回复: 4
LPC1754串口2和3无法通信。
出45入88汤圆
发表于 2019-9-17 22:32:56 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
demo里只有uart0,1,试过是可以正常收发。但修改成2,3都无法收发。什么原因?官方解疑在哪里?
原版:
*   uart.c:  UART API file for NXP LPC17xx Family Microprocessors
*   Copyright(C) 2009, NXP Semiconductor
*   All rights reserved.
*   History
*   2009.05.27  ver 1.00    Prelimnary version, first Release
#include "lpc17xx.h"
#include "type.h"
#include "uart.h"
volatile uint32_t UART0Status, UART1Status;
volatile uint8_t UART0TxEmpty = 1, UART1TxEmpty = 1;
volatile uint8_t UART0Buffer[BUFSIZE], UART1Buffer[BUFSIZE];
volatile uint32_t UART0Count = 0, UART1Count = 0;
** Function name:                UART0_IRQHandler
** Descriptions:                UART0 interrupt handler
** parameters:                        None
** Returned value:                None
void UART0_IRQHandler (void)
  uint8_t IIRValue, LSRValue;
  uint8_t Dummy = Dummy;
  IIRValue = LPC_UART0->IIR;
  IIRValue >>= 1;                        /* skip pending bit in IIR */
  IIRValue &= 0x07;                        /* check bit 1~3, interrupt identification */
  if ( IIRValue == IIR_RLS )                /* Receive Line Status */
        LSRValue = LPC_UART0->LSR;
        if ( LSRValue & (LSR_OE|LSR_PE|LSR_FE|LSR_RXFE|LSR_BI) )
          /* There are errors or break interrupt */
          /* Read LSR will clear the interrupt */
          UART0Status = LSRValue;
          Dummy = LPC_UART0->RBR;                /* Dummy read on RX to clear
                                                        interrupt, then bail out */
          return;
        if ( LSRValue & LSR_RDR )        /* Receive Data Ready */
          /* If no error on RLS, normal ready, save into the data buffer. */
          /* Note: read RBR will clear the interrupt */
          UART0Buffer[UART0Count] = LPC_UART0->RBR;
          UART0Count++;
          if ( UART0Count == BUFSIZE )
                UART0Count = 0;                /* buffer overflow */
  else if ( IIRValue == IIR_RDA )        /* Receive Data Available */
        UART0Count++;
  else if ( IIRValue == IIR_CTI )        /* Character timeout indicator */
        /* Character Time-out indicator */
        UART0Status |= 0x100;                /* Bit 9 as the CTI error */
  else if ( IIRValue == IIR_THRE )        /* THRE, transmit holding register empty */
        /* THRE interrupt */
        LSRValue = LPC_UART0->LSR;                /* Check status in the LSR to see if
        valid data in U0THR or not */
        if ( LSRValue & LSR_THRE )
          UART0TxEmpty = 1;
          UART0TxEmpty = 0;
** Function name:                UART1_IRQHandler
** Descriptions:                UART1 interrupt handler
** parameters:                        None
void UART1_IRQHandler (void)
  IIRValue = LPC_UART1->IIR;
        LSRValue = LPC_UART1->LSR;
          UART1Status = LSRValue;
          Dummy = LPC_UART1->RBR;                /* Dummy read on RX to clear
          return;
          UART1Buffer[UART1Count] = LPC_UART1->RBR;
          UART1Count++;
          if ( UART1Count == BUFSIZE )
                UART1Count = 0;                /* buffer overflow */
        UART1Count++;
        UART1Status |= 0x100;                /* Bit 9 as the CTI error */
        LSRValue = LPC_UART1->LSR;                /* Check status in the LSR to see if
          UART1TxEmpty = 1;
          UART1TxEmpty = 0;
** Function name:                UARTInit
** Descriptions:                Initialize UART port, setup pin select,
**                                                clock, parity, stop bits, FIFO, etc.
** parameters:                        portNum(0 or 1) and UART baudrate
** Returned value:                true or false, return false only if the
**                                                interrupt handler can't be installed to the
**                                                VIC table
uint32_t UARTInit( uint32_t PortNum, uint32_t baudrate )
  uint32_t Fdiv;
  uint32_t pclkdiv, pclk;
  if ( PortNum == 0 )
        LPC_PINCON->PINSEL0 &= ~0x000000F0;
        LPC_PINCON->PINSEL0 |= 0x00000050;  /* RxD0 is P0.3 and TxD0 is P0.2 */
        /* By default, the PCLKSELx value is zero, thus, the PCLK for
        all the peripherals is 1/4 of the SystemFrequency. */
        /* Bit 6~7 is for UART0 */
        pclkdiv = (LPC_SC->PCLKSEL0 >> 6) & 0x03;
        switch ( pclkdiv )
          case 0x00:
          default:
                pclk = SystemFrequency/4;
                break;
          case 0x01:
                pclk = SystemFrequency;
                break;
          case 0x02:
                pclk = SystemFrequency/2;
                break;
          case 0x03:
                pclk = SystemFrequency/8;
                break;
    LPC_UART0->LCR = 0x83;                /* 8 bits, no Parity, 1 Stop bit */
        Fdiv = ( pclk / 16 ) / baudrate ;        /*baud rate */
    LPC_UART0->DLM = Fdiv / 256;
    LPC_UART0->DLL = Fdiv % 256;
        LPC_UART0->LCR = 0x03;                /* DLAB = 0 */
    LPC_UART0->FCR = 0x07;                /* Enable and reset TX and RX FIFO. */
           NVIC_EnableIRQ(UART0_IRQn);
    LPC_UART0->IER = IER_RBR | IER_THRE | IER_RLS;        /* Enable UART0 interrupt */
    return (TRUE);
  else if ( PortNum == 1 )
        LPC_PINCON->PINSEL4 &= ~0x0000000F;
        LPC_PINCON->PINSEL4 |= 0x0000000A;        /* Enable RxD1 P2.1, TxD1 P2.0 */
        /* Bit 8,9 are for UART1 */
        pclkdiv = (LPC_SC->PCLKSEL0 >> 8) & 0x03;
        switch ( pclkdiv )
          case 0x00:
          default:
                break;
          case 0x01:
                break;
          case 0x02:
                break;
          case 0x03:
                break;
    LPC_UART1->LCR = 0x83;                /* 8 bits, no Parity, 1 Stop bit */
    LPC_UART1->DLM = Fdiv / 256;
    LPC_UART1->DLL = Fdiv % 256;
        LPC_UART1->LCR = 0x03;                /* DLAB = 0 */
    LPC_UART1->FCR = 0x07;                /* Enable and reset TX and RX FIFO. */
           NVIC_EnableIRQ(UART1_IRQn);
    LPC_UART1->IER = IER_RBR | IER_THRE | IER_RLS;        /* Enable UART1 interrupt */
    return (TRUE);
  return( FALSE );
** Function name:                UARTSend
** Descriptions:                Send a block of data to the UART 0 port based
**                                                on the data length
** parameters:                        portNum, buffer pointer, and data length
void UARTSend( uint32_t portNum, uint8_t *BufferPtr, uint32_t Length )
  if ( portNum == 0 )
    while ( Length != 0 )
          /* THRE status, contain valid data */
          while ( !(UART0TxEmpty & 0x01) );
          LPC_UART0->THR = *BufferPtr;
          UART0TxEmpty = 0;        /* not empty in the THR until it shifts out */
          BufferPtr++;
          Length--;
          while ( !(UART1TxEmpty & 0x01) );
          LPC_UART1->THR = *BufferPtr;
          UART1TxEmpty = 0;        /* not empty in the THR until it shifts out */
          BufferPtr++;
          Length--;
  return;
**                            End Of File
下面是我修改的:
*   History
#include "type.h"
#include "uart.h"
volatile uint32_t UART0Status, UART1Status,UART2Status, UART3Status;
volatile uint8_t UART0TxEmpty = 1, UART1TxEmpty = 1,UART2TxEmpty = 1, UART3TxEmpty = 1;
volatile uint8_t UART0Buffer[BUFSIZE], UART1Buffer[BUFSIZE],UART2Buffer[BUFSIZE], UART3Buffer[BUFSIZE];;
volatile uint32_t UART0Count = 0, UART1Count = 0,UART2Count = 0, UART3Count = 0;;
** parameters:                        None
          return;
          UART0Count++;
        UART0Count++;
          UART0TxEmpty = 1;
          UART0TxEmpty = 0;
** parameters:                        None
          return;
          UART1Count++;
        UART1Count++;
          UART1TxEmpty = 1;
          UART1TxEmpty = 0;
void UART2_IRQHandler (void)
  IIRValue = LPC_UART2->IIR;
        LSRValue = LPC_UART2->LSR;
          UART2Status = LSRValue;
          Dummy = LPC_UART2->RBR;                /* Dummy read on RX to clear
          return;
          UART2Buffer[UART2Count] = LPC_UART2->RBR;
          UART2Count++;
          if ( UART2Count == BUFSIZE )
                UART2Count = 0;                /* buffer overflow */
        UART2Count++;
        UART2Status |= 0x100;                /* Bit 9 as the CTI error */
        LSRValue = LPC_UART2->LSR;                /* Check status in the LSR to see if
          UART2TxEmpty = 1;
          UART2TxEmpty = 0;
void UART3_IRQHandler (void)
  IIRValue = LPC_UART3->IIR;
        LSRValue = LPC_UART3->LSR;
          UART3Status = LSRValue;
          Dummy = LPC_UART3->RBR;                /* Dummy read on RX to clear
          return;
          UART3Buffer[UART3Count] = LPC_UART3->RBR;
          UART3Count++;
          if ( UART3Count == BUFSIZE )
                UART3Count = 0;                /* buffer overflow */
        UART3Count++;
        UART3Status |= 0x100;                /* Bit 9 as the CTI error */
        LSRValue = LPC_UART3->LSR;                /* Check status in the LSR to see if
          UART3TxEmpty = 1;
          UART3TxEmpty = 0;
**                                                VIC table
  uint32_t Fdiv;
  if ( PortNum == 0 )
        switch ( pclkdiv )
          case 0x00:
          default:
                break;
          case 0x01:
                break;
          case 0x02:
                break;
          case 0x03:
                break;
    return (TRUE);
        switch ( pclkdiv )
          case 0x00:
          default:
                break;
          case 0x01:
                break;
          case 0x02:
                break;
          case 0x03:
                break;
    return (TRUE);
  else if ( PortNum == 2 )
        LPC_PINCON->PINSEL4 &= ~0x000f0000;
        LPC_PINCON->PINSEL4 |=  0x000a0000;        /* Enable RxD1 P2.9, TxD1 P2.8 */
        /* Bit 16,17 are for UART2 */
        pclkdiv = (LPC_SC->PCLKSEL1 >> 16) & 0x03;
        switch ( pclkdiv )
          case 0x00:
          default:
                break;
          case 0x01:
                break;
          case 0x02:
                break;
          case 0x03:
                break;
    LPC_UART2->LCR = 0x83;                /* 8 bits, no Parity, 1 Stop bit */
    LPC_UART2->DLM = Fdiv / 256;
    LPC_UART2->DLL = Fdiv % 256;
        LPC_UART2->LCR = 0x03;                /* DLAB = 0 */
    LPC_UART2->FCR = 0x07;                /* Enable and reset TX and RX FIFO. */
           NVIC_EnableIRQ(UART2_IRQn);
    LPC_UART2->IER = IER_RBR | IER_THRE | IER_RLS;        /* Enable UART2 interrupt */
    return (TRUE);
  else if ( PortNum == 3 )
        LPC_PINCON->PINSEL9 &= ~0x0f000000;
        LPC_PINCON->PINSEL9 |=  0x0f000000;        /* Enable RxD1 P4.29, TxD1 P4.28 */
        pclkdiv = (LPC_SC->PCLKSEL1 >> 18) & 0x03;
        switch ( pclkdiv )
          case 0x00:
          default:
                break;
          case 0x01:
                break;
          case 0x02:
                break;
          case 0x03:
                break;
    LPC_UART3->LCR = 0x83;                /* 8 bits, no Parity, 1 Stop bit */
    LPC_UART3->DLM = Fdiv / 256;
    LPC_UART3->DLL = Fdiv % 256;
        LPC_UART3->LCR = 0x03;                /* DLAB = 0 */
    LPC_UART3->FCR = 0x07;                /* Enable and reset TX and RX FIFO. */
           NVIC_EnableIRQ(UART3_IRQn);
    LPC_UART3->IER = IER_RBR | IER_THRE | IER_RLS;        /* Enable UART2 interrupt */
    return (TRUE);
  return( FALSE );
  if ( portNum == 0 )
          BufferPtr++;
          Length--;
  else if ( portNum == 1 )
      BufferPtr++;
      Length--;
  else if ( portNum == 2 )
          while ( !(UART2TxEmpty & 0x01) );
          LPC_UART2->THR = *BufferPtr;
          UART2TxEmpty = 0;        /* not empty in the THR until it shifts out */
          BufferPtr++;
          Length--;
          while ( !(UART3TxEmpty & 0x01) );
          LPC_UART3->THR = *BufferPtr;
          UART3TxEmpty = 0;        /* not empty in the THR until it shifts out */
          BufferPtr++;
          Length--;
  return;
**                            End Of File
发表于 2019-9-18 07:14:55 来自手机 | 只看该作者
nxp也有库,例程看看。
出45入88汤圆
 楼主| 发表于 2019-9-18 07:22:18 | 只看该作者
解决了,原来串口0,1默认是打开了电源,串口2,3要设置寄存器才能打开电源。
发表于 2019-9-18 09:04:36 | 只看该作者
nxp有个功率寄存器要使能的
发表于 2019-9-18 20:23:56 | 只看该作者
感谢分享
GMT+8, 2024-4-29 05:09
