发表于 2008-5-30 17:49:56
MPLAB IDE v8.10 新特性一览(在Release Notes里有最新支持的芯片型号):
芯片调试资源工具栏(Silicon Debug Resource Toolbar) – A new toolbar details the number of silicon debug features (trace, HW breaks) in the currently selected device for in-circuit emulation or in-circuit debugging. The toolbar indicates if software breakpoints are supported in the device, and whether they are enabled or disabled.
强化的跟踪功能(Trace Improvements) – The disassembled instruction at the trace point is now displayed, and new buttons allow “trace step back “and “trace step forward.”
数据监视与控制接口数据实时更新(DMCI Run-time Data Monitor) –DMCI (in concert with a target-resident monitor and a serial connection) can change application variables during run-time.
PIC18数据捕捉(PIC18 Data Capture )– PIC18-family devices can now stream data off of the device at run time to be displayed in the run-time watch window or the DMCI.
PIC32跟踪启停触发控制(Triggered Control of PIC32 Trace Start/Stop) – New capabilities have been added to the MPLAB REAL ICE to start or stop the collection of trace data based on trigger criteria.
工程目录管理(Project Folder Management) – Project files not tied directly to the current project directory structure can be organized and managed along with other project files.
PIC18软件断点(Software Breakpoints for PIC18) – PIC18-family devices can use software breakpoints with MPLAB REAL ICE.
默认PIC18连接器(Default Linker Script for PIC18 )– Eliminates linker script confusion by automatically using a default linker script. No longer does the engineer need to switch linker scripts when using an in-circuit emulator or debugger. Additionally, the linker wizard doesn’t ask to select a linker script, which reduces the complexity of making projects. Additionally, the PIC18 family has a generic setting for building libraries that will work with any PIC18-family device.
工程符号集快速切换(Fast Swapping Between Project Symbol Sets) – This eases debugging of applications that are built using two projects, such as those with a bootloader.
自动更新(Automated Updates) – MPLAB IDE checks the Microchip web site to see if a newer version is available and notifies the user.. |
