 2^11
x2 = (ac2 * b6) >> 11;
x3 = x1 + x2;
//B3 = ((AC1*4+X3) << oss + 2) / 4
b3 = ((((long)ac1 * 4 + x3) << oss) + 2) / 4;
//b3 = (((long)ac1 * 4 + x3) + 2) / 4;
//X1 = AC3 * B6 / 2^13
x1 = (ac3 * b6) >> 13;
//X2 = (B1 * (B6 * B6 / 2^12 )) / 2^16
x2 = (b1 * ((b6 * b6)>> 12)) >> 16;
//X3 = ((X1 + X2) + 2) / 2^2
x3 = ((x1 + x2 )+ 2) >> 2;
//B4 = AC4 * (unsigend long)(X3 + 32768) / 2^15
b4 = (ac4 * (unsigned long)(x3 + 32768)) >> 15;
//B7 = ((unsigned long)UP - B3) * (50000 >> oss)
b7 = ((unsigned long)press_reg - b3) * (50000 >> oss);
//b7 = ((unsigned long)press_reg - b3) * (50000);
// if(b7 < 0x80000000)
// pressure = (b7 * 2) / b4;
// else
// pressure = (b7 / b4) * 2;
//X1 = (p / 2^8 ) * (p / 2^8 )
x1 = (pressure >> 8) * (pressure >> 8);
//X1 = (X1 * 3038) / 2^16
x1 = (x1 * 3038) >> 16;
//X2 = (-7357 * p) / 2^16
x2 = (-7357 * pressure) >> 16;
//p = p + (X1 + X2 + 3791) / 2^4
pressure = pressure + ((x1 + x2 + 3791) >> 4);
bmp180_presure = pressure;
// bmp180_presure /= 10;
//for(i=0; i<200*3; i++)
//I2C_delay(2000);
unsigned char buf[2];
// I2C_Read(Open_I2C,ADDR_24LC02,0xaa,buf, 2);
BMP180_ReadArray (buf, 0xaa, 2);
ac1 = buf[0] << 8 |buf[1];
// I2C_Read(Open_I2C,ADDR_24LC02,0xac,buf, 2);
BMP180_ReadArray (buf, 0xac, 2);
ac2 = buf[0] << 8 |buf[1];
// I2C_Read(Open_I2C,ADDR_24LC02,0xae,buf, 2);
BMP180_ReadArray (buf, 0xae, 2);
ac3 = buf[0] << 8 |buf[1];
// I2C_Read(Open_I2C,ADDR_24LC02,0xb0,buf, 2);
BMP180_ReadArray (buf, 0xb0, 2);
ac4 = buf[0] << 8 |buf[1];
// I2C_Read(Open_I2C,ADDR_24LC02,0xb2,buf, 2);
BMP180_ReadArray (buf, 0xb2, 2);
ac5 = buf[0] << 8 |buf[1];
// I2C_Read(Open_I2C,ADDR_24LC02,0xb4,buf, 2);
BMP180_ReadArray (buf, 0xb4, 2);
ac6 = buf[0] << 8 |buf[1];
// I2C_Read(Open_I2C,ADDR_24LC02,0xb6,buf, 2);
BMP180_ReadArray (buf, 0xb6, 2);
b1 = buf[0] << 8 |buf[1];
// I2C_Read(Open_I2C,ADDR_24LC02,0xb8,buf, 2);
BMP180_ReadArray (buf, 0xb8, 2);
b2 = buf[0] << 8 |buf[1];
// I2C_Read(Open_I2C,ADDR_24LC02,0xba,buf, 2);
BMP180_ReadArray (buf, 0xba, 2);
mb = buf[0] << 8 |buf[1];
// I2C_Read(Open_I2C,ADDR_24LC02,0xbc,buf, 2);
BMP180_ReadArray (buf, 0xbc, 2);
mc = buf[0] << 8 |buf[1];
// I2C_Read(Open_I2C,ADDR_24LC02,0xbe,buf, 2);
BMP180_ReadArray (buf, 0xbe, 2);
md = buf[0] << 8 |buf[1];
////printf("ac1=%d,ac2=%d,ac3=%d,ac4=%d,ac5=%d,ac6=%d,b1=%d,b2=%d,mb=%d,mc=%d,md=%d\r\n",ac1,ac2,ac3,ac4,ac5,ac6,b1,b2,mb,mc,md);
* Function Name : Delay
* Description : Delay Time
* Input : - nCount: Delay Time
* Output : None
* Return : None
* Attention : None
/* http://www.rdbuy.cn */
unsigned char i;
for(i=25;i>0;i--)
for(; nCount != 0; nCount--);
// End Of File
