回复: 278
恶补模拟电路 仿真的 [同相比例放大电路] & [反相比例放大电路] 其他陆续增加中
发表于 2008-5-9 16:05:14 | 显示全部楼层 |阅读模式
1.同相比例放大电路
(原文件名:同相1.jpg)
  仿真波形图
(原文件名:同相波形.jpg)
2.反相比例放大电路
(原文件名:反相.jpg)
  仿真波形图
(原文件名:反相波形.jpg)
  频率响应
(原文件名:SpxImage1.jpg)
Circuit: Pro33E
Date:    星期五 五月 9 16:31:37 2008
Fourier analysis for vout:
  No. Harmonics: 10, THD: 7.4154E-5 %, Gridsize: 200, Interpolation Degree: 1
Harmonic  Frequency      Magnitude      Phase          Norm. Mag      Norm. Phase
0        0.00000E+000   3.31204E-005   0.00000E+000   0.00000E+000   0.00000E+000
1        1.00000E+004   9.98621E-001   1.79463E+002   1.00000E+000   0.00000E+000
2        2.00000E+004   2.79656E-007   9.42420E+001   2.80042E-007   -8.52212E+001
3        3.00000E+004   2.68728E-007   9.67391E+001   2.69099E-007   -8.27241E+001
4        4.00000E+004   2.60577E-007   9.93774E+001   2.60936E-007   -8.00857E+001
5        5.00000E+004   2.59877E-007   1.01727E+002   2.60236E-007   -7.77363E+001
6        6.00000E+004   2.58920E-007   1.04081E+002   2.59277E-007   -7.53821E+001
7        7.00000E+004   2.57590E-007   1.06443E+002   2.57946E-007   -7.30202E+001
8        8.00000E+004   2.55650E-007   1.08819E+002   2.56003E-007   -7.06446E+001
9        9.00000E+004   2.52505E-007   1.11221E+002   2.52854E-007   -6.82424E+001
Fourier analysis for vin:
  No. Harmonics: 10, THD: 6.34448E-5 %, Gridsize: 200, Interpolation Degree: 1
0        0.00000E+000   -5.62056E-008  0.00000E+000   0.00000E+000   0.00000E+000
1        1.00000E+004   4.99331E-001   1.18011E-005   1.00000E+000   0.00000E+000
2        2.00000E+004   1.12365E-007   -8.53517E+001  2.25032E-007   -8.53517E+001
3        3.00000E+004   1.12308E-007   -8.30279E+001  2.24917E-007   -8.30279E+001
4        4.00000E+004   1.12228E-007   -8.07046E+001  2.24757E-007   -8.07046E+001
5        5.00000E+004   1.12125E-007   -7.83819E+001  2.24550E-007   -7.83819E+001
6        6.00000E+004   1.11999E-007   -7.60600E+001  2.24299E-007   -7.60600E+001
7        7.00000E+004   1.11851E-007   -7.37390E+001  2.24001E-007   -7.37390E+001
8        8.00000E+004   1.11680E-007   -7.14191E+001  2.23659E-007   -7.14191E+001
9        9.00000E+004   1.11486E-007   -6.91004E+001  2.23270E-007   -6.91004E+001
Fourier analysis for vcc5p:
  No. Harmonics: 10, THD: 171.815 %, Gridsize: 200, Interpolation Degree: 1
0        0.00000E+000   5.00000E+000   0.00000E+000   0.00000E+000   0.00000E+000
1        1.00000E+004   1.23250E-015   1.42227E+002   1.00000E+000   0.00000E+000
2        2.00000E+004   7.86616E-016   -1.06312E+002  6.38227E-001   -2.48539E+002
3        3.00000E+004   4.99047E-016   1.72843E+002   4.04906E-001   3.06165E+001
4        4.00000E+004   6.31662E-016   -2.31854E+001  5.12505E-001   -1.65412E+002
5        5.00000E+004   3.78207E-016   -1.05668E+002  3.06861E-001   -2.47895E+002
6        6.00000E+004   1.23092E-015   -1.61925E+002  9.98719E-001   -3.04151E+002
7        7.00000E+004   4.47810E-016   -6.87789E+001  3.63334E-001   -2.11006E+002
8        8.00000E+004   7.32656E-016   -1.30206E+002  5.94447E-001   -2.72433E+002
9        9.00000E+004   9.06641E-016   -1.60544E+002  7.35611E-001   -3.02771E+002
Fourier analysis for vcc5n:
0        0.00000E+000   -5.00000E+000  0.00000E+000   0.00000E+000   0.00000E+000
1        1.00000E+004   1.23250E-015   -3.77731E+001  1.00000E+000   0.00000E+000
2        2.00000E+004   7.86616E-016   7.36880E+001   6.38227E-001   1.11461E+002
3        3.00000E+004   4.99047E-016   -7.15664E+000  4.04906E-001   3.06165E+001
4        4.00000E+004   6.31662E-016   1.56815E+002   5.12505E-001   1.94588E+002
5        5.00000E+004   3.78207E-016   7.43318E+001   3.06861E-001   1.12105E+002
6        6.00000E+004   1.23092E-015   1.80754E+001   9.98719E-001   5.58486E+001
7        7.00000E+004   4.47810E-016   1.11221E+002   3.63334E-001   1.48994E+002
8        8.00000E+004   7.32656E-016   4.97942E+001   5.94447E-001   8.75674E+001
9        9.00000E+004   9.06641E-016   1.94556E+001   7.35611E-001   5.72287E+001
Fourier analysis for vcc12p:
  No. Harmonics: 10, THD: 171.466 %, Gridsize: 200, Interpolation Degree: 1
0        0.00000E+000   1.20000E+001   0.00000E+000   0.00000E+000   0.00000E+000
1        1.00000E+004   2.83594E-015   -1.05288E+002  1.00000E+000   0.00000E+000
2        2.00000E+004   3.31005E-015   -1.35761E+002  1.16718E+000   -3.04734E+001
3        3.00000E+004   2.92189E-016   1.14228E+002   1.03031E-001   2.19515E+002
4        4.00000E+004   6.00441E-016   4.76978E+001   2.11725E-001   1.52985E+002
5        5.00000E+004   4.51685E-016   -1.20094E+002  1.59272E-001   -1.48067E+001
6        6.00000E+004   2.49445E-015   -1.53344E+002  8.79586E-001   -4.80561E+001
7        7.00000E+004   1.14891E-015   -7.05845E+001  4.05126E-001   3.47030E+001
8        8.00000E+004   2.05377E-015   -1.35526E+002  7.24193E-001   -3.02381E+001
9        9.00000E+004   5.28149E-016   -1.32274E+002  1.86234E-001   -2.69861E+001
Fourier analysis for vcc12n:
0        0.00000E+000   -1.20000E+001  0.00000E+000   0.00000E+000   0.00000E+000
1        1.00000E+004   2.83594E-015   7.47124E+001   1.00000E+000   0.00000E+000
2        2.00000E+004   3.31005E-015   4.42390E+001   1.16718E+000   -3.04734E+001
3        3.00000E+004   2.92189E-016   -6.57723E+001  1.03031E-001   -1.40485E+002
4        4.00000E+004   6.00441E-016   -1.32302E+002  2.11725E-001   -2.07015E+002
5        5.00000E+004   4.51685E-016   5.99058E+001   1.59272E-001   -1.48067E+001
6        6.00000E+004   2.49445E-015   2.66563E+001   8.79586E-001   -4.80561E+001
7        7.00000E+004   1.14891E-015   1.09415E+002   4.05126E-001   3.47030E+001
8        8.00000E+004   2.05377E-015   4.44744E+001   7.24193E-001   -3.02381E+001
9        9.00000E+004   5.28149E-016   4.77263E+001   1.86234E-001   -2.69861E+001
PDF格式下载
点击此处下载 ourdev_272242.pdf(文件大小:16K) (原文件名:反相比例放大电路仿真波形.pdf)
点击此处下载 ourdev_272243.pdf(文件大小:33K) (原文件名:反相比例放大电路原理图.pdf)
点击此处下载 ourdev_272244.pdf(文件大小:15K) (原文件名:同相比例放大电路仿真波形.pdf)
点击此处下载 ourdev_272245.pdf(文件大小:35K) (原文件名:同相比例放大电路原理图.pdf)
PROTEL AD6格式下载
点击此处下载 ourdev_272262.rar(文件大小:6K) (原文件名:反相比例放大电路.rar)
点击此处下载 ourdev_272263.rar(文件大小:6K) (原文件名:同相比例放大电路.rar)
出0入22汤圆
发表于 2008-5-9 16:14:49 | 显示全部楼层
谢谢。看看看看。
 楼主| 发表于 2008-5-9 16:20:01 | 显示全部楼层
楼上的真速度,我还没发完呢。
发表于 2008-5-9 16:29:55 | 显示全部楼层
最近用上了Multisim,很爽,只是画原理图没有 AD6 好画,但里面的虚拟仪器用起来就是方便
发表于 2008-5-9 16:34:13 | 显示全部楼层
来个简单的317的稳压电路:
(原文件名:1.jpg)
发表于 2008-5-9 16:34:52 | 显示全部楼层
狂顶!!正要补模电呢。
发表于 2008-5-9 16:35:45 | 显示全部楼层
超声波收发同体电路分析:
(原文件名:2.jpg)
发表于 2008-5-9 16:36:43 | 显示全部楼层
电路仿真软件对于我们这些模拟电路设计经验不够的人来说  还是很有作用的
参考作用很大。
 楼主| 发表于 2008-5-9 16:40:54 | 显示全部楼层
狂汗啊
把高手们都整兴奋了。
下次一定要发有技术含量的..
 楼主| 发表于 2008-5-9 16:44:36 | 显示全部楼层
260Khz超声波接收部份电路分析
(原文件名:SpxImage2.jpg)
(原文件名:SpxImage3.jpg)
发表于 2008-5-9 16:53:37 | 显示全部楼层
希望多点这样基础的电路.特别是如何设计.
汗.我现在只会写C了..
以前学校是大专.
跟本不会培养我们做电路设计.
另外也一直没机会接触.都是在做软件.
发表于 2008-5-9 17:10:56 | 显示全部楼层
模拟电路还是pspice仿真最好,其中个人认为最好的仿真器是Orcad,Multisim,AD也用过,不过和ORCAD比起来,还是差得太远.
发表于 2008-5-9 17:33:22 | 显示全部楼层
看来我也得补一补模拟电路了.总是搞数字电路和单片机,结果模拟部分什么都不会了.
发表于 2008-5-9 20:02:52 | 显示全部楼层
拜托老大,这些都是最基本的电路,如果这些都还不会的话真的很难混的。特别是做一个稍微复杂点的电路。
当然不是要你记住,但是需要你至少知道在什么地方有现成的可以参考。。
发表于 2008-5-9 20:58:12 | 显示全部楼层
不错,谢谢
发表于 2008-5-9 21:12:46 | 显示全部楼层
顶啊,多谢楼主共享。
发表于 2008-5-9 21:44:17 | 显示全部楼层
先做记号,慢慢学习。
发表于 2008-5-9 23:53:52 | 显示全部楼层
ding
 楼主| 发表于 2008-5-10 08:41:09 | 显示全部楼层
差分放大电路
(原文件名:SpxImage10.jpg)
(原文件名:SpxImage7.jpg)
(原文件名:SpxImage8.jpg)
加法电路 反相输出
输出波形反相叠加了1V的电压
(原文件名:SpxImage9.jpg)
(原文件名:SpxImage6.jpg)
PDF格式下载
点击此处下载 ourdev_273003.pdf(文件大小:32K) (原文件名:差分放大电路Schematic Prints.pdf)
点击此处下载 ourdev_273004.pdf(文件大小:25K) (原文件名:差分放大电路SimView Prints.pdf)
点击此处下载 ourdev_273005.pdf(文件大小:30K) (原文件名:加法电路Schematic Prints.pdf)
点击此处下载 ourdev_273006.pdf(文件大小:15K) (原文件名:加法电路SimView Prints.pdf)
 楼主| 发表于 2008-5-30 17:17:42 | 显示全部楼层
3V 5V 双相转换电路
(原文件名:SpxImage4.jpg)
(原文件名:io-conv.gif)
PDF格式原理图ourdev_297237.pdf(文件大小:31K) (原文件名:Schematic Prints.pdf)
PDF格式波形图ourdev_297238.pdf(文件大小:15K) (原文件名:SimView Prints.pdf)
发表于 2008-5-30 18:24:28 | 显示全部楼层
这个好像是PS什么什么的模拟的吗?
发表于 2008-5-30 21:03:43 | 显示全部楼层
好,留个标记
出0入46汤圆
发表于 2008-5-30 21:04:45 | 显示全部楼层
学习了!
发表于 2008-5-30 21:11:22 | 显示全部楼层
记号
发表于 2008-5-31 14:56:06 | 显示全部楼层
mark
发表于 2008-5-31 19:02:38 | 显示全部楼层
好贴
发表于 2008-5-31 19:43:34 | 显示全部楼层
哇!
看到好资料,学习...
发表于 2008-5-31 20:24:25 | 显示全部楼层
19楼的mosfet的电路可以实现3V和5V转换吗??貌似不行吧??
 楼主| 发表于 2008-6-4 23:06:49 | 显示全部楼层
MOS 管的 3-5V转换,是IIC上最常用的转换,
具体为什么能实现双向,我也不知道。
不过看波形好象是可以的  也希望高手指点一下 他为什么能实现双向的转换
发表于 2008-6-4 23:32:00 | 显示全部楼层
很简单,因为MOS管在不加偏压的时候本来就是单向导通的……
发表于 2008-6-5 00:27:49 | 显示全部楼层
ms仿真完了最好还是搭一个实体电路验证 有一次用op37搞一个衰减电路  仿真没问题 作板子自激了 -_-!
发表于 2008-6-5 00:47:29 | 显示全部楼层
仿真“没错”而实体电路出错的原因,通常是没有给被仿真电路加入必要的干扰源……
发表于 2008-6-5 01:20:41 | 显示全部楼层
-_-干扰源么? 其实是没有加补偿电容引起的
发表于 2008-6-5 01:41:18 | 显示全部楼层
哦,正确的说法应该是,电路仿真时无法出现实体电路中遇到的问题,是仿真过程中缺乏必要的干扰源造成的
发表于 2008-6-5 02:05:48 | 显示全部楼层
赞成 仿真距离实际还是比较远的  尤其是pcb这块
发表于 2008-6-5 20:43:26 | 显示全部楼层
AD6的仿镇功能还没有用过
发表于 2008-6-16 20:02:50 | 显示全部楼层
19楼的图,请高手赐教
看仿真结果,开关断开和闭合,输出端电压只有0.01V的变化
(原文件名:未命名.GIF)
 楼主| 发表于 2008-6-16 20:18:23 | 显示全部楼层
按键下接个100K的再接地试试
发表于 2008-6-17 01:30:55 | 显示全部楼层
ding !!
发表于 2008-6-17 08:41:51 | 显示全部楼层
加了100K下地也不行,基本上电压没有变化
发表于 2008-6-17 09:45:15 | 显示全部楼层
mark
发表于 2008-6-17 19:54:12 | 显示全部楼层
74lvc4245那个是王道。其他的低速下用没什么问题。
发表于 2008-6-22 19:47:39 | 显示全部楼层
看看,Multisim用起来还不错哦!
发表于 2009-3-16 22:13:09 | 显示全部楼层
我正在学模电,但还没学到这个软件,以后请多多指教啊!
发表于 2009-3-17 18:36:25 | 显示全部楼层
学习
发表于 2009-3-17 20:09:52 | 显示全部楼层
谢谢。看看看看。
发表于 2009-3-18 19:47:01 | 显示全部楼层
mark 谢谢
发表于 2009-3-18 20:05:58 | 显示全部楼层
老师今天刚讲了运放~~学习
发表于 2009-3-21 17:34:05 | 显示全部楼层
jh
发表于 2009-4-25 22:22:40 | 显示全部楼层
MARK
发表于 2009-4-26 14:36:31 | 显示全部楼层
mark一下
发表于 2009-4-26 15:27:17 | 显示全部楼层
仔细看看,3V-5V 双向转换电路,对吗?
(原文件名:3V-5V 双向转换电路 对吗?.png)
发表于 2009-4-26 16:43:09 | 显示全部楼层
功率mos管不清楚,但大部分开关mos管源极和漏极直接还接有一个二极管,电流从源流向漏的话,不加偏压也能导通
发表于 2009-4-27 20:50:38 | 显示全部楼层
要补!!!
发表于 2009-4-27 21:13:47 | 显示全部楼层
mark
出50入0汤圆
发表于 2009-4-29 13:44:09 | 显示全部楼层
模拟电路 仿真, 高手!
发表于 2009-4-29 17:37:13 | 显示全部楼层
顶!
发表于 2009-5-23 19:51:18 | 显示全部楼层
这个要好好学习
出0入25汤圆
发表于 2009-5-23 19:58:59 | 显示全部楼层
mark
发表于 2009-8-23 18:11:36 | 显示全部楼层
在看,学习……!
发表于 2009-8-23 18:47:26 | 显示全部楼层
学习
发表于 2009-8-23 20:22:51 | 显示全部楼层
呃…………………………
自言自语:“该补模电喽!”
发表于 2009-8-23 21:24:05 | 显示全部楼层
cool
发表于 2009-8-23 22:55:52 | 显示全部楼层
记号
发表于 2009-8-23 23:05:47 | 显示全部楼层
好东西  不看快忘光了
发表于 2009-8-23 23:27:04 | 显示全部楼层
好贴留记号,,,,最近用到了负压,做一个电源,才知道自己模电多么的弱。。。。。
发表于 2009-8-23 23:52:13 | 显示全部楼层
jh
发表于 2009-8-24 08:29:29 | 显示全部楼层
学习
发表于 2009-8-25 15:41:27 | 显示全部楼层
好就一个字
发表于 2009-9-3 01:00:44 | 显示全部楼层
学习了~~~·
发表于 2009-9-3 09:37:40 | 显示全部楼层
弱弱的问下楼主用的什么仿真软件
发表于 2009-9-3 17:31:07 | 显示全部楼层
真的要补啊,连基础的都不会,
发表于 2009-10-3 19:36:45 | 显示全部楼层
模电没学明白……
发表于 2009-10-3 23:40:09 | 显示全部楼层
学习
发表于 2009-10-4 09:24:15 | 显示全部楼层
mark
发表于 2009-10-4 10:29:48 | 显示全部楼层
mark
发表于 2009-10-30 16:26:02 | 显示全部楼层
恶恶补。。
出0入33汤圆
发表于 2009-10-30 16:32:21 | 显示全部楼层
收藏
发表于 2009-10-30 19:07:22 | 显示全部楼层
马克一下
发表于 2009-10-31 00:04:19 | 显示全部楼层
楼主问一下,你用的是什么软件,能否讲一下,我也想试试
发表于 2009-10-31 01:04:02 | 显示全部楼层
mark
发表于 2009-10-31 01:43:22 | 显示全部楼层
马克
发表于 2009-10-31 05:16:10 | 显示全部楼层
【79楼】 cyr_hongfeng
派别:
等级:------
来自:
LZ用的应是protel仿真软件。
发表于 2009-10-31 06:55:46 | 显示全部楼层
仿真是个好东西。呵呵。
不过,很多时候模型不对的话,可能误导人哦。
有过教训。
发表于 2009-11-1 20:34:45 | 显示全部楼层
向楼主学习!
发表于 2009-11-2 11:17:18 | 显示全部楼层
mark
发表于 2009-11-7 15:58:03 | 显示全部楼层
mark
发表于 2009-11-10 16:46:54 | 显示全部楼层
太好的东西了,以前没有认真学,现在回想一下,真后悔啊,模电浪费掉了
发表于 2009-11-10 16:57:59 | 显示全部楼层
马克
发表于 2009-11-10 19:04:56 | 显示全部楼层
mark
发表于 2009-11-13 10:36:02 | 显示全部楼层
记号一下 呵呵
发表于 2009-11-26 13:47:31 | 显示全部楼层
记号   谢楼主了
发表于 2010-1-3 20:45:44 | 显示全部楼层
mark
发表于 2010-1-6 18:26:25 | 显示全部楼层
mark
发表于 2010-1-6 20:30:08 | 显示全部楼层
mark
发表于 2010-1-28 10:12:55 | 显示全部楼层
好!
发表于 2010-1-28 11:47:26 | 显示全部楼层
的确 有了仿真软件发达之后 原理特别容易忘...尤其是不常用的那些
发表于 2010-1-28 12:14:29 | 显示全部楼层
mark
发表于 2010-1-29 19:58:34 | 显示全部楼层
回复【楼主位】starli 李明星
发表于 2010-1-30 11:24:22 | 显示全部楼层
学习学习
GMT+8, 2024-4-29 07:59
